[SOLVED] [WinServer2012] Will Not Download or Install Updates
KidSquid
Active member
Hello -
Many thanks for the assistance you provide here.
As requested in the Forum Posting Instructions I have:
1. Run the SFXFix Tool, it found no errors - log is below
SFCFix version 3.0.0.0 by niemiro.Start time: 2017-03-07 18:41:25.293
Microsoft Windows Server 2012  - amd64
Finish time: 2017-03-07 18:41:51.018
2. I went to upload my CBS folder and found that it was almost 2GB in size, I'm assuming this indicates possible corruption? I have not uploaded this file at the moment but will do so if so instucted.
I have attempted to use the OFFLine tool for Windows Update which always hangs at "listing id's of missing updates" that log is attached.
I have also included my Windows Update log file as I'm hoping it will provide more information for you to review.
I look forward to your reply.
Sid
Hi and welcome to Sysnative. Please start with the following.
  1. Right-click on the Start
Thanks. Now please do the following.
SFC Scan
Please do the following to fix the following file.
2017-03-11 10:51:29, Info                  CSI    000002eb [SR] Could not reproject corrupted file [ml:520{260},l:46{23}]"\??\C:\Windows\System32"\[l:22{11}]"ntmarta.dll"; source file in store is also corrupted
Step#1 - SFCFix Script
Please do the following.
FRST Fix
Results of SFCFix....
SFCFix version 3.0.0.0 by niemiro.Start time: 2017-03-11 12:12:20.095
Using .zip script file at C:\Users\Administrator\Desktop\SFCFix.zip [1]
Successfully took permissions for file or folder C:\Windows\Winsxs
Successfully created directory tree \\?\C:\Windows\Winsxs\amd64_microsoft-windows-security-ntmarta_31bf3856ad364e35_6.2.9200.16384_none_d450290c1965d449.
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\Winsxs\amd64_microsoft-windows-security-ntmarta_31bf3856ad364e35_6.2.9200.16384_none_d450290c1965d449\ntmarta.dll to C:\Windows\Winsxs\amd64_microsoft-windows-security-ntmarta_31bf3856ad364e35_6.2.9200.16384_none_d450290c1965d449\ntmarta.dll.
Successfully restored ownership for C:\Windows\Winsxs
Successfully restored permissions on C:\Windows\Winsxs
Finish time: 2017-03-11 12:14:07.809
Script hash: +iUTj2grE34cG9gq1CvTCcaEy/MZMsOOcTfFrVcLqCg=
Here are the results of the SFC /scannow
I hope this is a good sign.... "Windows Resource Protection did not find any integrity violations."
Yup, good sign. Please do the following next.
Here's the output of the SFCFix -
SFCFix version 3.0.0.0 by niemiro.Start time: 2017-03-12 00:11:58.114
Using .txt script file at C:\Users\Administrator\Desktop\SFCScript.txt [0]
FileScan::
[0: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.17514_none_17197f29b1265401\win32k.sys
File is untraceable.
 Found: IK2jlnCeaUtHl2omn+DBxkAZLu2eOewogVeu/6jprUs=
 Found: 6.1.7601.17514
Trace not available.
[1: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.17803_none_1723547db11f162e\win32k.sys
 Found: flTVvX1pv32WzeEgCCJu/INKtFHr5tIbB8fHujUgRrY=
 Found: 6.1.7601.17803
[2: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.21955_none_1778e240ca63745b\win32k.sys
 Found: ZWfbu4+ESiLrcVJotrgWWJ4QIwtsSw06FoHuIosIF+0=
 Found: 6.1.7601.21955
[3: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.19061_none_16e037a1b151d530\win32k.sys
 Found: QjVhXPVRcaDzVXyTMc3275yGvXyebJiEzNmvAk1nRsE=
 Found: 6.1.7601.19061
[4: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23265_none_176dd77aca6bd77d\win32k.sys
 Found: /8AiL+/buXgRl6/lOPew3kS9VOnLWAu6QbsAnnovW3c=
 Found: 6.1.7601.23265
[5: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.18512_none_171767cdb1283af4\win32k.sys
 Found: PcCxfN9gndhTDspkAljLPutShbY83xndomlH+9R4+sk=
 Found: 6.1.7601.18512
[6: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.22722_none_17963692ca4df3d6\win32k.sys
 Found: ixzQEKeGvXSrjn48mIXrhu+M1O7ZR7OnVoMWpoDzGsw=
 Found: 6.1.7601.22722
[7: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23528_none_179c1dbaca48ab33\win32k.sys
 Found: X1JtGjZ6r8JhAjYECacYwJqAKPhZRhtEqTvts/a5KLI=
 Found: 6.1.7601.23528
[8: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.18577_none_16db89b7b154614d\win32k.sys
 Found: Kf1HEQ7SHE8BeMBlrQV4moOHtnBM4bqUyFHJeFZiz5U=
 Found: 6.1.7601.18577
[9: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.22783_none_17565754ca7db4d3\win32k.sys
 Found: iNLXpneoTBiuZnFw32j6ilzLTpGMnCdnK8tbkyPzFnk=
 Found: 6.1.7601.22783
[10: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.18985_none_16cec0cfb15e3f2c\win32k.sys
 Found: n7O6vArcL6c2EG+LMf0qfp7QOEf74wX5I5vs/kvxAsY=
 Found: 6.1.7601.18985
[11: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23188_none_175b369aca795e3d\win32k.sys
 Found: TwBoLxNSmXy+xZvsIndCzrBhQ0DjrR3738U06+MBuCw=
 Found: 6.1.7601.23188
[12: 2] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23584_none_17573d0aca7ced7d\win32k.sys
 Found: sE5p2syruZhPzE1VWJXP0fMkIr9IhpLybl9But7/kfc=
 Found: 6.1.7601.23584
 [C:\Windows.old\Windows\System32\win32k.sys]
[13: 1] C:\Windows.old\Windows\SoftwareDistribution\Download\c14d6f55cfb96bdeaa12cf169cd7e5e6\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23591_none_17496c40ca87bd69\win32k.sys
 Found: 3ehyU556IvUO+B7qvLYxGn38lkoyUBOE45LRc9rsMj8=
 Found: 6.1.7601.23591
[14: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.18946_none_16fb00c9b13ce8bf\win32k.sys
 Found: y8UQpX91a4dKvVjF3GZhBX6YwIWloE+XMfq02fuR9ZM=
 Found: 6.1.7601.18946
[15: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23149_none_17877694ca5807d0\win32k.sys
 Found: WdGYXYNZ7ac7AQwMGb773MUH6+cKzqlrxHeUNZc9Qn0=
 Found: 6.1.7601.23149
[16: 1] C:\Windows.old\Windows\SoftwareDistribution\Download\a99c8ddafac16c7cb6682de293e73179\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23591_none_17496c40ca87bd69\win32k.sys
[17: 1] C:\Windows.old\Windows\winsxs\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23545_none_17837d04ca5b9710\win32k.sys
 Found: nkP5gj3D+KoW6ycO06GXOSB4NZAgeMY7Qlein2P1LAg=
 Found: 6.1.7601.23545
[18: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.16420_none_11fa0165241defdc\win32k.sys
 Found: VyzMb7tcRnCYeUVJP7Bo/e8ZZnGQq6ZxoOY44YUSgew=
 Found: 6.2.9200.16420
[19: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.20521_none_12849e7a3d3aa8fd\win32k.sys
 Found: i8nhg8WPit1PIFbjk4oMmh26GUeB3WzYChE7wC2VMP4=
 Found: 6.2.9200.20521
[20: 2] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.16384_none_11bd211f244affb7\win32k.sys
 Found: PGEv6Y4Y9CmUZ9PFVRsfH3NuIf54krbYpBaqZvGoiKs=
 Found: 6.2.9200.16384
 [C:\Windows\System32\win32k.sys]
[21: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.20525_none_12889fa23d370e59\win32k.sys
 Found: rtGkw2TUMFSXHRfNYoivOo01DvEoYi7aLd5DQGwPvRU=
 Found: 6.2.9200.20525
[22: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.16424_none_11fe028d241a5538\win32k.sys
 Found: zep0u09gzp5L/SrtUTYVvNxiIvR1d+ZrxDD9X/KLqks=
 Found: 6.2.9200.16424
[23: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.16471_none_11c4f213244594e8\win32k.sys
 Found: ZVc5b8GW7qs++kC+6YMb3nWxt99+v4ZpOU+wwCg+w24=
 Found: 6.2.9200.16471
[24: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.20575_none_125290063d5f9a0e\win32k.sys
 Found: G8Kviz24fYar8hhY/deJKsPyZZInt9m8OHiRpQPF6qw=
 Found: 6.2.9200.20575
[25: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.16467_none_11d5c3bb24381101\win32k.sys
 Found: pjfvhDI0o83ul9z4DEQEyUmnuUJW50WtzmNy53x3uPo=
 Found: 6.2.9200.16467
[26: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.20571_none_124e8ede3d6334b2\win32k.sys
 Found: gRJz9nboXs7yMEW4gBpjUGFWXUEoRa9kbizi6fYVcZU=
 Found: 6.2.9200.20571
[27: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.16465_none_11d3c3272439de53\win32k.sys
 Found: LOnQll4seOtDj6/KBGC8PONMq8uyXHlw89Vjj1B+lZ4=
 Found: 6.2.9200.16465
[28: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.20569_none_1261611a3d53e379\win32k.sys
 Found: UrcmdPPPUVVsl8gKc3xhH9XicpgEH/jRQAMmgX/OqXc=
 Found: 6.2.9200.20569
[29: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.20630_none_1278d02a3d43a8be\win32k.sys
 Found: dwKcGDH8CiQzmfHemw34sT7BBaGpPnbD63baU4I0ba8=
 Found: 6.2.9200.20630
[30: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.16525_none_11ff04bd24196bb6\win32k.sys
 Found: JYFN4wtTQtc4duNupNObhsUJVFe1qiUNaiOTGkXy0Jw=
 Found: 6.2.9200.16525
[31: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.20683_none_1245c16c3d698078\win32k.sys
 Found: x/pJ/QE052wJGWraBtlAJGVW5LoOO1shPIOIN2AK58M=
 Found: 6.2.9200.20683
[32: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.16579_none_11ccf649243e5cc7\win32k.sys
 Found: 3+B7AkAMRk/IWpAl4hDnMWd3wZJv18TmFLRqqqWyJBU=
 Found: 6.2.9200.16579
[33: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.21214_none_129252ca3d2ffb3d\win32k.sys
 Found: HcFVXo5rOot0ouBOxZkkRMbRpR2q8M7DXsW0wcvoBiM=
 Found: 6.2.9200.21214
[34: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.17096_none_11b4354d24517082\win32k.sys
 Found: gBd273Vwp4abudIMY8an9tV1lfbEKLcQoUMo7ddYtrQ=
 Found: 6.2.9200.17096
[35: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.20534_none_127ccf6c3d4010f3\win32k.sys
 Found: uoA9FdbbQUMsSoa+86RfgrVDiyndY69DsYAtyQUVJ1o=
 Found: 6.2.9200.20534
[36: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.16433_none_11f23257242357d2\win32k.sys
 Found: to43LetFWy8W2fAb1rxaXE2HkybWaKGeWieSO0LMqhE=
 Found: 6.2.9200.16433
[37: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.20764_none_125c63743d585f14\win32k.sys
 Found: JQcpKXTcFr2ejs6mnFzcOebhOKvCaLzkPlFLamxVfwE=
 Found: 6.2.9200.20764
[38: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.16657_none_11e09773242fef5e\win32k.sys
 Found: 6r0yGECwvY9Ypa9YhvGAuWyX3CAg0BPOPqU9dCJ3uQQ=
 Found: 6.2.9200.16657
[39: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.22029_none_128c69bc3d33b534\win32k.sys
 Found: 2CioFTUe/Ekt3COtrWtunfy3a3/28iJso54S28y7Rrk=
 Found: 6.2.9200.22029
[40: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.21142_none_126fe08c3d4a1f3b\win32k.sys
 Found: oxzwu6wLJEzjD8tzrtwVHmN9aqNNLeEFP1TdQSyCSL0=
 Found: 6.2.9200.21142
[41: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.17025_none_11fee47724199394\win32k.sys
 Found: y4nJsZqsNgjg6FpEpD7K5QsZKYH/HuPTaskYNJ2MEP4=
 Found: 6.2.9200.17025
[42: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.16451_none_11da91eb24355d06\win32k.sys
 Found: plHgxlFmNI/eASnrs3ZtyFDsgnD/St4Np56kDt8wDH0=
 Found: 6.2.9200.16451
[43: 1] C:\Windows\WinSxS\amd64_microsoft-windows-win32k_31bf3856ad364e35_6.2.9200.20555_none_12682fde3d4f622c\win32k.sys
 Found: hNl3t5Ezmi2J3BolY8DAuhAbDfPtopRKwFRZeI402bs=
 Found: 6.2.9200.20555
Finish time: 2017-03-12 00:12:18.207
Script hash: Tm25/DI1QiKddbytKL/LI/Y6DxTil4kBmH52hiJy9gk=
I installed the update with no issues and rebooted....
When OS started to load, a message appeared saying:
Failure configuring Windows updates
Reverting Changes
Please zip up and attach the following files. You may need to upload them to a hosting provider such as SendSpace and provide the download link so I can get them.
C:\windows\logs\cbs <----entire folder
Extract Readable WindowsUpdate.log
1. Click in the search box at the bottom of the screen and type Powershell.
2. Click on Windows PowerShell Desktop app that appears in the search results.
3. Copy/Paste the following into the Powershell window and hit enter. Note: In Windows 10, after you have copied your text, you can simply right-click inside the powershell window and the text will be pasted.
Get-WindowsUpdateLog
4. You may be prompted with a Microsoft Internet Symbol Store terms of use dialog. If you are, please click Yes.
5. When the process is done there should be a WindowsUpdate.log on your desktop. Please zip/attach this file.
Lastly, c:\windows\inf\setupapi.dev.log (if it exists)
