[SOLVED] Please Help with SFC.exe /Scannow (Famous Problem w/ MSDTC.LOG not being compressed)
g1900
Hi All
I have the same issue (as the ones that were reported on this forum, except I am unable to solve it) with MSDTC.LOG file not being compressed and well I tried to follow steps described on the forum but it did not work for me. I am attaching the log file generated after I ran SFCFix.exe. I would be really thankful if you could help me. I am also posting here the content of the file.
Thank you a lot!
George
SFCFix version 2.4.3.0 by niemiro.
Start time: 2015-03-21 20:53:44.417
CORRUPT: C:\WINDOWS\winsxs\amd64_microsoft-windows-com-dtc-runtime_31bf3856ad364e35_6.3.9600.16384_none_0a1162f033fa01f6\MSDTC.LOG
   CBS & SFC total detected corruption count:     1
   CBS & SFC total unimportant corruption count:  0
   CBS & SFC total fixed corruption count:        0
   SURT total detected corruption count:          0
   SURT total unimportant corruption count:       0
   SURT total fixed corruption count:             0
SFCFix version 2.4.3.0 by niemiro has completed.
Hi again,
I fixed DISM, then ran chkdsk /r on C: (where I have windows 8.1 installed. Both of them ended "successfully". Then I ran scannow and it ended again with the same error about corrupt MSTDC.LOG. I am the content of the log file below. I guess I either need to compress MSDTC.LOG or tell sfc to not to look for compressed MSTDC.LOG. I have no idea how to do either of these two. Could you please help me in solving this issue?
Thank you a lot,
George
Here is, I guess, the [only] relevant log to my problem.
2015-03-22 13:12:08, Info                  CSI    00000130 [SR] Cannot repair member file [l:18{9}]"MSDTC.LOG" of Microsoft-Windows-COM-DTC-Runtime, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file cannot be decompressed
2015-03-22 13:12:12, Info                  CSI    00000138 [SR] Cannot repair member file [l:18{9}]"MSDTC.LOG" of Microsoft-Windows-COM-DTC-Runtime, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file cannot be decompressed
2015-03-22 13:12:12, Info                  CSI    00000139 [SR] This component was referenced by [l:326{163}]"Microsoft-Windows-Client-Features-Package-AutoMerged-com~31bf3856ad364e35~amd64~~6.3.9600.16384.Microsoft-Windows-Client-Features-Package-AutoMerged-com-Deployment"
2015-03-22 13:39:11, Info                  CSI    00000a27 [SR] Repairing 1 components
2015-03-22 13:39:48, Info                  CSI    00000a2b [SR] Cannot repair member file [l:18{9}]"MSDTC.LOG" of Microsoft-Windows-COM-DTC-Runtime, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file cannot be decompressed
2015-03-22 13:41:49, Info                  CSI    00000a2e [SR] Cannot repair member file [l:18{9}]"MSDTC.LOG" of Microsoft-Windows-COM-DTC-Runtime, Version = 6.3.9600.16384, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file cannot be decompressed
2015-03-22 13:41:49, Info                  CSI    00000a2f [SR] This component was referenced by [l:326{163}]"Microsoft-Windows-Client-Features-Package-AutoMerged-com~31bf3856ad364e35~amd64~~6.3.9600.16384.Microsoft-Windows-Client-Features-Package-AutoMerged-com-Deployment"
2015-03-22 13:41:49, Info                  CSI    00000a31 [SR] Repair complete
2015-03-22 13:41:49, Info                  CSI    00000a32 [SR] Committing transaction
Hi and welcome to Sysnative. I need a little more information before I can provide a fix for you. Please do the following.
Step#1 - Re-Run SFC and Provide Log
1. Right-click on the Start
Hi BrianDrab & Thanks a lot for the quick reply!!
I ran again sfc /scannow and then created log text file which I am sending to you now (sending a link to my OneDrive where I uploaded cbs.txt) : http://1drv.ms/1xqGhh7
Please let me know what further steps do I need to follow to resolve the issue.
Thanks again!!
Best regards,
George
Thank you. Please try the following.
Step#1 - SFCFix Script
Step#2 - Verify Corruption is fixed
Items for your next post
1. SFCFix.txt log
2. New CBS.txt log
Thanks a lot a lot a lot! All is well now regarding the issue I had with msdtc.log. I tried to attach two log files to this post but attachment process does not work. It's looping endlessly, will try later to do so again.
Also, when I was trying to repair MSDTC.LOG, I uncovered or somehow got the new issue I had never experienced before (unlike almost all other users of windows 8/8.1). My PC is not shutting down / rebooting if I do not do a hard shutdown (keeping shutdown key down for several seconds). It literally started three days ago (at least I noticed it then).
I deactivated fast start-up and did try to analyze event logs but was unable to single out any specific program/event/application that can cause this. Is there a place on the forum where I can ask for a help regarding this new issue?
Thank you so much again for helping me already!
Kind regards,
George
Did you zip it up first? Right click on it > Send to > Compressed (zipped) folder. Then upload the new .zip file, otherwise it won't upload properly.
Now I did zip it and it worked. Thanks a lot. I will post now regarding the new issue of not being able to shutdown / reboot win8.1 pro.
Thanks a lot,
George
I've verified that you have no more corruption. Take care and good luck with your shutdown issue.
Niemiro - Thanks for the info. I'll adjust my instructions accordingly.
