So I have this wired controller that disconnects every 7 minutes. It's not random, and you could set your watch to it. That's odd enough, but it gets even weirder. When plugged into my PC, the issue doesn't exist and it works just fine. Now, I did open up the controller and found that there were about 5 colors wires soldered to the circuit board, and the black one had come off. However, I resoldered it back on and it didn't fix the problem. So I have no idea what that black wire actually does. The problem isn't the USB port on the PS4, because other controllers work fine. Does anyone have any idea what component could be causing this issue?
