[SOLVED] 0xC1900101 - 0x30018 phase first_boot process sysprep_specialize
I'm happy to hear that!
I would be so happy if Win 11 would work.
The file dsim.zip is attached.
[Oops, I did not see that my post had already been posted]
Copy the file C:\Windows\Logs\CBS\cbs.log to your desktop.
Try the upgrade again and report the result.
Unfortunately, the same error message appeared as at the beginning :l
The process got to 53% then came the blue screen.
Copy the files C:\Windows\Logs\CBS\cbs.log and C:\Windows\Logs\DISM\dism.log to your desktop.
Zip the copied files and attach the zipfile to your next reply.
When available attach following files also:
- C:\$Windows.~BT\Sources\Rollback\setupact.log
- C:\$Windows.~BT\Sources\Rollback\setupact.err
Except for C:\$Windows.~BT\Sources\Rollback\setupact.err I could find all the files.
They are in the zipped folder.
Attach the file C:\Windows\INF\setupapi.dev.log to your next reply.
SFCFix Scan:
  • Download
I was able to connect to the Sysnative servers through the tool.
SFCFix.txt was created.
Uninstall all NVIDIA programs.
Reboot the machine and try the upgrade again.
I uninstalled them. It actually worked.
I am so happy.
I will absolutely suggest this forum!
Great. Glad we could help. I will mark this thread as solved.
Take care.
