[SOLVED] [10v1703b15063 x64] Diagnostic tools stopped working. Upd. (v1709b16299) didn't help.
Re: [W10Stdv1703b15063 x64] Diagnostic tools stopped working. Updating didn't help.
also, "dir tmp*.cat" gets me 0 hits in that directory - there seem to be no files matching that search pattern. Standing by for further instructions. Do i just go ahead with the remaining steps?
(ftr: cryptsvc did not need to be stopped as it wasn't running when i told it to stop, in case that matters. I did start it tho as instructed after renaming catroot2.)
sadly, no luck:
• 2017-11 Kumulatives Update für Windows 10 Version 1709 für amd64-basierte Systeme (KB4048955) – Fehler 0x800706be
• 2017-11 Sicherheitsupdate für Adobe Flash Player für Windows 10 Version 1709 für x64-basierte Systeme (KB4048951) – Fehler 0x800706ba
attached, pls find the latest set of logs : View attachment logs-2017-11-16-(23-16).zip
esentutl /p %systemroot%\System32\catroot2\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\catdb finished stating "Repair completed. Database corruption has been repaired!"
esentutl /g %systemroot%\System32\catroot2\{F750E6C3-38EE-11D1-85E5-00C04FC295EE}\catdb finished stating "Integrity check sucessful."
I assumed you would like me to try normal Windows Update yet again after that and did so. Same result, sorry to say:
latest logs attached : View attachment logs-2017-11-16-(23-48).zip
  1. Right-click on the Start
    Please Note:: if the file is too big (over 7MB) to upload to your next post, please upload via a service such as One Drive or SendSpace and just provide the link.
DISM concluded successfully; cbs.txt ended up really small, here you go : View attachment cbs.txt
finished reporting corrupted files View attachment cbs-2017-11-17-(08-56).zip
Is there maybe a repository somewhere from which we can obtain confirmedly intact versions of the afflicted files and replace them manually at the required position here? Would that make any sense? (Clutching for straws here.) Cheers for your continuedly patient support <3
Yes, I'm sourcing all the replacement files from a clean copy from my virtual machine. I'll be with you shortly.
Strange. Could you do SFC once more please. I can't see any corrupt files.
Install Update with DISM
  1. Download the update MSU here:
    http://download.windowsupdate.com/d..._35f2f534365f41e09b9d707b220b1ea7b1379c1f.msu
    cd C:\temp
    expand {update name}.msu -f:* C:\temp
    replace {update name} with the name of the MSU file downloaded in step 1
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\{update name}.cab
    Restart Windows to complete this operation.
    Do you want to restart the computer now (Y/N)?
  9. Paste (Ctrl+V) it into your next post.
  10. Zip and attach C:\Windows\Logs\CBS\CBS.log
Microsoft Windows [Version 10.0.16299.19]
(c) 2017 Microsoft Corporation. Alle Rechte vorbehalten.
C:\>cd _install
C:\_install>expand windows10.0-kb4048951-x64_35f2f534365f41e09b9d707b220b1ea7b1379c1f.msu -f:* C:\_install
Microsoft (R) Dateiexpansions-Hilfsprogramm
Copyright (c) Microsoft Corporation. Alle Rechte vorbehalten.
C:\_install\WSUSSCAN.cab wird zur Extrahierungswarteschlange hinzugefügt
C:\_install\Windows10.0-KB4048951-x64.cab wird zur Extrahierungswarteschlange hinzugefügt
C:\_install\Windows10.0-KB4048951-x64-pkgProperties.txt wird zur Extrahierungswarteschlange hinzugefügt
C:\_install\Windows10.0-KB4048951-x64.xml wird zur Extrahierungswarteschlange hinzugefügt
Dateien werden erweitert ....
Erweitern der Dateien ist abgeschlossen ...
4 Dateien insgesamt
C:\_install>DISM.exe /Online /Add-Package /PackagePath:C:\_install\windows10.0-kb4048951-x64_35f2f534365f41e09b9d707b220b1ea7b1379c1f.cab
Tool zur Imageverwaltung für die Bereitstellung
Version: 10.0.16299.15
Abbildversion: 10.0.16299.19
Fehler beim Öffnen - C:\_install\windows10.0-kb4048951-x64_35f2f534365f41e09b9d707b220b1ea7b1379c1f.cab Fehler: 0x80070003
Fehler: 3
Die DISM-Protokolldatei befindet sich unter "C:\WINDOWS\Logs\DISM\dism.log".
[noticed the .cab was named differently from the dowload package, retried with name found on cab in dir]
C:\_install>DISM.exe /Online /Add-Package /PackagePath:C:\_install\Windows10.0-KB4048951-x64.cab
1 von 1 werden verarbeitet - Paket "Package_for_KB4048951~31bf3856ad364e35~amd64~~10.0.1.0" wird hinzugefügt
Fehler - Package_for_KB4048951: 0x800706be
Fehler: 1726
Der Remoteprozeduraufruf ist fehlgeschlagen.
C:\_install>
[end of copy]
+ here's the logs:
View attachment logs-2017-11-18-(17-33).zip
Click Start and enter Event Viewer.
Right-click the appropriate log file (Application, Security, System, Directory Service, or File Replication Service). I need System and Application logs.
Click Save Log File As.
Type a name for the file, and click Save.
Zip the files up and attach them for me to review.
not that I was aware of it. Probably one of those thingies that you only notice once you shut them off. ;) Want me to try anything with/out that?
Cheers - A / EMS
