[SOLVED] [10v1703b15063 x64] WU fails and sfc doesn't work dism gives Error:582
Here is the result
Start time: 2018-01-28 17:17:02.012
Microsoft Windows 10 Build 15063 - amd64
Using .txt script file at C:\Users\Owner\Desktop\SFCScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-comctl32-v5.resources_31bf3856ad364e35_10.0.15063.0_tr-tr_a5e84df14d3e554b.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-comctl32-v5.resources_31bf3856ad364e35_10.0.15063.0_tr-tr_a5e84df14d3e554b.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-comctl32-v5.resources_31bf3856ad364e35_10.0.15063.0_tr-tr_a5e84df14d3e554b.
Finish time: 2018-01-28 17:17:04.035
Script hash: VvtJG/cweTzM/HaI5WqdKkOu5xCkf5HwgcYSo2Ck13s=
Good. Please repeat the following. I'll only need the Logfile.pml if you get another Error: 582
2. Open an elevated Command Prompt and run sfc /scannow just like you have in the past.
3. Stop Process Monitor as soon as sfc fails. You can simply do this by clicking the magnifying glass on the toolbar as shown below.
We have another corruption to fix as shown below.
Please do the following.
Step#1 - SFCFix Script
Sorry for the delay, here is the result.
Start time: 2018-01-31 22:40:56.700
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e¾5_10.0.15063.0_bg-bg_b18ba9fa1bdcf885.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
Successfully deleted registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e¾5_10.0.15063.0_bg-bg_b18ba9fa1bdcf885.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_10.0.15063.0_bg-bg_b18ba9fa1bdcf885.
Failed to open registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e¾5_10.0.15063.0_bg-bg_b18ba9fa1bdcf885 with error code ERROR_FILE_NOT_FOUND.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_10.0.15063.0_bg-bg_b18ba9fa1bdcf885.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
RegistryScript:: directive failed to complete successfully.
Finish time: 2018-01-31 22:40:57.608
Script hash: dLoCqjjMwJ+Qjpv6+34PWGU0Tr2mlgAQF9petJwTc9I=
I did a sfc /scannow
and here is the result and CBS.log. Do you want me to do the Process Monitor log file as well?
View attachment CBS.zip
Verification 87% complete.
No need for Procmon yet. We're making good progress. Please do the following now.
Zip file is only 280kb. Attaching here itself
I burned the MemTest86 into a DVD and running that now. I didn't see a setup where I can set how many pass thru. It is going on several passes, except Test 0 all are having several errors. Errors are showing 65535+.
If I exit using Escape, it is going to stop. I don't htink I will be able to save the report if any as I am using DVD. By looking at this do you think a Memory replacement is required and a re-installation of Windows? Or please let me know the next steps.
Unfortunately that's what I suspected and this confirms it. At least one of the sticks of RAM (if you have more than one) is faulty. The priority is replacing the bad RAM. Make sure you run the test and have it come out clean before proceeding.
Once you have good RAM you can either wipe and reload or you may try to do a Windows 10 repair by using the Media Creation Tool (instructions below). Your choice.
1. Download the Media Creation Tool to your desktop. Go ahead and run this. Note: Click the Download tool now button when you are at this link.
2. Accept the license agreement
3. Keep the default which is to Upgrade your PC and click Next.
4. Go ahead and run this through and let me know when complete.
Doing it this way will keep all your data and programs intact. As always though, make sure you have a backup of any critical data in case something unexpected happens.
