Hey Everyone,
Had a BSOD occur this evening with a bugcheck name of
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
and bugcheck code of
0x7E(0xFFFFFFFFC0000005, 0xFFFFF8005A1A0982, 0xFFFFA0841B0E6358, 0xFFFFA0841B0E5B70)
Can upload a memory dmp and a minidump if it helps?
Ive had a look with windbdg and the only thing i can find that makes sense is steam.exe
Any help is appreciated!
Edit: found the instructions for a forum post so currently carrying them out :)
- A brief description of your problem (but you can also include the steps you tried)
- System Manufacturer: Custom build
- Laptop or Desktop: Desktop
- Exact model number: N/A
- OS ?: Windows 11
- x86 (32bit) or x64 (64bit)?: 64-bit
- (Only for Vista, Windows 7) Service pack?: N/A
- What was original installed OS on system?: Windows 11 as using a new SSD for C drive
- Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)?: Think its an OEM as i installed it using media creation kit
- Age of system? (hardware): new RTX 3080 but AMD 3700x is a could years old, Mobo is a Mag Tomahark b550 which is a couple years old, then a few SSD's ranging in less than a year old to a few years but the C drive is only a month old
- Age of OS installation?: Less than three weeks
- Have you re-installed the OS?: With the new SSD
- CPU: AMD 3700x
- RAM (brand, EXACT model, what slots are you using?): 32GB Hyper X in slots 2 and 4
- Video Card: Palet RTX 3080
- MotherBoard - (if NOT a laptop): MAG B550 TOMAHAWK
- Power Supply - brand & wattage (if laptop, skip this one): Corsair 750 RM
- Is driver verifier enabled or disabled?: Unsure
- What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth): Currently just Defender
- Are you using proxy, vpn, ipfilters or similar software?: No
- Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software): No
- Are you currently under/overclocking? Are there overclocking software installed on your system?: No over/underclocking
