[SOLVED] 2012R2 CU fails with 80073712
  3. Press the Fix button.
Restart the machine.
Run the command sfc /scannow in an elevated commandprompt and report the result.
If it fails, copy the file C:\Windows\Logs\CBS\cbs.log to your desktop.
