[7SP1 x64] SFC keeps finding corrupt files and repairing them
I do have a copy of Windows 10 lying around, but I'd rather find out the source of the issues and fix them if possible, reinstalling Windows being a last resort for me.
I wasn't thinking of reinstalling, but rather upgrading to the latest version, so all of your files would remain intact.
Let's see if there's something wrong in the registry:
Retrieve Components Hive
4. The file will likely be too large to upload here so please upload toa file sharing service and just provide the link here.
2. Cause the error just like you have in the past.
Step#1 - Export SideBySide
  5. Change the Save as type: to Registry Hive Files (*.*)
  6. Name this file SxS (with no file extension) and save it to your Desktop.
Upload it to a filesharing service of your choice and provide the link.
You have a corruption within your registry.
Step#1 - FRST Fix
5. When finished FRST64 will generate a log on the Desktop (Fixlog.txt). Please post the contents of it in your reply
Edited user name out.
Fix result of Farbar Recovery Scan Tool (x64) Version: 27.01.2018
Ran by **** (04-02-2018 05:46:27) Run:1
Running from C:\Users\****\Desktop
Loaded Profiles: **** (Available Profiles: ****)
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
[-HKLM\Software\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_microsoft-windows-directx-ÿÿÿÿÿÿÜS|ÝSÑ]
HKLM\Software\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_microsoft-windows-directx-ÿÿÿÿÿÿÜS|ÝSÑ => key not found
==== End of Fixlog 05:47:01 ====
Didn't work. Try this one. P.S. May I ask why are you editing the user name out?
Step#1 - FRST Fix
Ran by **** (04-02-2018 05:58:38) Run:2
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
[-HKLM\Software\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_microsoft-windows-directx-yyyyyy�S|�SN]
HKLM\Software\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_microsoft-windows-directx-yyyyyy�S|�SN  => key not found
==== End of Fixlog 05:58:49 ====
Just a habit of mine for privacy.
