[SOLVED] [7SP1 x64] WU rollups not installing error code 800736B3
Re: [Win7SP1 x64] WU rollups not installing error code 800736B3
  • Drag the SFCFixScript.txt file over the
    SFCFix.exe executable and release it.
OK, ran the script, and here's the output:
Start time: 2017-10-25 16:57:10.800
Using .txt script file at C:\Temp\SFCFixScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_6db34794a14214d6357cd9fe098b74e8_31bf3856ad364e35_6.1.7601.23914_none_f7af58c160c6394e.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\6db34794a14..9fe098b74e8_31bf3856ad364e35_6.1.7601.23914_f7af58c160c6394e.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_6db34794a14214d6357cd9fe098b74e8_31bf3856ad364e35_6.1.7601.23914_none_f7af58c160c6394e.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\d750e188f4d514c65f45947cf16e01d0ab79f0e44cd0d7320318e882dc022ad0.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\6db34794a14..9fe098b74e8_31bf3856ad364e35_6.1.7601.23914_f7af58c160c6394e.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_6db34794a14214d6357cd9fe098b74e8_31bf3856ad364e35_6.1.7601.23914_none_f7af58c160c6394e.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\d750e188f4d514c65f45947cf16e01d0ab79f0e44cd0d7320318e882dc022ad0.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\6db34794a14..9fe098b74e8_31bf3856ad364e35_6.1.7601.23914_f7af58c160c6394e.
Currently storing 6 datablocks.
Finish time: 2017-10-25 16:57:11.409
Script hash: mckny71WZnghG9xG3TQO7y9efs64hE7JJsUI+4RFIFQ=
I rebooted and tried another install of updates, which failed with the same error. I did notice that the download went instantly (It should have at least taken 30 seconds or so to DL 200MB) Then for each of the remaining two updates, the install quickly shot to 50%, stayed there for a little bit, then went to 100%, stayed there for a little bit, then errored out.
Here's the latest CBS.zip.
Download CBS.zip from Sendspace.com - send big files the easy way
I'd love to know what you're looking for in these logs, but I haven't been able to so much as open the large txt files in windows. I'm afraid if I can't get this working within the next 7 days I may end up having to just wipe this machine and reload, but I'm still hoping for some magic!
Thanks,
Jake
We need to fix some registry corruptions step by step as each corruption arise in the next log. We are progressing so if you have the time I'd like to continue.
OK, I ran the latest SFCFix, and here are the results:
Start time: 2017-11-01 06:55:18.072
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\41a04190ae8..5db25aabe63_b77a5c561934e089_6.1.7601.23790_05a896cbc7645339.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\41a04190ae8..5db25aabe63_b77a5c561934e089_6.1.7601.23790_05a896cbc7645339.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\41a04190ae8..5db25aabe63_b77a5c561934e089_6.1.7601.23790_05a896cbc7645339.
Finish time: 2017-11-01 06:55:18.555
Script hash: 8169zL2ec0pShil5fPbCAuLPCjc5c+XpJvk4UaSG2nQ=
Here's my latest CBS folder:
The behaviour of Windows update was pretty much just like last time.
Thanks again!
Jake
2. Download the attachment fixlist.txt and save it to your desktop.
3. Right-click on FRST64.exe and select "Run as administrator".
4. Press the Fix button.
5. The tool will now process fixlist.txt.
6. If for some reason the tool needs a restart, please make sure you let the system restart normally. After that let the tool complete its run.
7. When finished, a log called Fixlog.txt will appear in the same directory the tool is run from.
8. Post the logfile Fixlog.txt as attachment in your next reply.
Here is my Fixlog.txt
Looks like the same behavior occurs when trying to install updates still.
Thanks!
Jake
Sorry, something went wrong with the script I send.
Please follow the instructions below.
3. Press the Fix button.
Sorry for the long delay. Ran this latest fix, and it seemed to behave a little different during the install. It actually downloaded files and took a little time during the install, but still failed.
Here's my log:
Fix result of Farbar Recovery Scan Tool (x64) Version: 19-11-2017
Ran by dsuser (20-11-2017 07:38:18) Run:5
Running from C:\Temp
Loaded Profiles: dsuser (Available Profiles: dsuser & RMMTech & pmanning & jfierst & deltra)
Boot Mode: Normal
fixlist content:
CMD: REG LOAD HKLM\COMPONENTS C:\Windows\System32\config\COMPONENTS
StartRegedit:
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\dfd040441d9..97bb0243ff5_b77a5c561934e089_6.1.7601.23910_9a2f35a77f5367f9]
"i!CBS_package_5_for_kb4040980~31bf3856ad364e35~amd64~~6.1.1.0.4040_0a6ecf8dc19af7ae"=hex:4e,\
00,00,00,02,00,00,00,50,61,63,6b,61,67,65,5f,35,5f,66,6f,72,5f,4b,42,34,30,\
34,30,39,38,30,7e,33,31,62,66,33,38,35,36,61,64,33,36,34,65,33,35,7e,61,6d,\
64,36,34,7e,7e,36,2e,31,2e,31,2e,30,2e,34,30,34,30,39,38,30,2d,34,31,5f,6e,\
65,75,74,72,61,6c,5f,4c,44,52,31,36
EndRegedit:
========= REG LOAD HKLM\COMPONENTS C:\Windows\System32\config\COMPONENTS =========
====> Registry
==== End of Fixlog 07:38:18 ====
Here's my CBS folder as well:
Thanks!
Jake
Here's the latest results:
This time went through very quickly and failed.
Ran by dsuser (20-11-2017 18:26:29) Run:6
Boot Mode: Normal
fixlist content:
StartRegedit:
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5fb7c49b559..af9f8b5c957_b03f5f7f11d50a3a_6.1.7601.23744_3a62ebb8f3bc496f]
"i!CBS_package_5_for_kb4040980~31bf3856ad364e35~amd64~~6.1.1.0.4040_95642aac08f2eb3f"=hex:4e,\
64,36,34,7e,7e,36,2e,31,2e,31,2e,30,2e,34,30,34,30,39,38,30,2d,34,30,5f,6e,\
EndRegedit:
====> Registry
==== End of Fixlog 18:26:30 ====
CBS.log: Download CBS.zip from Sendspace.com - send big files the easy way
Thanks again!
Jake
Sorry for the long delay, but management decided that I needed to wipe the PC out, so I did that late last week. Thanks for all your help troubleshooting. I hope my logs were useful for honing your technique, at least!
Jake
No problem and thanks for your feedback. This thread will be mark as closed/solved.
All the best.
