[7SP1Pro x64] KB4054518 Error 80070057
=================================Checking System Update Readiness.
Binary Version 6.1.7601.22471
Package Version 26.0
2018-02-07 09:43
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
Summary:
Seconds executed: 606
 No errors detected
Export Component Based Servicing
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\
  5. Change the Save as type: to Registry Hive Files (*.*)
  6. Name this file ComponentBasedServicing (with no file extension) and save it to your Desktop.
  7. Right Click on the ComponentBasedServicing file on your Desktop and choose Send To -> Compressed (Zipped) Folder.
  8. Upload it to a file sharing service of your choice and provide the link.
are you by any chance interested in upgradiing to Win10?
Please do the following:
Step#1 - FRST Scan
4. Press Scan button.
6. Please attach the log back here.
7. Another log (Addition.txt - also located in the same directory as FRST64.exe) will be generated Please also attach that along with the FRST.txt in your reply.
I guess I can give a windows 10 update a try if it seems it may be the easier option at this point.
I was reluctant since I'm on a custom Clevo laptop so I'm not too sure how well it will go with drivers, and I also like the option of having a windows 7 development test environment.
Thanks for you help.
I asked because you'd be using a newer OS which is also safer, and 99% of the time Win10 grabs its own drivers, so... Regarding the Win7 dev env. you can always fire up a VM :)
