[SOLVED] [7SP1Pro x64] Updates KB2952664 and KB4048957: Error code 80073701
I'm sorry. Forgot to include..........
Binary Version 6.1.7601.22471
Package Version 26.0
2017-12-10 12:13
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
Summary:
Seconds executed: 154
No errors detected
OK. That's what I wanted to see. Would you please do this:
Remove Update Manually
wusa /uninstall /KB:4022719
If there's an error, please do a registry search for it using FRST and attach SearchReg.txt
Step#1 - FRST Fix
A very rewarding day:
It seems somewhat lame with all of your diligence and patience seeing this issue through to its conclusion, but....
When you suggested that pressing ahead and resolving the Optional update issue was the right thing to do, I knew then that I was very fortunate to have found Sysnative.com and softwaremaniac. I just can't thank you enough for hanging in there with me and my sometimes erratic schedule. You're the BEST!!
