[SOLVED] [8.1Upd3 x64] icrav03.rat & CNBJ2530.DPB corruption
Please do the following.
Step#1 - FRST Fix
Hi, it's done.
Fix result of Farbar Recovery Scan Tool (x64) Version: 14.03.2018Ran by Jorge (19-03-2018 22:16:04) Run:9
Running from C:\Users\kas_l_000\Desktop
Loaded Profiles: Jorge (Available Profiles: Jorge)
Boot Mode: Normal
fixlist content:
StartRegEdit:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_microsoft-windows-os-kernel_31bf3856ad364e35_none_2003e93c9ec12938\6.3]
@="6.3.9600.17476"
EndRegEdit:
====> Registry
==== End of Fixlog 22:16:04 ====
Thanks,
Hi, I now have a problem with the KB2919355. I try to install a software that replies that i don't have installed this KB.But if i search it in programs it seems installed. I tried to uninstaller and reinstaller the KB but it don't let me.
What i can do?
Thanks,
Hi, I installed the KB3115224 but when i rebooted the PC, i had a black screen. I attach a picture of the screen.
I had to restore the OS to previous state.
I assume this is a VM. When you say you restored to a previous state....do you mean the previous restore point that was available? Are you using StorageCraft at all? Also please do the following.
Step#1 - FRST Scan
4. Press Scan button.
6. Please copy and paste log back here.
7. Another log (Addition.txt - also located in the same directory as FRST64.exe) will be generated Please also paste that along with the FRST.txt into your reply.
I assume this is a VM. When you say you restored to a previous state....do you mean the previous restore point that was available? YES
Are you using StorageCraft at all? NO. I restored with Windows in Safe mode
Step#1 - FRST Scan
I attach the FRST and the Addition.
Hi, no idea what is b4notify.exe No is a VM. It is a laptop running 8.1 in normal mode, but once i installed virtual Box for running Windows XP in this laptop for some old software. But i think i uninstalled Virtual Box. I don't run it anymore.
Thanks,
I have to say that since I had the problem with the KB2919355 and a software, I ran the sfc/scannow and the Dism restorehealth before installing the KB3115224 and having the black screen on reboot.
I attach the CBS and the DISM.
Thanks,
Also, please do the following when able. There are remnants of Virtual Box that may have caused the previous issue we had.
Step#1 - FRST Fix
Hi, ok the update failed. I attach the CBS and the fixlog.
Fix result of Farbar Recovery Scan Tool (x64) Version: 14.03.2018Ran by Jorge (21-03-2018 21:23:04) Run:10
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
S3 VBoxNetAdp; C:\WINDOWS\system32\DRIVERS\VBoxNetAdp6.sys [200832 2017-11-22] (Oracle Corporation)
"HKLM\System\CurrentControlSet\Services\VBoxNetAdp" => removed successfully
VBoxNetAdp => service removed successfully
==== End of Fixlog 21:23:17 ====
Thanks,
Hi, I've done the clean boot state and i had the same issue with a black screen, but now i can not restore to a previous point the machine. I attach a capture of the dialog box. I've proven with diferent points with the same result. What could i do?
I dont want restore loosing all the programs installed.
Hi, yes i've tried booting into the 2 safe modes but i had the same error.
what could i do more?
