[SOLVED] Another kb4467107 victim
GSmartControl
  • Execute gsmartcontrol.exe; Let the install complete and launch the programme.
smartctl 6.5 2016-05-07 r4318 [i686-w64-mingw32-win7(64)-sp1] (sf-6.5-1)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     Samsung SSD 860 EVO 250GB
Serial Number:    S3YJNB0K635145B
LU WWN Device Id: 5 002538 e404adcd2
Firmware Version: RVT01B6Q
User Capacity:    250.059.350.016 bytes [250 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   Unknown(0x09fc), ACS-4 T13/BSR INCITS 529 revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Dec 14 11:08:33 2018
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
ATA Security is:  Disabled, frozen [SEC2]
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
                    Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)    The previous self-test routine completed
                    without error or no self-test has ever
                    been run.
Total time to complete Offline
data collection:         (    0) seconds.
capabilities:              (0x53) SMART execute Offline immediate.
                    Auto Offline data collection on/off support.
                    Suspend Offline collection upon new
                    command.
                    No Offline surface scan supported.
                    Self-test supported.
                    No Conveyance Self-test supported.
                    Selective Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
                    Supports SMART auto save timer.
Error logging capability:        (0x01)    Error logging supported.
                    General Purpose Logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      (  85) minutes.
SCT capabilities:            (0x003d)    SCT Status supported.
                    SCT Error Recovery Control supported.
                    SCT Feature Control supported.
                    SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  9 Power_On_Hours          -O--CK   099   099   000    -    77
 12 Power_Cycle_Count       -O--CK   099   099   000    -    142
177 Wear_Leveling_Count     PO--C-   099   099   000    -    2
179 Used_Rsvd_Blk_Cnt_Tot   PO--C-   100   100   010    -    0
181 Program_Fail_Cnt_Total  -O--CK   100   100   010    -    0
182 Erase_Fail_Count_Total  -O--CK   100   100   010    -    0
183 Runtime_Bad_Block       PO--C-   100   100   010    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
190 Airflow_Temperature_Cel -O--CK   079   049   000    -    21
195 Hardware_ECC_Recovered  -O-RC-   200   200   000    -    0
199 UDMA_CRC_Error_Count    -OSRCK   100   100   000    -    0
235 Unknown_Attribute       -O--C-   099   099   000    -    1
241 Total_LBAs_Written      -O--CK   099   099   000    -    891650385
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  SATA NCQ Queued Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1           SL  VS      16  Device vendor specific log
0xa5           SL  VS      16  Device vendor specific log
0xce-0xcf      SL  VS      16  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%        77         -
# 2  Extended offline    Aborted by host               50%        75         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
SCT Status Version:                  3
SCT Version (vendor specific):       256 (0x0100)
SCT Support Level:                   1
Device State:                        Active (0)
Current Temperature:                    21 Celsius
Power Cycle Min/Max Temperature:     14/14 Celsius
Lifetime    Min/Max Temperature:     24/51 Celsius
Under/Over Temperature Limit Count:   0/0
SMART Status:                        0xc24f (PASSED)
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        10 minutes
Min/Max recommended Temperature:      0/70 Celsius
Min/Max Temperature Limit:            0/70 Celsius
Temperature History Size (Index):    128 (40)
Index    Estimated Time   Temperature Celsius
  41    2018-12-13 13:50     ?  -
  42    2018-12-13 14:00    30  ***********
  43    2018-12-13 14:10    36  *****************
  44    2018-12-13 14:20     ?  -
  45    2018-12-13 14:30    24  *****
  46    2018-12-13 14:40     ?  -
  47    2018-12-13 14:50    36  *****************
  48    2018-12-13 15:00     ?  -
  49    2018-12-13 15:10    26  *******
  50    2018-12-13 15:20     ?  -
  51    2018-12-13 15:30     ?  -
  52    2018-12-13 15:40    32  *************
  53    2018-12-13 15:50     ?  -
  54    2018-12-13 16:00     ?  -
  55    2018-12-13 16:10    30  ***********
  56    2018-12-13 16:20     ?  -
  57    2018-12-13 16:30    32  *************
  58    2018-12-13 16:40    34  ***************
  59    2018-12-13 16:50    36  *****************
  60    2018-12-13 17:00    33  **************
  61    2018-12-13 17:10    37  ******************
  62    2018-12-13 17:20    37  ******************
  63    2018-12-13 17:30    38  *******************
  64    2018-12-13 17:40    38  *******************
  65    2018-12-13 17:50    35  ****************
  66    2018-12-13 18:00    38  *******************
  67    2018-12-13 18:10    32  *************
  68    2018-12-13 18:20     ?  -
  69    2018-12-13 18:30    34  ***************
  70    2018-12-13 18:40    31  ************
  71    2018-12-13 18:50    35  ****************
  72    2018-12-13 19:00    37  ******************
  73    2018-12-13 19:10    31  ************
  74    2018-12-13 19:20    36  *****************
  75    2018-12-13 19:30    39  ********************
  76    2018-12-13 19:40    34  ***************
  77    2018-12-13 19:50    34  ***************
  78    2018-12-13 20:00     ?  -
  79    2018-12-13 20:10    21  **
  80    2018-12-13 20:20    29  **********
  81    2018-12-13 20:30    30  ***********
  82    2018-12-13 20:40    30  ***********
  83    2018-12-13 20:50     ?  -
  84    2018-12-13 21:00    29  **********
  85    2018-12-13 21:10    30  ***********
  86    2018-12-13 21:20    32  *************
  87    2018-12-13 21:30    31  ************
  88    2018-12-13 21:40    34  ***************
  89    2018-12-13 21:50    28  *********
  90    2018-12-13 22:00    33  **************
  91    2018-12-13 22:10    28  *********
  92    2018-12-13 22:20     ?  -
  93    2018-12-13 22:30    25  ******
  94    2018-12-13 22:40    35  ****************
  95    2018-12-13 22:50    32  *************
  96    2018-12-13 23:00    34  ***************
  97    2018-12-13 23:10     ?  -
  98    2018-12-13 23:20    33  **************
  99    2018-12-13 23:30    34  ***************
 100    2018-12-13 23:40    31  ************
 101    2018-12-13 23:50    27  ********
 102    2018-12-14 00:00    36  *****************
 103    2018-12-14 00:10    32  *************
 104    2018-12-14 00:20    31  ************
 105    2018-12-14 00:30    28  *********
 106    2018-12-14 00:40    30  ***********
 107    2018-12-14 00:50    28  *********
 108    2018-12-14 01:00    28  *********
 109    2018-12-14 01:10    35  ****************
 110    2018-12-14 01:20    37  ******************
 111    2018-12-14 01:30    38  *******************
 112    2018-12-14 01:40    37  ******************
 113    2018-12-14 01:50     ?  -
 114    2018-12-14 02:00     ?  -
 115    2018-12-14 02:10    22  ***
 116    2018-12-14 02:20    21  **
 117    2018-12-14 02:30    25  ******
 118    2018-12-14 02:40    23  ****
 119    2018-12-14 02:50    22  ***
 120    2018-12-14 03:00    28  *********
 121    2018-12-14 03:10    23  ****
 122    2018-12-14 03:20    33  **************
 123    2018-12-14 03:30    34  ***************
 124    2018-12-14 03:40    34  ***************
 125    2018-12-14 03:50    23  ****
 126    2018-12-14 04:00    32  *************
 127    2018-12-14 04:10    22  ***
   0    2018-12-14 04:20    21  **
   1    2018-12-14 04:30    20  *
   2    2018-12-14 04:40    20  *
   3    2018-12-14 04:50    19  -
   4    2018-12-14 05:00    19  -
   5    2018-12-14 05:10    19  -
   6    2018-12-14 05:20    24  *****
   7    2018-12-14 05:30    21  **
   8    2018-12-14 05:40    22  ***
   9    2018-12-14 05:50    23  ****
  10    2018-12-14 06:00     ?  -
  11    2018-12-14 06:10     ?  -
  12    2018-12-14 06:20    24  *****
  13    2018-12-14 06:30    24  *****
  14    2018-12-14 06:40    30  ***********
  15    2018-12-14 06:50    29  **********
  16    2018-12-14 07:00    32  *************
  17    2018-12-14 07:10    30  ***********
  18    2018-12-14 07:20    34  ***************
  19    2018-12-14 07:30    29  **********
  20    2018-12-14 07:40    30  ***********
  21    2018-12-14 07:50    33  **************
  22    2018-12-14 08:00    33  **************
  23    2018-12-14 08:10    41  **********************
  24    2018-12-14 08:20    37  ******************
  25    2018-12-14 08:30    37  ******************
  26    2018-12-14 08:40    37  ******************
  27    2018-12-14 08:50    36  *****************
  28    2018-12-14 09:00     ?  -
  29    2018-12-14 09:10     ?  -
  30    2018-12-14 09:20    30  ***********
  31    2018-12-14 09:30    29  **********
  32    2018-12-14 09:40    30  ***********
  33    2018-12-14 09:50    30  ***********
  34    2018-12-14 10:00    31  ************
  35    2018-12-14 10:10    32  *************
  36    2018-12-14 10:20    32  *************
  37    2018-12-14 10:30    32  *************
  38    2018-12-14 10:40    24  *****
  39    2018-12-14 10:50    21  **
  40    2018-12-14 11:00     ?  -
SCT Error Recovery Control:
           Read: Disabled
          Write: Disabled
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4             142  ---  Lifetime Power-On Resets
0x01  0x010  4              77  ---  Power-on Hours
0x01  0x018  6       891650385  ---  Logical Sectors Written
0x01  0x020  6        12076633  ---  Number of Write Commands
0x01  0x028  6      1759003096  ---  Logical Sectors Read
0x01  0x030  6        37657002  ---  Number of Read Commands
0x01  0x038  6         2952000  ---  Date and Time TimeStamp
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4              36  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              21  ---  Current Temperature
0x05  0x020  1              51  ---  Highest Temperature
0x05  0x028  1              24  ---  Lowest Temperature
0x05  0x058  1              70  ---  Specified Maximum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4             722  ---  Number of Hardware Resets
0x06  0x010  4               0  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0x07  =====  =               =  ===  == Solid State Device Statistics (rev 1) ==
0x07  0x008  1               0  N--  Percentage Used Endurance Indicator
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2          831  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            3  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
0x000f  2            0  R_ERR response for host-to-device data FIS, CRC
0x0010  2            0  R_ERR response for host-to-device data FIS, non-CRC
0x0012  2            0  R_ERR response for host-to-device non-data FIS, CRC
0x0013  2            0  R_ERR response for host-to-device non-data FIS, non-CRC
2. Try installing the update just like you have in the past.
Well, launched the update together with process monitor:
- the update seems to be finished without problems (sorry but it is in italian)
- The logfile created is 6gb then for me impossible to be send.
- i enclose the link with CBS log.WeTransfer
Then it seems that the update KB4467017 is not possible to be installed but, in my ignorance, i think i could live without it :).
The updates get released each month a therefore supersede the earlier ones. I don't have a definitive answer as to why the November update was giving you grief. Sorry. Glad to hear it's working now!
