Another update currupt file problem
Hi Andy,
Thanks for the logs. The corruption has all been repaired now but let's take a look whether the permissions have actually restored as there seems to be a bit of conflict in the log:
  2. Download the below file, SFCFix.txt, and save this to your Desktop. Ensure that this file is named SFCFix.txt - do not rename it.
    https://dl.dropboxusercontent.com/u...iro/SFCFix Scripts/PrintDataBlocks/SFCFix.txt
  4. On your Desktop, you should see two files: SFCFix.exe and SFCFix.txt.
  5. Drag the file SFCFix.txt onto the file SFCFix.exe and release it.
  8. Copy (Ctrl + C) and Paste (Ctrl + V) the contents of this into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text.
Command Prompt
  1. Click on the Start
    icacls C:\Windows\System32\* /save %USERPROFILE%\Desktop\sysACLfile
    icacls C:\Windows\IME\IMESC5\DICTS\* /save %USERPROFILE%\Desktop\dicACLfile
  4. This will create two files on your Desktop, sysACLfile and dicACLfile, please zip these up (right click > send to > compressed zipped archive) and attach this file to your next post.
Tom
Here's the SFCFIX
SFCFix version 1.4.1.0 by niemiro.
Start time: 2013-04-30 22:40:10.736
Using .txt script file at C:\Users\q\Desktop\SFCFix.txt
Successfully took permissions for file or folder C:\Windows\WinSxS\x86_microsoft-windows-directshow-other_31bf3856ad364e35_6.0.6000.16386_none_0b1ac5fde3cf7f3f\mciqtz32.dll
Successfully took permissions for file or folder C:\Windows\System32\mciqtz32.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\x86_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.0.6000.16386_none_15da9be54b086d36\PINTLGAS.IMD
Successfully took permissions for file or folder C:\Windows\IME\IMESC5\DICTS\PINTLGAS.IMD
Successfully copied file \\?\C:\mciqtz32.dll to \\?\C:\Windows\WinSxS\x86_microsoft-windows-directshow-other_31bf3856ad364e35_6.0.6000.16386_none_0b1ac5fde3cf7f3f\mciqtz32.dll.
Successfully copied file \\?\C:\mciqtz32.dll to \\?\C:\Windows\System32\mciqtz32.dll.
Successfully copied file \\?\C:\PINTLGAS.IMD to \\?\C:\Windows\WinSxS\x86_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.0.6000.16386_none_15da9be54b086d36\PINTLGAS.IMD.
Successfully copied file \\?\C:\PINTLGAS.IMD to \\?\C:\Windows\IME\IMESC5\DICTS\PINTLGAS.IMD.
Successfully restored ownership for C:\Windows\WinSxS\x86_microsoft-windows-directshow-other_31bf3856ad364e35_6.0.6000.16386_none_0b1ac5fde3cf7f3f\mciqtz32.dll
Successfully restored permissions on C:\Windows\WinSxS\x86_microsoft-windows-directshow-other_31bf3856ad364e35_6.0.6000.16386_none_0b1ac5fde3cf7f3f\mciqtz32.dll
Failure code returned from icacls process in RestoreFromDataBlock function for file C:\Windows\System32\mciqtz32.dll. Error code 0x5.
Successfully restored ownership for C:\Windows\WinSxS\x86_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.0.6000.16386_none_15da9be54b086d36\PINTLGAS.IMD
Successfully restored permissions on C:\Windows\WinSxS\x86_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.0.6000.16386_none_15da9be54b086d36\PINTLGAS.IMD
Failure code returned from icacls process in RestoreFromDataBlock function for file C:\Windows\IME\IMESC5\DICTS\PINTLGAS.IMD. Error code 0x5.
PowerCopy:: directive failed to complete successfully.
SFCFix version 1.4.1.0 by niemiro has completed.
Finish time: 2013-04-30 22:40:11.120
----------------------EOF------------------
I'm hoping the zip file is attached ...
Hi Bobble,
Can you use the attached SFCFix script as you have previously done please? Post the log when it finishes :)
Tom
Start time: 2013-05-01 16:42:22.194
Using .txt script file at C:\Users\q\Downloads\SFCFix.txt
PrintDataBlocks::
C:\Windows\WinSxS\x86_microsoft-windows-directshow-other_31bf3856ad364e35_6.0.6000.16386_none_0b1ac5fde3cf7f3f\mciqtz32.dll|D:PAI(A;;FA;;;S-1-5-80-956008885-3418522649-1831038044-1853292631-2271478464)(A;;0x1200a9;;;BA)(A;;0x1200a9;;;SY)(A;;0x1200a9;;;BU)S:AI|S-1-5-80-956008885-3418522649-1831038044-1853292631-2271478464
C:\Windows\System32\mciqtz32.dll|D:PAI(A;;FA;;;WD)S:AI|S-1-1-0
C:\Windows\WinSxS\x86_microsoft-windows-i..lified-chinese-core_31bf3856ad364e35_6.0.6000.16386_none_15da9be54b086d36\PINTLGAS.IMD|D:PAI(A;;FA;;;S-1-5-80-956008885-3418522649-1831038044-1853292631-2271478464)(A;;0x1200a9;;;BA)(A;;0x1200a9;;;SY)(A;;0x1200a9;;;BU)S:AI|S-1-5-80-956008885-3418522649-1831038044-1853292631-2271478464
C:\Windows\IME\IMESC5\DICTS\PINTLGAS.IMD|D:PAI(A;;FA;;;WD)S:AI|S-1-1-0
PrintDataBlocks:: directive completed successfully.
Finish time: 2013-05-01 16:42:22.210
Hi Andy,
Sorry for keeping you in the dark, there's been a lot of work done in SFCFix recently and I didn't want to interfere with that.
We've successfully repaired the corruption on your system however the ownership of the files still needs resetting as SFCFix was unable to do so with that script.
  2. Download the attached file, SFCFix.txt, and save this to your Desktop. Ensure that this file is named SFCFix.txt - do not rename it.
Tom
Please dont apologies Tom, you have done me a massive favour and for that i salute you.
The reason i ask is that i'm still having certain problems with the computer which i thought were linked to these corrupt files but obviously there must be other issuses.
For at least six months firefox has been crashing regularly, then when i had to do a clean windows install i'm unable to update Microsoft security essential as it states there's no internet connection and now i'm this past week in unable to load things properly, ie tweetdeck, Hp printer software and an electronic car parts catalogue..
I'll have to sort the other stuff out at a later date, at least i can start loading stuff onto the computer again without fear it wont crash while updating .. anyway here's the log :
SFCFix version 1.4.2.0 by niemiro.
Start time: 2013-05-04 23:46:36.757
Using .txt script file at C:\Users\q\Downloads\SFCFix(1).txt
TrustedInstaller::
Successfully set file ownership to TrustedInstaller for C:\Windows\System32\mciqtz32.dll
Successfully set file ownership to TrustedInstaller for C:\Windows\IME\IMESC5\DICTS\PINTLGAS.IMD
TrustedInstaller:: directive completed successfully.
SFCFix version 1.4.2.0 by niemiro has completed.
Finish time: 2013-05-04 23:46:36.778
Now ive had the Blue screen of Death twice this morning also had a pop up saying MSCOMCTL.OCX part of it's dependencies is missing.
Is it just best to reformat the drive then do another clean install ?
Hi Andy,
Hmm those sort of symptoms are usually an indication of malware being present on the system, it might be a good idea to start a thread over at the security forum:
Security Arena - Sysnative Forums
It may well turn out to be nothing but it's better to be safe than sorry!
The corruption has been repaired and we have now restored both the permissions and the ownership so you shouldn't be having any more problems running SFC.
As for the DataBlocks, they are essentially a backup of the permissions and the ownership of a file. If you look back a few posts, you'll see we ran a PrintDataBlocks:: command, which returned this (the 4 datablocks):
PrintDataBlocks::
These are known as a Security Descriptors. Windows uses Security Descriptors to store permissions and they indicate who can read, modify, execute etc. the files. SFCFix usually stores the SID (Security Identifier - a string of numbers unique to that user) of the file owner at the end of the DataBlock however it was unable to do so here and this is why we ran into a few problems - the last SFCFix script you ran manually set the owner back to TrustedInstaller.
Tom
Ok Tom i'll pop across and start a new thread but before i go i just like to thank you for all your help, you have been a star so thank you very much,
Hi Andy,
You're most welcome, it has been a pleasure to work with you :) In future, try to keep to one forum at a time because it can get very confusing for us if our fixes start undoing themselves - fortunately it didn't happen here but it's happened in the past.
http://forums.v3.co.uk/showthread.php?p=1393573
http://forums.pcw.co.uk/showthread.php?p=1393217
Plus, we're better here :p
On another note, you'll need to attach your minidumps to your post over in the BSOD forum for them to analyse:
https://www.sysnative.com/forums/bs...g-instructions-windows-8-7-windows-vista.html
Tom
I've generaly gone to the other forum with little niggling problems and to be fair they have helped me out every time so obviously i went there again but, even though good people have took their time to help no one has an answer so i had to look further afield and here i am .
Not wanting to put the other forum down, there is a more personal 1-2-1 on here.
Anyway thanks again .
Version 6.0.6001.22275
2013-05-06 11:20
Checking Deployment Packages
Checking Package Manifests and catalogs.
Checking package watchlist.
Checking component watchlist.
Checking packages.
Checking component store
(f) CSI Manifest Bad XML 0xC0150006 WinSxS\Manifests\x86_mscorlib_b77a5c561934e089_6.0.6001.18111_none_c7b76ec4c15aabb4.manifest x86_mscorlib_b77a5c561934e089_6.0.6001.18111_none_c7b76ec4c15aabb4
Checking SMI Store
Summary:
Milliseconds: 1014771
Found 1 errors
CSI Manifest Bad XML Total Count: 1
Binary Version 6.0.6002.22574
Package Version 18.0
2013-05-06 19:40
2013-05-06 19:47
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
2013-05-06 20:11
Checking Packages
Summary:
Seconds executed: 1025
No errors detected
Hi Andy,
No luck there, let's see what the other logs have to say about things.
Export CBS folder
  1. Click the Start button
    then click Computer.
  2. Double-click on the C: drive, under the Hard Disk Drives category, and then scroll down to, and double click on the Windows folder.
  3. Find and double click on the Logs folder.
  4. Right-click on the CBS folder, and select Copy.
  5. Go back to your Desktop, right-click on it, and select Paste. You should now see a copy of the CBS folder appear on your Desktop called CBS.
  6. Right-click on this new folder, and navigate through Send to, and select Compressed (zipped) folder.
  7. A new file, also called CBS (CBS.zip), but this time with a different icon, will be created.
Attach CBS.zip to your next post if it is within the forum size limits, if not upload it to Free large file hosting. Send big files the easy way!
Tom
Hi Andy,
Your CBS log is showing that an 0x8007000d error was returned when you attempted to install SP1:
2013-05-06 17:40:48, Info                  CBS    Exec: Processing started.  Client: SP Coordinater Engine, Session: 30296696:1980069146, Package: VistaSP1-KB936330~31bf3856ad364e35~x86~~6.0.0.180002013-05-06 17:40:48, Info                  CBS    Appl: Evaluating package applicability for package VistaSP1-KB936330~31bf3856ad364e35~x86~~6.0.0.18000, applicable state: 7
2013-05-06 17:43:20, Error                        DpxException hr=0x8007000d code=0x020201
2013-05-06 17:43:20, Error                        DpxException hr=0x8007000d code=0x020217
2013-05-06 17:43:20, Info                  CBS    WER: Generating failure report for package: VistaSP1-KB936330~31bf3856ad364e35~x86~~6.0.0.18000, status: 0x8007000d, failure source: CBS Other, start state: 0, target state: 4
2013-05-06 17:43:24, Info                  CBS    SQM: Install counter not opted-in for package: VistaSP1-KB936330~31bf3856ad364e35~x86~~6.0.0.18000
2013-05-06 17:43:24, Info                  CBS    Exec: Processing complete.  Session: 30296696:1980069146, Package: VistaSP1-KB936330~31bf3856ad364e35~x86~~6.0.0.18000, hr: 0x8007000d
0x8007000d tranlates to ERROR_INVALID_DATA:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Windows\System32>err 0xd
# for hex 0xd / decimal 13 :
  BTH_ERROR_HOST_REJECTED_LIMITED_RESOURCES                     bthdef.h
  MUTEX_LEVEL_NUMBER_VIOLATION                                  bugcodes.h
  EVENT_MSCEP_FAIL_TO_ENCRYPT                                   ceplog.mc
# SCEP Add-on cannot encrypt the return CertRep (3) message
# to the client's certificate (%2).  %3  Please find support
# information at http://%1/certsrv/mscep/mscephlp.htm.
  MSG_E_CANNOT_GET_KEY_PROVIDER                                 certlog.mc
# Certificate Services did not start: Unable to extract key
# provider information from the CA certificate for %1.  %2.
  CR_NO_SUCH_DEVNODE                                            cfgmgr32.h
  LOG_MODULE_EVTLOG                                             clusvmsg.h
  IAAPI_BADNUM                                                  iaapi.h
# /* Bad INTEGER or ENUMERATED number */
  MD_ERROR_SUB403_CERT_REVOKED                                  iiscnfg.h
  KDC_ERR_BADOPTION                                             kerberr.h
# KDC cannot accommodate requested option
  RSVP_Err_UNKN_OBJ_CLASS                                       lpmapi.h
  POLICY_ERRV_SUBNET_DEF_FLOW_DURATION                          lpmapi.h
  MAPI_DIAG_LENGTH_CONSTRAINT_VIOLATD                           mapidefs.h
  MMSYSERR_INVALIDALIAS                                         mmsystem.h
  MSIDBERROR_BADFILENAME                                        msiquery.h
# bad filename
  NRC_DUPNAME                                                   nb30.h
# /* duplicate name                             */
  NDDE_INVALID_APPNAME                                          nddeapi.h
  NMERR_INVALID_HPROPERTY                                       netmon.h
  ODBC_ERROR_LOAD_LIB_FAILED                                    odbcinst.h
  OLE_ERROR_OBJECT,                                             ole.h
# Not a valid object                      */
  MSG_LOAD_TEMPLATE                                             pollog.mc
# The %1 Certificate Template could not be loaded.  %2.
  MFE_NO_SPACE                                                  routprot.h
# not enough room in packet
  SCESTATUS_ALREADY_RUNNING                                     scesvc.h
  SNMP_ERRORSTATUS_RESOURCEUNAVAILABLE                          snmp.h
  GE_SSC_ERR_OBJ_CLOSED                                         ssc.h
# /* object is not available for use due  to configuration */
  TWCC_CAPUNSUPPORTED                                           twain.h
# /* Capability not supported by source            */
  MSG_NT4_DOMAIN                                                w32timemsg.mc
# Time Provider NtpClient:  This machine is configured to use
# the domain hierarchy to
# determine its time source, but the computer is joined to a
# Windows NT 4.0 domain. Windows NT 4.0 domain controllers do
# not have
# a time service and do not support domain hierarchy as a
# time source.
# NtpClient will attempt to use an alternate configured
# external time
# source if available.  If an external time source is not
# configured
# or used for this computer, you may choose to disable the
# NtpClient.
[B]  ERROR_INVALID_DATA                                            winerror.h[/B]
[B]# The data is invalid.[/B]
  LDAP_CONFIDENTIALITY_REQUIRED                                 winldap.h
  SNMP_ERROR_RESOURCEUNAVAILABLE                                winsnmp.h
# 29 matches found for "0xd"
I suspect that something isn't quite right with your SP1 download so I would like you to run this FixIt in aggressive mode please:
How do I reset Windows Update components?
Then try to update and post your CBS log if it fails please.
Tom
