[SOLVED] Audio Cracking and Popping. FIX: using audio jacks of the monitor (connected through DisplayPort to the graphics card)
Sorry about the confusion, yes I do have speakers, but they are old stereo speakers connected through an old receiver. This is why I've been using my newly purchased headset to do all the testing. I didn't think it would make a difference because I'm using the same green (front speakers) output from the motherboard. I did test the latest changes on my speakers also. I get the same crackling/popping if I am using my headset, and also if I am using the speakers. My goal is to mainly use my headset once this is fixed.
As for your previous post. I did change the items you discussed, turning off the enhancements, lowering/changing the quality, and unchecking the exclusive control. None of these seemed to have any effect.
I did figure out how to make the other jacks work by changing from stereo to quadraphonic or 5.1. They did produce sound, but the same crackling/popping issues occurred. I now have my headset connected to the green(front speaker/headphone) jack.
Cheers
I will post but it will be a lot later
Possibly after 12 midnight UK time.
No need for you to apologise as I said
My error for not asking for confirmation of speakers / headset.
That is my fault for not clarifying that you were using speakers
Sorry I am late posting, been busy putting new front wheel bearings on my 4x4
Fell asleep last night and woke too late o post.
Please send me attached images as here. AND HOW please is the microphone of the headset attached. - presuming it has one
To send an image either use the snipping tool as here
https://support.microsoft.com/en-gb/help/4027213/windows-10-open-snipping-tool-and-take-a-screenshot
and then click attach files on the reply panel OR with the window on the desktop press print screen key on keyboard
open paint by typing PAINT in search on taskbar and then click on paste, then click select and drag mouse across part of image you want, then copy, file tab, new and paste. File tab, save as to desktop and attach. Send two separate if that is easier
Here are the images. Hopefully your wheel bearings were no trouble!
Pig of a job - on an Isuzu DMax - special locking ring, with detailed preload measurements to take account of 4x4 with locked low.
Will look at them and post approx. 1100 hrs
Sorry for delay
Am studying your various reports
Just looking at the drivers etc installed for the hardware that may be responsible for the problem.
I see you have a Logitech G510 keyboard
and unless I am mistaken also a
Razer Death Adder keyboard
are BOTH in use.
On my screenshots on post 23 as you can see all devices are shown there is no slide arrow to the right
On your playback devices - what else is listed please or is the space below the Dell Monitor all blank
I presume you have two Dell S27116DG monitors, is that correct please.
I do have the Logitech G510 Keyboard and a Razer Death Adder Mouse. Both in use.
I am using the Dell S27116GD(connected through display port)as my main monitor and an much older Acer AL2216W(connected through DVI) monitor.
I included the other images of the lower half of my device list for playback and recording.
OK
This is a little involved - hopefully it will solve your problems
1. This is your monitor
https://downloads.dell.com/manuals/...y/dell-s2716dg-monitor_user's guide_en-us.pdf
2.It has a display port and is connected to the 970 I presume
see page 10
3. The display port carries not only video but also audio
What is the difference between DisplayPort and HDMI? - News
see audio features.
4. The 970 has a display port
Sound via DisplayPort?
and that carries audio from the 970 not requiring your realtek
5. Now see page 10 again of your monitor manual and look at item 3 - line out speakers.
Then page 9 port 3 headphones
NOTE do not connect both
6. Now see page 33 re audio level headphones
The speaker volume is controlled of course from the speakers as they being connected and NOT included in the monitor they must rely on their own volume control.
AFTER a lot of searching, I think this will solve your problem.
Could you kindly work on it and if you have any questions please ask.
You should be able to disable Realtek, enable Nvidia and go from there
Done the other wheel bearing today - not as bad - having done one - but weather conditions were about 10 degrees colder
Luckily the wife kept me supplied with hot drinks.
Goodnight.
Good luck and as I said - I hope you will hear good audio without - the rice crispies:D
So, this worked!!! I currently have my headphones plugged into my Dell monitor. Sound is coming through my displayport. I hear no crackling/popping!!!
I am overwhelmed with excitement!
If you would indulge me though. Why might this have worked? Like should I be investigating? Is my motherboard or cpu or something going bad? What would you do next in order to fix the actual problem? If that makes sense?!?
Thanks again though, it's so nice to hear quality sound again.
and you now reply
I am pleased it worked, well done to you on sorting out that setup, from my guidance.
I cannot really give you a definite reason. I doubt if anyone can.
The possibilities
1. A bad connection on the ports of the headphone and speaker -out on the computer tower.
This does sometime occur, especially if there is frequent connection and disconnection.
The minijack socket becomes worn, however this usually becomes evident in gradually increasing stages.
2. A fault - most unusual but it can occur on the sound chip on the motherboard. The realtek is integrated audio, I mean there is no actual sound card. This in your case is not the apparent problem, as you say the pops and crackles also occurred with the Sounblaster card.
3. Is the computer power connected directly to the AC supply or through a power surge strip. If the latter ios the monitor also on the power surge connection. Sometimes a less than perfect earth can cause such interference.
There is a lot of possible EMI and RFI in computers
Electro magnetic Interference and Radio Frequency Interference.
RFI/EMI in my earphones?
4. IT MAY just be, that something such as the aforementioned faulty earth was effecting the headphone and speaker cables when connected to the computer but not on the monitor.
The DP cable from the card to the monitor is as you will realise less likely to easily pick up interference, than the relatively poor shielded headphone and speaker cables and connections are.
5. The audio of course is now coming from your Nvidia card and not the Realtek.
6. So the answer is, although I have some degree of knowledge about it, having in times gone by, been involved in transmitting radio signals across the world and indeed bouncing them off the moon, I cannot tell you the cause, without being there at your setup.
7. I suggest you do the following
A. Check the inside of your computer tower. Make saure if you have possibly disturbed a power connection that it is fully made. AND whilst inside check for dust build up on fans and the CPU fins and fans
B. If it is connected via power surge and you wish to pursue the testing, try a direct connection without the power surge bar
C. As on the link at 3 you can buy clip on or rings to which you wind the speaker cable say on four turns, known as ferrite chokes - meant for RFI and to a lesser extent
although not designed for them, reasonably effective on other sources of interference.
D. If you had a wireless internet adapter or a wireless keyboard etc, I may have suspected that
OF COURSE on the inside the tower, ensure disconnected from power.
Do NOT touch any chips on ram etc AND before even touching any circuitry, ground any static in your body, by touching firmly the metal case inside on bare metal of the computer tower.
You may think this a little OTT, but I have know people work on a carpeted area, not follow that advice, grabbing hold of a ram stick by the chips on it, instead of the edges of the stick and in the right conditions, it is goodbye that ram stick. NOT OFTEN but certainly can happen
5.
I would, if you do not find anything from the above and before even thinking of ferrite chokes, try connecting the computer to a different power source in your house.
For example if you know a little about electricity circuits, then usually the downstairs is one ring, the upstairs is another and the cooker if electric or the hob, are normally separate circuits. IT MAYBE that the circuit your computer is on, has an earth fault somewhere and of course the earth is common throughout the circuit.
IF there is a fault you may find that it exists on all outlets on that circuit, but not on another ring or separate feed to cooker etc. This slight fault may now be hidden as I said by the use of the DP cable for the sound and the headphones off the monitor. Other equipment in use, may not of course be sensitive to such.
6. FINALLY it has been my pleasure to help you, you are great to work with. Please do let me know how it goes.
Regards
Stay safe in the crisis
Write your reply...
