[SOLVED] Bleeping computers suggested I post for help with corrupt mshta.exe file on W7
If you still have problems with Firefox, either refresh it to the defaults settings or uninstall and reinstall it.
Uninstalling Firefox should be no problem.
Aha. Follow the instructions below to cleanup the tools and logfiles used in this thread.
Rename the file FRST64.exe to uninstall.exe and run it. This will remove all files and folders created by FRST and the tool itself.
Reboot the machine to complete.
You may remove all other tools and log files.
Ahh.. thank you. It wasn't showing up on revo or control panel and I knew it wasn't a portable. SFCfix isn't showing anywhere either but it's in C drive - does it have an uninstaller (I don't know if I should just delete the folder).
Good. I will mark this thread as solved.
Take care.
