BSOD and OS not Found Problem
Hi -
Please run Autoruns - #1a only - https://www.sysnative.com/forums/bs...g-instructions-windows-8-7-windows-vista.html
Save it as an ARN file (default file extension); zip it up and attach to your next post.
I believe you have too many apps running and want to see if we can cut out some start-up items (any items that are start-up disabled will still be available to you when needed).
Regards. . .
jcgriff2
Hello
Yes Sir the above mentioned website and Model No is my System (Silver Color)
I tried Run SeaTools for DOS, LONG test
It Shows STATUS :
Disc burner wasn't found.
Make sure that burner is properly installed & you have appropriate permission to burn the disc.
Even I tried F2 and Factory Restore but it shows HDD :320 GB
THANKS
Hello
Sir , I ran HD Tune Pro.
I have copied BENCHMARK , HEALTH AND INFO in my Post.
HD Tune Pro: Hitachi HTS543232A7A384 Benchmark
Test capacity: full
Read transfer rate
Transfer Rate Minimum : 42.5 MB/s
Transfer Rate Maximum : 87.4 MB/s
Transfer Rate Average : 68.5 MB/s
Access Time : 20.3 ms
Burst Rate : 146.5 MB/s
CPU Usage : 5.9%
HD Tune Pro: Hitachi HTS543232A7A384 Information :
Firmware version : ES2OA90C
Serial number : E20B12C7HHREVS
Capacity : 320.1 gB (298.1 GB)
Buffer size : 8192 KB
Sector size : 512 bytes
Standard : SATA 2.6 (3.0 Gb/s)
Supported mode : UDMA Mode 6
Current mode : UDMA Mode 6
Avergae speed : 60 MB/s
Rotation speed : 5400 RPM
S.M.A.R.T : yes
48-bit Address : yes
Read Look-Ahead : yes
Write Cache : yes
Host Protected Area : yes
Device Configuration Overlay : yes
Firmware Upgradable : yes
Automatic Acoustic Management: no
Power Management : yes
Advanced Power Management : yes
Interface Power Management : yes
Power-up in Standby : yes
Security Mode : yes
SCT Tables : yes
Native Command Queuing (NCQ) : yes
Trim : no
Volume :
Capacity :
Free :
Usage :
File system :
Serial :
Alignment : 2 MB
Volume : New Volume (D:)
Capacity : 73121 MB
Free : 71009 MB
Usage : 3%
File system : NTFS
Serial : 882A-8E44
Alignment : 1 MB
Volume : New Volume (E:)
Capacity : 73595 MB
Free : 71620 MB
Usage : 3%
File system : NTFS
Serial : 4C48-18B8
Alignment : 2 MB
Volume : (C:)
Capacity : 148870 MB
Free : 119095 MB
Usage : 20%
File system : NTFS
Serial : BEBC-8881
Alignment : 1 MB
Volume :
Capacity :
Free :
Usage :
File system :
Serial :
Alignment : 2 MB
HD Tune Pro: Hitachi HTS543232A7A384 Health
ID Current Worst ThresholdData Status
(01) Raw Read Error Rate 100 100 62 0 ok
(02) Throughput Performance 100 100 40 0 ok
(03) Spin Up Time 243 243 33 42949672961 ok
(04) Start/Stop Count 100 100 0 805 ok
(05) Reallocated Sector Count 100 100 5 0 ok
(07) Seek Error Rate 100 100 67 0 ok
(08) Seek Time Performance 100 100 40 0 ok
(09) Power On Hours Count 98 98 0 1238 ok
(0A) Spin Retry Count 100 100 60 0 ok
(0C) Power Cycle Count 100 100 0 793 ok
(BF) G-sense Error Rate 100 100 0 0 ok
(C0) Unsafe Shutdown Count 100 100 0 147 ok
(C1) Load Cycle Count 96 96 0 41501 ok
(C2) Temperature 166 166 0 184685101092 ok
(C4) Reallocated Event Count 100 100 0 0 ok
(C5) Current Pending Sector 100 100 0 0 ok
(C6) Offline Uncorrectable 100 100 0 0 ok
(C7) Interface CRC Error Count 200 200 0 0 ok
(DF) Load/Unload Retry Count 100 100 0 0 ok
Health Status : ok
Please let me know if you need any other things.
THANKS
Hi
Sorry Sir, I couldn't do it
I opened Img Burn option which was created on desktop.
I selected Sea Tools , it shows No device detected in IMG BURN Option
Here is the Picture :
THANKS
