BSOD - BugCheck DRIVER_POWER_STATE_FAILURE 0x0000009f ntoskrnl.exe+180940
Clicking Run Anyway should allow it to run - at least that is how it works on my W10 version.
I've asked the other admins/staff to take a look - it's baffled me why you can't get it to run.
We are still looking into the error - strangely it is not working on my PC now either so I suspect that whatever has been modified has made it worse!
Latest finding is that downloading the app via Internet Explorer works fine. Hope this will work for you.
Note: We are still investigating the reasons for this!
Unfortunately I am not seeing anything obvious from the logs. Please post a new set every time you get a new BSOD and hopefully we can start to detect a pattern.
Is this a new system or did you just reinstall Windows ~1 week ago on:
Original Install Date:     6/1/2019, 11:13:13 AM
If reinstalled Windows, what was the reason?
i.e., were you having system crashes (like BSODs) on the prior Windows installation?
How old is the hardware?
Regards. . .
jcgriff2
System Restore (factory reset) done at request of MSI support for unrelated issue with True Color 2.0 no longer working.
Yes having BSODs prior to restore. Hasn't happened in last couple days since installing older driver on msi site per request here.
Purchased 6 months ago. New laptop.
I would suggest that you contact the system manufacturer's support desk while the system is still under warranty.
The mini kernel memory dumps produced by your BSODs are not clear and straight-forward at all. None of the 3 dumps list a 3rd party driver (non-Microsoft driver) as the probable cause, which means that there is a good chance that "unknown" hardware failure is the likely cause.
However, for info, memory dumps from system crashes are produced for the benefit of software developers to aid them in debugging the piece of software they are currently working on and are not generated for the benefit of end-users like us. We of course use the dumps (process/read them) for general debugging purposes in the hope of helping to diagnose and propose fixes.
Memory dumps are incapable of telling us which piece of hardware has/is failing. Dumps, however, can give clues or point us in a direction. For example, if a bugcheck contains a parameter (one of the four hecadecimal numbers found inside the parenthesis of a bugcheck) that translates to an I/O error, it is likely that there is some type of a problem with a hard drive - internal to the system or perhaps an external SATA or USB HDD. We would then request the user to run HDD diagnostic tests.
A bugcheck that translates to an issue with RAM would highly suggest to us to instruct the user to test RAM.
Your dumps give off no such indicators. That is why I used the term "unknown" hardware failure -- as your BSODs could be caused by just about any piece of hardware from the motherboard, PSU, RAM, HDD/SSD, etc...
MSI Support Desk Information -
System Manufacturer:       Micro-Star International Co., Ltd.
System Model:              GS65 Stealth Thin 8RF
MSI Support Phone - (626) 271-1004
MSI Support Online - MSI USA
Select your exact system model here and look for a BIOS/other driver updates - Laptops - The best gaming laptop provider | MSI USA
"Other Driver Updates" would include video (Intel UHD Graphics 630); wifi (Intel Wireless-AC 9560 160MHz); Ethernet (Killer E2500 Gigabit Ethernet Controller); Bluetooth (Bluetooth Device)
Current BIOS -
BIOS Version/Date    American Megatrends Inc. E16Q2IMS.111, 12/5/2018
SMBIOS Version    3.1
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer Micro-Star International Co., Ltd.
BaseBoard Product MS-16Q2
BaseBoard Version REV:1.0
Platform Role Mobile
Secure Boot State On
Regards. . .
jcgriff2
p.s. About how long after your initial boot (the first boot-up when the laptop was new - 6 months ago) did you start experiencing BSODs? (i.e., the same day as Windows installation/very first system boot-up after removing the laptop from the box; a week; a month, etc...)?
Were you having BSODs when you last contacted MSI about True Color 2.0 not working?
Did True Color 2.0 originally work after installation?
Did " " then stop working/crashing after x-period of time after installation?
Or did " " not work properly at all after installation?
Did you ever get True Color 2.0 to work?
How long ago were you in contact with MSI support about True Color 2.0?
I'm asking these and other questions to try and ascertain whether or not you've had system problems since day 1 (or thereabouts) or did the BSODs start to appear some period of time after your initial system boot-up after you purchased the laptop?
Also - did you buy the laptop as "NEW" or "OPEN-BOX"?
First experienced BSODs approximately 5 months after purchase. Yes, was having BSODs during the True Color 2.0 support call. Yes, True Color 1.0 worked fine then stopped approximately 5 months in as well. True Color 2.0 is fully functional post factory restore. Purchased brand new.
Just received a different BSOD when I went to lunch. Looks like it was memory related.
Bugcheck was 0x1a - severe memory management error. Probable cause listed as "NT" - the Windows kernel. This is not the actual cause. It is simply listed as a default of sorts.
I do believe that there is unknown hardware failure present.
Please contact MSI Support.
Regards. . .
jcgriff2
Microsoft (R) Windows Debugger Version 10.0.17763.132 AMD64
Loading Dump File [C:\Users\PalmDesert\AppData\Local\Temp\Temp1_SysnativeFileCollectionApp.zip\061019-11484-01.dmp]
************* Path validation summary **************
Response Time (ms) Location
Deferred SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 10 Kernel Version 18362 MP (12 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 18362.1.amd64fre.19h1_release.190318-1202
Machine Name:
Kernel base = 0xfffff805`1a000000 PsLoadedModuleList = 0xfffff805`1a4432b0
Debug session time: Mon Jun 10 15:40:57.685 2019 (UTC - 4:00)
System Uptime: 0 days 5:46:04.603
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 1A, {41792, ffff9a3efa490d40, 1004000000, 0}
Probably caused by : memory_corruption ( nt!MiDeleteVa+1718cd )
Followup: MachineOwner
Processing initial command '!analyze -v;r;kv;lmtn;lmtsmn;.bugcheck'
5: kd> !analyze -v;r;kv;lmtn;lmtsmn;.bugcheck
MEMORY_MANAGEMENT (1a)
# Any other values for parameter 1 must be individually examined.
Arguments:
Arg1: 0000000000041792, A corrupt PTE has been detected. Parameter 2 contains the address of
the PTE. Parameters 3/4 contain the low/high parts of the PTE.
Arg2: ffff9a3efa490d40
Arg3: 0000001004000000
Arg4: 0000000000000000
Debugging Details:
KEY_VALUES_STRING: 1
STACKHASH_ANALYSIS: 1
TIMELINE_ANALYSIS: 1
DUMP_CLASS: 1
DUMP_QUALIFIER: 400
BUILD_VERSION_STRING: 18362.1.amd64fre.19h1_release.190318-1202
DUMP_TYPE: 2
BUGCHECK_P1: 41792
BUGCHECK_P2: ffff9a3efa490d40
BUGCHECK_P3: 1004000000
BUGCHECK_P4: 0
BUGCHECK_STR: 0x1a_41792
CPU_COUNT: c
CPU_MHZ: 8a0
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 9e
CPU_STEPPING: a
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: dllhost.exe
CURRENT_IRQL: 2
ANALYSIS_SESSION_HOST: SYSNATIVEFORUMS
ANALYSIS_SESSION_TIME: 06-12-2019 11:23:31.0511
ANALYSIS_VERSION: 10.0.17763.132 amd64fre
LAST_CONTROL_TRANSFER: from fffff8051a22786d to fffff8051a1bc8a0
STACK_TEXT:
fffffb09`7a0f7a68 fffff805`1a22786d : 00000000`0000001a 00000000`00041792 ffff9a3e`fa490d40 00000010`04000000 : nt!KeBugCheckEx
fffffb09`7a0f7a70 fffff805`1a0b41a7 : ffffbc02`b73a69c0 ffff9a3e`fa490d40 00000000`00000000 00000000`00000000 : nt!MiDeleteVa+0x1718cd
fffffb09`7a0f7b80 fffff805`1a0b4661 : fffffb09`7a0f7fd0 ffff9a4d`1f7d2480 00000000`00000000 0a000000`1768a867 : nt!MiWalkPageTablesRecursively+0x1e7
fffffb09`7a0f7c40 fffff805`1a0b4661 : fffffb09`7a0f7fd0 ffff9a4d`268fbe90 00000000`00000000 0a000004`0e889867 : nt!MiWalkPageTablesRecursively+0x6a1
fffffb09`7a0f7d00 fffff805`1a0b4661 : fffffb09`7a0f7fd0 ffff9a4d`269347d8 ffff9a4d`00000000 8a000001`99661867 : nt!MiWalkPageTablesRecursively+0x6a1
fffffb09`7a0f7dc0 fffff805`1a0b3dec : fffffb09`7a0f7fd0 ffff9a4d`269349a0 fffffb09`00000000 fffffb09`7a0f7f49 : nt!MiWalkPageTablesRecursively+0x6a1
fffffb09`7a0f7e80 fffff805`1a0b2258 : fffffb09`7a0f7fd0 ffffbc02`00000002 00000000`00000001 00000000`00000000 : nt!MiWalkPageTables+0x36c
fffffb09`7a0f7f80 fffff805`1a0c03b0 : ffffffff`ffffffff ffffbc02`b73a6838 00000000`00000001 00000000`00000000 : nt!MiDeletePagablePteRange+0x268
fffffb09`7a0f8320 fffff805`1a5c9c9d : ffffbc02`a926a080 ffffbc02`a926a080 ffffbc02`a48ae060 ffffbc02`b73a6830 : nt!MiDeleteVad+0x860
fffffb09`7a0f84e0 fffff805`1a5dc084 : ffffbc02`a48ae060 ffffbc02`b2734290 ffffbc02`a926a080 00000000`00000000 : nt!MiUnmapVad+0x49
fffffb09`7a0f8510 fffff805`1a5dbb3f : ffffbc02`b75236e0 ffffbc02`b75236e0 ffffbc02`b73a64c0 fffff805`1a465180 : nt!MiCleanVad+0x30
fffffb09`7a0f8540 fffff805`1a635551 : ffffffff`00000000 ffffffff`ffffffff fffffb09`7a0f8701 ffffbc02`b73a64c0 : nt!MmCleanProcessAddressSpace+0x137
fffffb09`7a0f85c0 fffff805`1a65c313 : ffffbc02`b73a64c0 ffffcd82`fe4975f0 fffffb09`7a0f87e9 00000000`00000000 : nt!PspRundownSingleProcess+0x139
fffffb09`7a0f8640 fffff805`1a6ca853 : ffffbc02`00000000 00000191`06fb5a01 00000089`8b045000 fffffb09`7a0f8834 : nt!PspExitThread+0x60b
fffffb09`7a0f8750 fffff805`1a03da11 : 00000000`00000000 fffff805`1a5f30be ffff88b2`6d4cf84e 00000000`00000002 : nt!KiSchedulerApcTerminate+0x33
fffffb09`7a0f8790 fffff805`1a1c0d90 : ffffbc02`acd09801 fffffb09`7a0f8850 ffffbc02`b35bee10 00000000`00000000 : nt!KiDeliverApc+0x481
fffffb09`7a0f8850 fffff805`1a1ce03f : 00000000`00000000 fffffb09`7a0f8a80 ffffbc02`b6febde0 fffff805`1a5fbbad : nt!KiInitiateUserApc+0x70
fffffb09`7a0f8990 00007ffa`eccbf9f4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x9f
00000089`8b9ffa78 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffa`eccbf9f4
THREAD_SHA1_HASH_MOD_FUNC: c091b23167a9747ad03bff889b67c15ac126f525
THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 028e1779ed9fb9e850a1d1503c577728a8d15412
THREAD_SHA1_HASH_MOD: 82d14546c43bd06881f781d6d197c4c7f7ceb9cb
FOLLOWUP_IP:
fffff805`1a22786d cc int 3
FAULT_INSTR_CODE: 550de8cc
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt!MiDeleteVa+1718cd
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 0
IMAGE_VERSION: 10.0.18362.145
STACK_COMMAND: .thread ; .cxr ; kb
IMAGE_NAME: memory_corruption
BUCKET_ID_FUNC_OFFSET: 1718cd
FAILURE_BUCKET_ID: 0x1a_41792_nt!MiDeleteVa
PRIMARY_PROBLEM_CLASS: 0x1a_41792_nt!MiDeleteVa
TARGET_TIME: 2019-06-10T19:40:57.000Z
OSBUILD: 18362
OSSERVICEPACK: 145
SERVICEPACK_NUMBER: 0
OS_REVISION: 0
SUITE_MASK: 784
PRODUCT_TYPE: 1
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS Personal
OS_LOCALE:
USER_LCID: 0
OSBUILD_TIMESTAMP: unknown_date
BUILDDATESTAMP_STR: 190318-1202
BUILDLAB_STR: 19h1_release
BUILDOSVER_STR: 10.0.18362.1.amd64fre.19h1_release.190318-1202
ANALYSIS_SESSION_ELAPSED_TIME: f31
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x1a_41792_nt!mideleteva
FAILURE_ID_HASH: {ad6dfca3-101b-35a8-d6e1-12de9ecbc1f5}
rax=ffff9a0000000000 rbx=0000001004000000 rcx=000000000000001a
rdx=0000000000041792 rsi=fffffb097a0f7fd0 rdi=ffff9a3efa490d40
rip=fffff8051a1bc8a0 rsp=fffffb097a0f7a68 rbp=fffffb097a0f7b19
r8=ffff9a3efa490d40 r9=0000001004000000 r10=fffff8051a0b5fa0
r11=ffffbc02b73a69c0 r12=0000000000000042 r13=fffffb097a0f8200
r14=00007df4921a8000 r15=0000000000000000
iopl=0 nv up ei pl zr na po nc
cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00040246
nt!KeBugCheckEx:
fffff805`1a1bc8a0 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:fffffb09`7a0f7a70=000000000000001a
# Child-SP RetAddr : Args to Child : Call Site
00 fffffb09`7a0f7a68 fffff805`1a22786d : 00000000`0000001a 00000000`00041792 ffff9a3e`fa490d40 00000010`04000000 : nt!KeBugCheckEx
01 fffffb09`7a0f7a70 fffff805`1a0b41a7 : ffffbc02`b73a69c0 ffff9a3e`fa490d40 00000000`00000000 00000000`00000000 : nt!MiDeleteVa+0x1718cd
02 fffffb09`7a0f7b80 fffff805`1a0b4661 : fffffb09`7a0f7fd0 ffff9a4d`1f7d2480 00000000`00000000 0a000000`1768a867 : nt!MiWalkPageTablesRecursively+0x1e7
03 fffffb09`7a0f7c40 fffff805`1a0b4661 : fffffb09`7a0f7fd0 ffff9a4d`268fbe90 00000000`00000000 0a000004`0e889867 : nt!MiWalkPageTablesRecursively+0x6a1
04 fffffb09`7a0f7d00 fffff805`1a0b4661 : fffffb09`7a0f7fd0 ffff9a4d`269347d8 ffff9a4d`00000000 8a000001`99661867 : nt!MiWalkPageTablesRecursively+0x6a1
05 fffffb09`7a0f7dc0 fffff805`1a0b3dec : fffffb09`7a0f7fd0 ffff9a4d`269349a0 fffffb09`00000000 fffffb09`7a0f7f49 : nt!MiWalkPageTablesRecursively+0x6a1
06 fffffb09`7a0f7e80 fffff805`1a0b2258 : fffffb09`7a0f7fd0 ffffbc02`00000002 00000000`00000001 00000000`00000000 : nt!MiWalkPageTables+0x36c
07 fffffb09`7a0f7f80 fffff805`1a0c03b0 : ffffffff`ffffffff ffffbc02`b73a6838 00000000`00000001 00000000`00000000 : nt!MiDeletePagablePteRange+0x268
08 fffffb09`7a0f8320 fffff805`1a5c9c9d : ffffbc02`a926a080 ffffbc02`a926a080 ffffbc02`a48ae060 ffffbc02`b73a6830 : nt!MiDeleteVad+0x860
09 fffffb09`7a0f84e0 fffff805`1a5dc084 : ffffbc02`a48ae060 ffffbc02`b2734290 ffffbc02`a926a080 00000000`00000000 : nt!MiUnmapVad+0x49
0a fffffb09`7a0f8510 fffff805`1a5dbb3f : ffffbc02`b75236e0 ffffbc02`b75236e0 ffffbc02`b73a64c0 fffff805`1a465180 : nt!MiCleanVad+0x30
0b fffffb09`7a0f8540 fffff805`1a635551 : ffffffff`00000000 ffffffff`ffffffff fffffb09`7a0f8701 ffffbc02`b73a64c0 : nt!MmCleanProcessAddressSpace+0x137
0c fffffb09`7a0f85c0 fffff805`1a65c313 : ffffbc02`b73a64c0 ffffcd82`fe4975f0 fffffb09`7a0f87e9 00000000`00000000 : nt!PspRundownSingleProcess+0x139
0d fffffb09`7a0f8640 fffff805`1a6ca853 : ffffbc02`00000000 00000191`06fb5a01 00000089`8b045000 fffffb09`7a0f8834 : nt!PspExitThread+0x60b
0e fffffb09`7a0f8750 fffff805`1a03da11 : 00000000`00000000 fffff805`1a5f30be ffff88b2`6d4cf84e 00000000`00000002 : nt!KiSchedulerApcTerminate+0x33
0f fffffb09`7a0f8790 fffff805`1a1c0d90 : ffffbc02`acd09801 fffffb09`7a0f8850 ffffbc02`b35bee10 00000000`00000000 : nt!KiDeliverApc+0x481
10 fffffb09`7a0f8850 fffff805`1a1ce03f : 00000000`00000000 fffffb09`7a0f8a80 ffffbc02`b6febde0 fffff805`1a5fbbad : nt!KiInitiateUserApc+0x70
11 fffffb09`7a0f8990 00007ffa`eccbf9f4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiSystemServiceExit+0x9f (TrapFrame @ fffffb09`7a0f8a00)
12 00000089`8b9ffa78 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffa`eccbf9f4
start end module name
ffffcc21`33000000 ffffcc21`333a0000 win32kfull win32kfull.sys 72096118 (This is a reproducible build file hash, not a timestamp)
ffffcc21`333b0000 ffffcc21`33658000 win32kbase win32kbase.sys 9DC13AD9 (This is a reproducible build file hash, not a timestamp)
ffffcc21`33660000 ffffcc21`336a8000 cdd cdd.dll E63E8BF3 (This is a reproducible build file hash, not a timestamp)
ffffcc21`33ba0000 ffffcc21`33c2c000 win32k win32k.sys 7B83186F (This is a reproducible build file hash, not a timestamp)
fffff805`17200000 fffff805`17236000 wcifs wcifs.sys 616EC3AA (This is a reproducible build file hash, not a timestamp)
fffff805`17240000 fffff805`172b7000 cldflt cldflt.sys 0CF2C7CF (This is a reproducible build file hash, not a timestamp)
fffff805`172c0000 fffff805`172da000 storqosflt storqosflt.sys D77C69C8 (This is a reproducible build file hash, not a timestamp)
fffff805`172e0000 fffff805`172f8000 lltdio lltdio.sys 707E9308 (This is a reproducible build file hash, not a timestamp)
fffff805`17300000 fffff805`17319000 mslldp mslldp.sys 15C3108A (This is a reproducible build file hash, not a timestamp)
fffff805`17320000 fffff805`1733b000 rspndr rspndr.sys ED98D1EE (This is a reproducible build file hash, not a timestamp)
fffff805`17340000 fffff805`1735d000 wanarp wanarp.sys 1BD57CFB (This is a reproducible build file hash, not a timestamp)
fffff805`17360000 fffff805`17378000 ndisuio ndisuio.sys 38FD20EE (This is a reproducible build file hash, not a timestamp)
fffff805`17380000 fffff805`17432000 nwifi nwifi.sys B3B2BBFC (This is a reproducible build file hash, not a timestamp)
fffff805`17440000 fffff805`17478000 winquic winquic.sys D60F7863 (This is a reproducible build file hash, not a timestamp)
fffff805`17480000 fffff805`175c4000 HTTP HTTP.sys F709630D (This is a reproducible build file hash, not a timestamp)
fffff805`175d0000 fffff805`175e3000 condrv condrv.sys AEE79CBA (This is a reproducible build file hash, not a timestamp)
fffff805`17600000 fffff805`17625000 bowser bowser.sys D37F2E35 (This is a reproducible build file hash, not a timestamp)
fffff805`17630000 fffff805`1764a000 mpsdrv mpsdrv.sys 7D5AF2F0 (This is a reproducible build file hash, not a timestamp)
fffff805`17650000 fffff805`176df000 mrxsmb mrxsmb.sys BACC3E1C (This is a reproducible build file hash, not a timestamp)
fffff805`176e0000 fffff805`17725000 mrxsmb20 mrxsmb20.sys 274D454A (This is a reproducible build file hash, not a timestamp)
fffff805`17730000 fffff805`177f4000 srv2 srv2.sys CC2BA330 (This is a reproducible build file hash, not a timestamp)
fffff805`17800000 fffff805`17822000 rasl2tp rasl2tp.sys A7AA404E (This is a reproducible build file hash, not a timestamp)
fffff805`17830000 fffff805`17850000 raspptp raspptp.sys 54893590 (This is a reproducible build file hash, not a timestamp)
fffff805`17860000 fffff805`1787c000 raspppoe raspppoe.sys 053A7D72 (This is a reproducible build file hash, not a timestamp)
fffff805`17880000 fffff805`178ba000 ndiswan ndiswan.sys FB43C10D (This is a reproducible build file hash, not a timestamp)
fffff805`17930000 fffff805`17944000 cfwids cfwids.sys Tue Mar 5 22:52:45 2019 (5C7F440D)
fffff805`17960000 fffff805`17966000 winio64 winio64.sys Fri Jun 4 00:08:03 2010 (4C087C23)
fffff805`17b00000 fffff805`17b0d000 WSDPrint WSDPrint.sys FCE23E82 (This is a reproducible build file hash, not a timestamp)
fffff805`17b60000 fffff805`17b73000 vwifimp vwifimp.sys 3AE8886D (This is a reproducible build file hash, not a timestamp)
fffff805`17b80000 fffff805`17bb7000 nvhda64v nvhda64v.sys Tue Apr 3 22:01:20 2018 (5AC431F0)
fffff805`17c60000 fffff805`18805000 dump_iaStorAC dump_iaStorAC.sys Wed Feb 27 08:31:32 2019 (5C769134)
fffff805`18830000 fffff805`1884d000 dump_dumpfve dump_dumpfve.sys C1539D11 (This is a reproducible build file hash, not a timestamp)
fffff805`18850000 fffff805`1892b000 dxgmms2 dxgmms2.sys E443C889 (This is a reproducible build file hash, not a timestamp)
fffff805`18930000 fffff805`18946000 monitor monitor.sys B13C31B1 (This is a reproducible build file hash, not a timestamp)
fffff805`18950000 fffff805`189a0000 WUDFRd WUDFRd.sys 2A40F545 (This is a reproducible build file hash, not a timestamp)
fffff805`189b0000 fffff805`189bb000 mshidumdf mshidumdf.sys DD5C0F15 (This is a reproducible build file hash, not a timestamp)
fffff805`189c0000 fffff805`189ea000 luafv luafv.sys 08A8E82A (This is a reproducible build file hash, not a timestamp)
fffff805`1a000000 fffff805`1aab2000 nt ntkrnlmp.exe FECF74B7 (This is a reproducible build file hash, not a timestamp)
fffff805`1aab2000 fffff805`1ab55000 hal hal.dll 63975E9E (This is a reproducible build file hash, not a timestamp)
fffff805`1da00000 fffff805`1da0b000 kd kd.dll 5A75D524 (This is a reproducible build file hash, not a timestamp)
fffff805`1da10000 fffff805`1dc11000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll 258CAB1A (This is a reproducible build file hash, not a timestamp)
fffff805`1dc20000 fffff805`1dc31000 werkernel werkernel.sys 958E14B2 (This is a reproducible build file hash, not a timestamp)
fffff805`1dc40000 fffff805`1dc6a000 ksecdd ksecdd.sys A35F28F6 (This is a reproducible build file hash, not a timestamp)
fffff805`1dc70000 fffff805`1dcd0000 msrpc msrpc.sys 8E1A4F15 (This is a reproducible build file hash, not a timestamp)
fffff805`1dce0000 fffff805`1dd07000 tm tm.sys 2ADB549A (This is a reproducible build file hash, not a timestamp)
fffff805`1dd10000 fffff805`1dd78000 CLFS CLFS.SYS 477FEB27 (This is a reproducible build file hash, not a timestamp)
fffff805`1dd80000 fffff805`1dd9a000 PSHED PSHED.dll B21F9DDA (This is a reproducible build file hash, not a timestamp)
fffff805`1dda0000 fffff805`1ddab000 BOOTVID BOOTVID.dll 0F301604 (This is a reproducible build file hash, not a timestamp)
fffff805`1ddb0000 fffff805`1ddbe000 cmimcext cmimcext.sys C7F022B4 (This is a reproducible build file hash, not a timestamp)
fffff805`1ddc0000 fffff805`1ddcc000 ntosext ntosext.sys BAC877D8 (This is a reproducible build file hash, not a timestamp)
fffff805`1ddd0000 fffff805`1dde3000 WDFLDR WDFLDR.SYS 3B396780 (This is a reproducible build file hash, not a timestamp)
fffff805`1ddf0000 fffff805`1ddff000 SleepStudyHelper SleepStudyHelper.sys BA6E2346 (This is a reproducible build file hash, not a timestamp)
fffff805`1de00000 fffff805`1df05000 clipsp clipsp.sys Mon Mar 18 18:11:27 2019 (5C90178F)
fffff805`1df10000 fffff805`1df81000 FLTMGR FLTMGR.SYS 2FCE7C68 (This is a reproducible build file hash, not a timestamp)
fffff805`1df90000 fffff805`1e06c000 CI CI.dll BFF35B48 (This is a reproducible build file hash, not a timestamp)
fffff805`1e070000 fffff805`1e12c000 cng cng.sys 65453531 (This is a reproducible build file hash, not a timestamp)
fffff805`1e130000 fffff805`1e205000 Wdf01000 Wdf01000.sys 116A658A (This is a reproducible build file hash, not a timestamp)
fffff805`1e210000 fffff805`1e220000 WppRecorder WppRecorder.sys 34A54231 (This is a reproducible build file hash, not a timestamp)
fffff805`1e230000 fffff805`1e255000 acpiex acpiex.sys 2B91EDB2 (This is a reproducible build file hash, not a timestamp)
fffff805`1e260000 fffff805`1e27a000 SgrmAgent SgrmAgent.sys F851A195 (This is a reproducible build file hash, not a timestamp)
fffff805`1e280000 fffff805`1e34c000 ACPI ACPI.sys 637B6DAD (This is a reproducible build file hash, not a timestamp)
fffff805`1e350000 fffff805`1e35c000 WMILIB WMILIB.SYS 59021E3D (This is a reproducible build file hash, not a timestamp)
fffff805`1e360000 fffff805`1e36b000 msisadrv msisadrv.sys 5E470A0E (This is a reproducible build file hash, not a timestamp)
fffff805`1e370000 fffff805`1e3df000 pci pci.sys AF24B239 (This is a reproducible build file hash, not a timestamp)
fffff805`1e3e0000 fffff805`1e420000 tpm tpm.sys F091EC87 (This is a reproducible build file hash, not a timestamp)
fffff805`1e460000 fffff805`1e4a9000 intelpep intelpep.sys 8A1B7970 (This is a reproducible build file hash, not a timestamp)
fffff805`1e4b0000 fffff805`1e4c7000 WindowsTrustedRT WindowsTrustedRT.sys CB95CE3D (This is a reproducible build file hash, not a timestamp)
fffff805`1e4d0000 fffff805`1e4db000 WindowsTrustedRTProxy WindowsTrustedRTProxy.sys 514E3023 (This is a reproducible build file hash, not a timestamp)
fffff805`1e4e0000 fffff805`1e4f5000 pcw pcw.sys 6B731527 (This is a reproducible build file hash, not a timestamp)
fffff805`1e500000 fffff805`1e513000 vdrvroot vdrvroot.sys 0101BCC6 (This is a reproducible build file hash, not a timestamp)
fffff805`1e520000 fffff805`1e553000 pdc pdc.sys 9AEEDDCB (This is a reproducible build file hash, not a timestamp)
fffff805`1e560000 fffff805`1e579000 CEA CEA.sys F3811107 (This is a reproducible build file hash, not a timestamp)
fffff805`1e580000 fffff805`1e5b0000 partmgr partmgr.sys 89C96AD1 (This is a reproducible build file hash, not a timestamp)
fffff805`1e5c0000 fffff805`1e665000 spaceport spaceport.sys DC82B965 (This is a reproducible build file hash, not a timestamp)
fffff805`1e670000 fffff805`1e68a000 volmgr volmgr.sys 211CEF76 (This is a reproducible build file hash, not a timestamp)
fffff805`1e690000 fffff805`1e6f3000 volmgrx volmgrx.sys D6F366B7 (This is a reproducible build file hash, not a timestamp)
fffff805`1e700000 fffff805`1e71f000 mountmgr mountmgr.sys 242DB05F (This is a reproducible build file hash, not a timestamp)
fffff805`1e720000 fffff805`1f2c5000 iaStorAC iaStorAC.sys Wed Feb 27 08:31:32 2019 (5C769134)
fffff805`1f2d0000 fffff805`1f372000 storport storport.sys A692CE5B (This is a reproducible build file hash, not a timestamp)
fffff805`1f380000 fffff805`1f39b000 EhStorClass EhStorClass.sys 526CC202 (This is a reproducible build file hash, not a timestamp)
fffff805`1f3a0000 fffff805`1f3ba000 fileinfo fileinfo.sys 24BBED20 (This is a reproducible build file hash, not a timestamp)
fffff805`1f3c0000 fffff805`1f3fd000 Wof Wof.sys 3CB75347 (This is a reproducible build file hash, not a timestamp)
fffff805`1f400000 fffff805`1f4fa000 mfehidk mfehidk.sys Tue Mar 5 22:46:14 2019 (5C7F4286)
fffff805`1f500000 fffff805`1f50d000 Fs_Rec Fs_Rec.sys 49E932BA (This is a reproducible build file hash, not a timestamp)
fffff805`1f510000 fffff805`1f5a4000 NETIO NETIO.SYS E5D63B1E (This is a reproducible build file hash, not a timestamp)
fffff805`1f5b0000 fffff805`1f84e000 Ntfs Ntfs.sys D9A3CE82 (This is a reproducible build file hash, not a timestamp)
fffff805`1f850000 fffff805`1f9c2000 ndis ndis.sys A6D0FB1E (This is a reproducible build file hash, not a timestamp)
fffff805`1f9d0000 fffff805`1fa02000 ksecpkg ksecpkg.sys E1E129D5 (This is a reproducible build file hash, not a timestamp)
fffff805`1fa10000 fffff805`1fcfa000 tcpip tcpip.sys A5F4F7D8 (This is a reproducible build file hash, not a timestamp)
fffff805`1fd00000 fffff805`1fd7a000 fwpkclnt fwpkclnt.sys 58C1E6ED (This is a reproducible build file hash, not a timestamp)
fffff805`1fd80000 fffff805`1fdb0000 wfplwfs wfplwfs.sys ADA837F9 (This is a reproducible build file hash, not a timestamp)
fffff805`1fdc0000 fffff805`1fe19000 mfewfpk mfewfpk.sys Tue Mar 5 22:46:45 2019 (5C7F42A5)
fffff805`1fe20000 fffff805`1fee9000 fvevol fvevol.sys 66798154 (This is a reproducible build file hash, not a timestamp)
fffff805`1fef0000 fffff805`1fefb000 volume volume.sys A4E9FDFA (This is a reproducible build file hash, not a timestamp)
fffff805`1ff00000 fffff805`1ff6d000 volsnap volsnap.sys 1876F533 (This is a reproducible build file hash, not a timestamp)
fffff805`1ff70000 fffff805`1ffbe000 rdyboost rdyboost.sys F450CEB3 (This is a reproducible build file hash, not a timestamp)
fffff805`1ffc0000 fffff805`1ffe5000 mup mup.sys 565E0311 (This is a reproducible build file hash, not a timestamp)
fffff805`1fff0000 fffff805`20002000 iorate iorate.sys 18D52DDA (This is a reproducible build file hash, not a timestamp)
fffff805`20020000 fffff805`2003c000 disk disk.sys 384FEFED (This is a reproducible build file hash, not a timestamp)
fffff805`20040000 fffff805`200ab000 CLASSPNP CLASSPNP.SYS 09ED6E49 (This is a reproducible build file hash, not a timestamp)
fffff805`32d50000 fffff805`32d6d000 crashdmp crashdmp.sys 2985CB13 (This is a reproducible build file hash, not a timestamp)
fffff805`34600000 fffff805`3460e000 tbs tbs.sys 965BAC31 (This is a reproducible build file hash, not a timestamp)
fffff805`34610000 fffff805`3461a000 Null Null.SYS E822087B (This is a reproducible build file hash, not a timestamp)
fffff805`34620000 fffff805`3462a000 Beep Beep.SYS 528EC21A (This is a reproducible build file hash, not a timestamp)
fffff805`34630000 fffff805`349a3000 dxgkrnl dxgkrnl.sys 8CDD2D26 (This is a reproducible build file hash, not a timestamp)
fffff805`349b0000 fffff805`349c6000 watchdog watchdog.sys 21474799 (This is a reproducible build file hash, not a timestamp)
fffff805`349d0000 fffff805`349e6000 BasicDisplay BasicDisplay.sys 4E6E05E1 (This is a reproducible build file hash, not a timestamp)
fffff805`349f0000 fffff805`34a01000 BasicRender BasicRender.sys 82A93228 (This is a reproducible build file hash, not a timestamp)
fffff805`34a10000 fffff805`34a2c000 Npfs Npfs.SYS B03ECFD3 (This is a reproducible build file hash, not a timestamp)
fffff805`34a30000 fffff805`34a41000 Msfs Msfs.SYS 91FE0FF4 (This is a reproducible build file hash, not a timestamp)
fffff805`34a50000 fffff805`34a76000 tdx tdx.sys 0A1F3DC4 (This is a reproducible build file hash, not a timestamp)
fffff805`34a80000 fffff805`34a90000 TDI TDI.SYS 894065A0 (This is a reproducible build file hash, not a timestamp)
fffff805`34aa0000 fffff805`34af9000 netbt netbt.sys 113D2A22 (This is a reproducible build file hash, not a timestamp)
fffff805`34b00000 fffff805`34b13000 afunix afunix.sys 9D6C12C4 (This is a reproducible build file hash, not a timestamp)
fffff805`34b20000 fffff805`34bc7000 afd afd.sys B88DD13E (This is a reproducible build file hash, not a timestamp)
fffff805`34bd0000 fffff805`34bea000 vwififlt vwififlt.sys 39396289 (This is a reproducible build file hash, not a timestamp)
fffff805`34bf0000 fffff805`34c1b000 pacer pacer.sys E7276BDE (This is a reproducible build file hash, not a timestamp)
fffff805`34c20000 fffff805`34c34000 netbios netbios.sys B37FD2E9 (This is a reproducible build file hash, not a timestamp)
fffff805`34c40000 fffff805`34cbb000 rdbss rdbss.sys BCE0ED0A (This is a reproducible build file hash, not a timestamp)
fffff805`34cc0000 fffff805`34cd2000 nsiproxy nsiproxy.sys 528DA18A (This is a reproducible build file hash, not a timestamp)
fffff805`34ce0000 fffff805`34ced000 npsvctrig npsvctrig.sys 0E7AC006 (This is a reproducible build file hash, not a timestamp)
fffff805`34cf0000 fffff805`34d00000 mssmbios mssmbios.sys E6DC521D (This is a reproducible build file hash, not a timestamp)
fffff805`34d10000 fffff805`34d1a000 HWiNFO64A HWiNFO64A.SYS Tue Mar 31 05:51:32 2015 (551A6E24)
fffff805`34d20000 fffff805`34d2a000 gpuenergydrv gpuenergydrv.sys 0CC24294 (This is a reproducible build file hash, not a timestamp)
fffff805`34d30000 fffff805`34d5c000 dfsc dfsc.sys FABE3F7D (This is a reproducible build file hash, not a timestamp)
fffff805`34d60000 fffff805`34d75000 umbus umbus.sys 3104A4AD (This is a reproducible build file hash, not a timestamp)
fffff805`34d80000 fffff805`34deb000 fastfat fastfat.SYS 5D09ADAA (This is a reproducible build file hash, not a timestamp)
fffff805`34df0000 fffff805`34e06000 bam bam.sys 22198778 (This is a reproducible build file hash, not a timestamp)
fffff805`34e10000 fffff805`34e5f000 ahcache ahcache.sys A8473BE2 (This is a reproducible build file hash, not a timestamp)
fffff805`34e60000 fffff805`34eec000 Vid Vid.sys B7391632 (This is a reproducible build file hash, not a timestamp)
fffff805`34ef0000 fffff805`34f0f000 winhvr winhvr.sys 5EB9FF62 (This is a reproducible build file hash, not a timestamp)
fffff805`34f10000 fffff805`34f21000 CompositeBus CompositeBus.sys F050D616 (This is a reproducible build file hash, not a timestamp)
fffff805`34f30000 fffff805`34f3d000 kdnic kdnic.sys 1FF5F7F5 (This is a reproducible build file hash, not a timestamp)
fffff805`34f40000 fffff805`34f55000 CAD CAD.sys 56CE6ABF (This is a reproducible build file hash, not a timestamp)
fffff805`35ba0000 fffff805`35bd0000 cdrom cdrom.sys 9F6B0B7B (This is a reproducible build file hash, not a timestamp)
fffff805`35be0000 fffff805`35bf5000 filecrypt filecrypt.sys 4EAD73C1 (This is a reproducible build file hash, not a timestamp)
fffff805`36680000 fffff805`36cf3000 RTKVHD64 RTKVHD64.sys Tue Jan 8 06:52:12 2019 (5C348EEC)
fffff805`36d00000 fffff805`36d0f000 ksthunk ksthunk.sys 15502221 (This is a reproducible build file hash, not a timestamp)
fffff805`36d10000 fffff805`36da9000 IntcDAud IntcDAud.sys Tue Sep 4 05:00:26 2018 (5B8E49AA)
fffff805`36db0000 fffff805`36de3000 usbccgp usbccgp.sys 5D2AF1D1 (This is a reproducible build file hash, not a timestamp)
fffff805`36f80000 fffff805`3803a000 nvlddmkm nvlddmkm.sys Thu Jun 21 04:07:16 2018 (5B2B5CB4)
fffff805`38040000 fffff805`3804c000 swenum swenum.sys C4D73525 (This is a reproducible build file hash, not a timestamp)
fffff805`38050000 fffff805`3805d000 ssdevfactory ssdevfactory.sys Tue May 14 12:50:31 2019 (5CDAF1D7)
fffff805`38060000 fffff805`38076000 ViGEmBus ViGEmBus.sys Wed Oct 17 14:02:19 2018 (5BC7792B)
fffff805`38080000 fffff805`3808e000 rdpbus rdpbus.sys 4E9899F8 (This is a reproducible build file hash, not a timestamp)
fffff805`38090000 fffff805`380a0000 mouhid mouhid.sys A140C187 (This is a reproducible build file hash, not a timestamp)
fffff805`380b0000 fffff805`380bc000 MTConfig MTConfig.sys 91CD1C75 (This is a reproducible build file hash, not a timestamp)
fffff805`380c0000 fffff805`3815c000 UsbHub3 UsbHub3.sys D4267D67 (This is a reproducible build file hash, not a timestamp)
fffff805`38200000 fffff805`38288000 USBXHCI USBXHCI.SYS C566CB6A (This is a reproducible build file hash, not a timestamp)
fffff805`38290000 fffff805`382d1000 ucx01000 ucx01000.sys 04268533 (This is a reproducible build file hash, not a timestamp)
fffff805`382e0000 fffff805`38bee000 Netwtw08 Netwtw08.sys Wed Apr 24 07:16:22 2019 (5CC04586)
fffff805`38bf0000 fffff805`38cda000 wdiwifi wdiwifi.sys FA346E3D (This is a reproducible build file hash, not a timestamp)
fffff805`38ce0000 fffff805`38cee000 vwifibus vwifibus.sys 4F3B1CDE (This is a reproducible build file hash, not a timestamp)
fffff805`38cf0000 fffff805`38d2b000 TeeDriverW8x64 TeeDriverW8x64.sys Wed Apr 11 10:46:32 2018 (5ACE1FC8)
fffff805`38d30000 fffff805`38d59000 e2xw10x64 e2xw10x64.sys Thu Sep 20 01:10:32 2018 (5BA32BC8)
fffff805`38d60000 fffff805`38d83000 i8042prt i8042prt.sys E54F27F7 (This is a reproducible build file hash, not a timestamp)
fffff805`38d90000 fffff805`38d9b000 ssps2 ssps2.sys Tue May 14 12:50:28 2019 (5CDAF1D4)
fffff805`38da0000 fffff805`38e5f000 SynTP SynTP.sys Mon Sep 3 02:33:29 2018 (5B8CD5B9)
fffff805`38e60000 fffff805`38e6e000 USBD USBD.SYS CD63CE9D (This is a reproducible build file hash, not a timestamp)
fffff805`38e70000 fffff805`38e83000 HIDPARSE HIDPARSE.SYS 4105D214 (This is a reproducible build file hash, not a timestamp)
fffff805`38e90000 fffff805`38ea4000 kbdclass kbdclass.sys 0B474226 (This is a reproducible build file hash, not a timestamp)
fffff805`38eb0000 fffff805`38ec3000 mouclass mouclass.sys 4A22FFB8 (This is a reproducible build file hash, not a timestamp)
fffff805`38ed0000 fffff805`38edf000 Smb_driver_Intel Smb_driver_Intel.sys Fri Aug 17 13:42:41 2018 (5B770911)
fffff805`38ee0000 fffff805`38f1e000 intelppm intelppm.sys DF02127E (This is a reproducible build file hash, not a timestamp)
fffff805`38f20000 fffff805`38f2b000 acpipagr acpipagr.sys 80AB510E (This is a reproducible build file hash, not a timestamp)
fffff805`38f30000 fffff805`38f3f000 CmBatt CmBatt.sys 15AECFEB (This is a reproducible build file hash, not a timestamp)
fffff805`38f40000 fffff805`38f50000 BATTC BATTC.SYS 23D7DB85 (This is a reproducible build file hash, not a timestamp)
fffff805`38f60000 fffff805`38f6c000 wmiacpi wmiacpi.sys AF7EFCE5 (This is a reproducible build file hash, not a timestamp)
fffff805`38f70000 fffff805`38f92000 HDAudBus HDAudBus.sys AECD2958 (This is a reproducible build file hash, not a timestamp)
fffff805`38fa0000 fffff805`39007000 portcls portcls.sys D4F15BF0 (This is a reproducible build file hash, not a timestamp)
fffff805`39010000 fffff805`39031000 drmk drmk.sys ***** Invalid (A3E06FB0)
fffff805`39040000 fffff805`3904e000 UEFI UEFI.sys 60BAE916 (This is a reproducible build file hash, not a timestamp)
fffff805`39050000 fffff805`3905b000 mshidkmdf mshidkmdf.sys CD1AD421 (This is a reproducible build file hash, not a timestamp)
fffff805`39060000 fffff805`3909b000 HIDCLASS HIDCLASS.SYS D4D0DEE6 (This is a reproducible build file hash, not a timestamp)
fffff805`390a0000 fffff805`390ad000 NdisVirtualBus NdisVirtualBus.sys D217410A (This is a reproducible build file hash, not a timestamp)
fffff805`390b0000 fffff805`39f7a000 igdkmd64 igdkmd64.sys Wed Oct 31 16:22:14 2018 (5BDA0EF6)
fffff805`39f80000 fffff805`39ff8000 ks ks.sys D02EDE05 (This is a reproducible build file hash, not a timestamp)
fffff805`3ae00000 fffff805`3af63000 bthport bthport.sys EE6F2FBC (This is a reproducible build file hash, not a timestamp)
fffff805`3af70000 fffff805`3af82000 hidusb hidusb.sys 7B9189FE (This is a reproducible build file hash, not a timestamp)
fffff805`3afc0000 fffff805`3afce000 sshid sshid.sys Tue May 14 12:50:31 2019 (5CDAF1D7)
fffff805`3afd0000 fffff805`3afe1000 kbdhid kbdhid.sys 4CF68CA7 (This is a reproducible build file hash, not a timestamp)
fffff805`3aff0000 fffff805`3b00e000 Microsoft_Bluetooth_Legacy_LEEnumerator Microsoft.Bluetooth.Legacy.LEEnumerator.sys 8F924B7C (This is a reproducible build file hash, not a timestamp)
fffff805`3b010000 fffff805`3b04a000 rfcomm rfcomm.sys C18658F4 (This is a reproducible build file hash, not a timestamp)
fffff805`3b050000 fffff805`3b072000 BthEnum BthEnum.sys 1D20FC48 (This is a reproducible build file hash, not a timestamp)
fffff805`3b080000 fffff805`3b0a6000 bthpan bthpan.sys 20E20C9C (This is a reproducible build file hash, not a timestamp)
fffff805`3b0b0000 fffff805`3b0f0000 BthA2dp BthA2dp.sys 5583FA53 (This is a reproducible build file hash, not a timestamp)
fffff805`3b100000 fffff805`3b111000 btampm btampm.sys 97BF123B (This is a reproducible build file hash, not a timestamp)
fffff805`3b120000 fffff805`3b137000 Microsoft_Bluetooth_AvrcpTransport Microsoft.Bluetooth.AvrcpTransport.sys 482A0016 (This is a reproducible build file hash, not a timestamp)
fffff805`3b140000 fffff805`3b166000 bthhfenum bthhfenum.sys EF17FBF9 (This is a reproducible build file hash, not a timestamp)
fffff805`3b170000 fffff805`3b193000 hidbth hidbth.sys 78AC252F (This is a reproducible build file hash, not a timestamp)
fffff805`3b1a0000 fffff805`3b1b5000 BthHfAud BthHfAud.sys 4139196E (This is a reproducible build file hash, not a timestamp)
fffff805`3b1c0000 fffff805`3b23e000 mfeaack mfeaack.sys Tue Mar 5 22:58:50 2019 (5C7F457A)
fffff805`3b240000 fffff805`3b25f000 mfeplk mfeplk.sys Tue Mar 5 22:59:08 2019 (5C7F458C)
fffff805`3b260000 fffff805`3b2bd000 mfeavfk mfeavfk.sys Tue Mar 5 22:48:21 2019 (5C7F4305)
fffff805`3b2c0000 fffff805`3b340000 mfefirek mfefirek.sys Tue Mar 5 22:51:31 2019 (5C7F43C3)
fffff805`3b350000 fffff805`3b3dd000 mfencbdc mfencbdc.sys Fri Mar 1 09:06:38 2019 (5C793C6E)
fffff805`3b3f0000 fffff805`3b3fe000 dump_diskdump dump_diskdump.sys 5CC3D020 (This is a reproducible build file hash, not a timestamp)
fffff805`3b5a0000 fffff805`3c34b000 ibtusb ibtusb.sys Wed Apr 17 13:49:29 2019 (5CB76729)
fffff805`3c350000 fffff805`3c36f000 BTHUSB BTHUSB.sys 81C8EB86 (This is a reproducible build file hash, not a timestamp)
fffff805`7cc00000 fffff805`7ccd6000 peauth peauth.sys Wed Aug 24 06:52:50 1983 (19A9FB82)
fffff805`7cce0000 fffff805`7ccf4000 tcpipreg tcpipreg.sys 3451B629 (This is a reproducible build file hash, not a timestamp)
fffff805`7cd00000 fffff805`7cd0f000 ndistapi ndistapi.sys 690D0D05 (This is a reproducible build file hash, not a timestamp)
fffff805`7cd10000 fffff805`82648000 KfeCo10X64 KfeCo10X64.sys Tue Nov 20 11:27:17 2018 (5BF435E5)
fffff805`82650000 fffff805`826a2000 srvnet srvnet.sys 5F4A3694 (This is a reproducible build file hash, not a timestamp)
fffff805`826b0000 fffff805`826c4000 mmcss mmcss.sys 3EE4136D (This is a reproducible build file hash, not a timestamp)
fffff805`826d0000 fffff805`82722000 mrxsmb10 mrxsmb10.sys 5DDA4A77 (This is a reproducible build file hash, not a timestamp)
fffff805`82730000 fffff805`82757000 Ndu Ndu.sys 23725908 (This is a reproducible build file hash, not a timestamp)
fffff805`82760000 fffff805`8277d000 rassstp rassstp.sys 6EC6A1E5 (This is a reproducible build file hash, not a timestamp)
fffff805`82780000 fffff805`827c0000 NDProxy NDProxy.sys 1E12D3FF (This is a reproducible build file hash, not a timestamp)
fffff805`827d0000 fffff805`827f7000 AgileVpn AgileVpn.sys A96AFF6D (This is a reproducible build file hash, not a timestamp)
Unloaded modules:
fffff805`17b10000 fffff805`17b48000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`17ab0000 fffff805`17ae8000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`17a70000 fffff805`17aa8000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`17a30000 fffff805`17a68000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`179f0000 fffff805`17a28000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`179b0000 fffff805`179e8000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`17970000 fffff805`179a8000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`178c0000 fffff805`178f8000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`17c00000 fffff805`17c38000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`17bc0000 fffff805`17bf8000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`17b80000 fffff805`17bb8000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
fffff805`17b20000 fffff805`17b58000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`17b10000 fffff805`17b1f000 hiber_storpo
Checksum: 00000000
ImageSize: 0000F000
fffff805`83770000 fffff805`84316000 hiber_iaStor
Checksum: 00000000
ImageSize: 00BA6000
fffff805`84320000 fffff805`8433e000 hiber_dumpfv
Checksum: 00000000
ImageSize: 0001E000
fffff805`17910000 fffff805`17924000 vwifimp.sys
Checksum: 00000000
ImageSize: 00014000
fffff805`17af0000 fffff805`17afe000 WSDPrint.sys
Checksum: 00000000
ImageSize: 0000E000
fffff805`17950000 fffff805`1795e000 WSDPrint.sys
Checksum: 00000000
ImageSize: 0000E000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
fffff805`17bf0000 fffff805`17c28000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`17bb0000 fffff805`17be8000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`17b70000 fffff805`17ba8000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`17b30000 fffff805`17b68000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
fffff805`17af0000 fffff805`17b28000 nvhda64v.sys
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Unloaded modules:
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 0000F000
Checksum: 00000000
ImageSize: 00BA6000
Checksum: 00000000
ImageSize: 0001E000
Checksum: 00000000
ImageSize: 00014000
Checksum: 00000000
ImageSize: 0000E000
Checksum: 00000000
ImageSize: 0000E000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Checksum: 00000000
ImageSize: 00038000
Bugcheck code 0000001A
Arguments 00000000`00041792 ffff9a3e`fa490d40 00000010`04000000 00000000`00000000
