We could have got more information about the registry key, by doing a !reg findkcb with the full path of the registry key, and then using the !reg kcb with the address provided by the !reg findkcb extension. I've demonstrated it in my latest blog post.
I'm Sorry but I'm too Scared now is it a bad problem ? in a hardware or what u mean as I don't know when I used those registrys
Don't worry, I was just indicating to the others, that the nVidia graphics card driver might have a common bug. It may even have been fixed in the Beta version.
Networking isn't my area of expertise, but you may want to read this article to get an understanding of the error - Windows 7 Network Awareness: How Windows knows it has an internet connection « Super User Blog
The third error is related to a program called ASUS Disk Unlocker, please open up MSCONFIG, and then go to the Startup tab.
How to open MSCONFIG:
Start >> Type: msconfig into the Search box >> Select Startup >> Check to see if ASUS Disk Unlocker is present.
Did you remove the Disk Unlocker program?
I would also check for any corrupt or missing files with the System File Checker. Instructions are available in the link.
[TD="class: small"][/TD]
Download the free trail of Revo, and then see if it's able to remove any leftover traces of the program - Revo Uninstaller Pro - Uninstall Software, Remove Programs easily, Forced Uninstall, Leftovers Uninstaller
Do not run Reginout, it's a registry cleaner, and these programs do more harm than good.
Dear, but when i had faced this problem so i scanned my PC with Reginout, now my PC performance is better then before. Yes, i agree with you that some registry cleaner are harmful for PC, but that cleaner are free. That's why i don't believe on free products. Thanks
Really Usefully App, Thanks So much X BlueRobot for your Completely Help :)
