BSOD - please help
Hi, few things to go through here.
Two attached dumps are of the FE: BUGCODE_USB_DRIVER bugcheck - The first paramter is 0x5, as we can see here:
Arg1: 0000000000000005, USBBUGCODE_INVALID_PHYSICAL_ADDRESS [B]The host controller is
    using a physical memory address that was not allocated by
    the USBport driver.[/B]
Right off the bat, FE bugcheck usual causes are: USB hardware (motherboard or attachments) or the USB device driver has a bug. We can possibly rule out the chipset or USB drivers themselves being the issue as you've already navigated to Lenovo's website and ensured you had the latest drivers. We can also rule out any devices connected via USB as the only device you have connected is the M & K, correct? Do you normally attach any other device via USB, or have you previously at a time?
Ultimately, usbehci.sys is the culprit, which is a Windows component / driver. Something else, whether it's a device or driver (or hardware), is faulting it.
You can give disabling and re-enabling the USB controller(s) in DevMan a try, this will allow the drivers to recover the controller(s) from their unresponsive state. The USB controllers represent the USB ports in DevMan:
start > search > device manager
a. Click Start, type device manager in the Start search box and hit Enter.
b. Expand Universal Serial Bus controllers.
Note: You might have to scroll down the list to find this item.
c. Right-click the first USB controller under Universal Serial Bus controllers, and then click Uninstall to remove it.
d. Repeat the above step for each USB controller that is listed under Universal Serial Bus controllers.
e. Restart the computer. After the computer starts, Windows will automatically scan for hardware changes and reinstall all the USB controllers that you uninstalled.
f. Check the USB device to see whether it is working.
As the usual cases state as well, it's possible this is a board issue as well, or even a hub / port issue. It's not uncommon for a port to give out, it's happened on previous systems I have owned. It happens sometimes over time. Are there any other USB ports you can try and connect your devices to, to rule out a specific port issue?
Drivers that need to be updated:
NCREMOTEPCI.SYS - Mon Sep 11 16:47:50 2006 (Technisat digital satellite driver). Update if available here.
regi.sys - Mon Apr 16 11:19:10 2007 (InterVideo regi.sys driver). Update if available here.
PQAWDrv.sys - Thu Feb 28 21:09:31 2008 (PowerQuest BootMode Driver). Not sure where to update this.... the website (www.powerquest.com) redirects to Norton's website? I'll have to have someone chime in on this, like John C with his expert Googling skills :lol:
DDCDrv.sys - Tue Apr 08 03:50:11 2008 (WINI2C-DDC Kernel Mode Driver). Update if available here.
Regards,
Patrick
