BSOD Randomnly can't fix with SFC
Status
Not open for further replies.
Thanks, why couldn't the MBAM removal tool load out of interest?
FRST Fix
1. Download the attached fixlist.txt and save it to the Desktop.
FRST Fix
I tried to run FRST64 but it's freezing on creating restore point , i just see one green box and nothing more. What should i do ? Thank you
Update i open the fixlist file and remove the creating restore point value and FRST64 did run this time, that is the log . It could not create a restore point, i checked and i cant create restore point not even manually , is searching for drive without find one .
Do you have System Restore enabled? Nevertheless, please run DISM again and then upload the CBS logs if it fails.
Hi , i run DISM again and this time it worked fine , after that run SFC and it found corrupted files and fixed them successfully. now i just receive message from antivirus that says it's off , please check the attached picture, i click on the message but i cant activate the antivirus, please check second picture. What should i do ? One more issue is that windows update it's not working , i have an update the KB5033372 but installing is at 0% since long time and i tried to install it manually as well but without success thank you
Please open an elevated command prompt and then enter the following command:
reg query "HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows Defender" /s >> %userprofile%\Desktop\policies.txt
Please attach the policies.txt file to your next post. In addition to that, please also provide the latest CBS logs as you've done before.
this are the files . Thank you
This machine isn't connected to some domain is it or a corporate machine?
Could you please provide the latest copy of your COMPONENTS hive along with the SideBySide (SxS) subkey which must be saved as a .hiv file.
Retrieve Components Hive
4. The file will likely be too large to upload here so please upload to a file sharing service. Examples of services to upload to are Dropbox or OneDrive or WeTransfer and then just provide the link in your reply.
Export SideBySide
  5. Change the Save as type: to Registry Hive Files (.)
  6. Name this file SxS (with no file extension) and save it to your Desktop.
Once done please upload this file via Dropbox or OneDrive or WeTransfer.
Export SideBySide
As far as i know is a private machine , it's not mine is from a friend that asked me to remove a trojan.
This are the log files Thank you
COMPONENTS.zip
SxS
Install Update with DISM
  1. Download the update MSU here: windows10.0-kb5033372-x64_822cb06e298fd32637584b623f2cdaa3468f42a1.msu
  2. Copy the .msu file to a convenient location (such as %userprofile%\Desktop).
    cd %userprofile%\Desktop
    replace %userprofile%\Desktop with your path if different
    expand windows10.0-kb5033372-x64_822cb06e298fd32637584b623f2cdaa3468f42a1.msu -f:* %userprofile%\Desktop
    DISM /Online /Add-Package /PackagePath:%userprofile%\Desktop\windows10.0-kb5033372-x64.cab
    Post a screenshot of the Command Prompt window.
    Zip and attach the file %systemroot%\Logs\CBS\CBS.log
If it doesn't work, then we can look at addressing the problem in a different way.
Maybe the trojan change things around ?!
I doubt that, I should imagine that you still have remnants of MBAM on your system but you never explained why the removal tool wasn't able to loaded?
I don't know why it didn't work, double clicked on it but nothing happened
Did you right-click and run the removal tool as an administrator? I would check that you have a version of .NET framework installed which is at least 4.0
You can check using: Determine which .NET Framework versions are installed - .NET Framework
Let me know how the update goes with DISM.
before the dism repair the removal tool for Malwarebytes didnt work even with right click and run as admin i just tried again and this time worked and i run it and clean.
after i try to update with DISM but after 40 minutes still on the same state as you can see from my screen shot.
before that i had 3 more BSOD , i checked the framework version, you can see on the attachment files
Update, i left it over night and DISM fail with this error , i post the screen shot and the new CBS log thank you
  • CBS.zip
    CBS.zip
i am using it and it did crashes already after i removed it 2 times :( i tried again DISM but no success, can't find source files...
This thread has now been locked, if you're having a similar issue then please create a thread of your own.
Status
