[SOLVED] CBS Catalog Missing Package_****_for_KB4537764
It seems this file is still corrupt, it is only 45 bytes. Please run the following DISM command, post the result and attach a new copy of the CBS log.
The restore operation was completed successfully.
The process was completed successfully.
cbs.log is attached
(w)	CBS Package Index Package Missing	0x80070490	Package_5898_for_KB4537764~31bf3856ad364e35~amd64~~0.0.0.0	Package_5898_for_KB4537764~31bf3856ad364e35~amd64~~10.0.1.3
(w)	CBS Package Index Package Missing	0x80070490	Package_6223_for_KB4537764~31bf3856ad364e35~amd64~~0.0.0.0	Package_6223_for_KB4537764~31bf3856ad364e35~amd64~~10.0.1.3
(w)	CBS Package Index Package Missing	0x80070490	Package_6575_for_KB4537764~31bf3856ad364e35~amd64~~0.0.0.0	Package_6575_for_KB4537764~31bf3856ad364e35~amd64~~10.0.1.3
(w)	CBS Package Index Package Missing	0x80070490	Package_6681_for_KB4537764~31bf3856ad364e35~amd64~~0.0.0.0	Package_6681_for_KB4537764~31bf3856ad364e35~amd64~~10.0.1.3
(w)	CBS Package Index Package Missing	0x80070490	Package_6826_for_KB4537764~31bf3856ad364e35~amd64~~0.0.0.0	Package_6826_for_KB4537764~31bf3856ad364e35~amd64~~10.0.1.3
(w)	CBS Package Index Package Missing	0x80070490	Package_7028_for_KB4537764~31bf3856ad364e35~amd64~~0.0.0.0	Package_7028_for_KB4537764~31bf3856ad364e35~amd64~~10.0.1.3
(w)	CBS Package Index Package Missing	0x80070490	Package_8316_for_KB4537764~31bf3856ad364e35~amd64~~0.0.0.0	Package_8316_for_KB4537764~31bf3856ad364e35~amd64~~10.0.1.3
(w)	CBS Package Index Package Missing	0x80070490	Package_8388_for_KB4537764~31bf3856ad364e35~amd64~~0.0.0.0	Package_8388_for_KB4537764~31bf3856ad364e35~amd64~~10.0.1.3
(w)	CBS Package Index Package Missing	0x80070490	Package_8994_for_KB4537764~31bf3856ad364e35~amd64~~0.0.0.0	Package_8994_for_KB4537764~31bf3856ad364e35~amd64~~10.0.1.3
The latest CBS log looks good, there are only some warnings, let's remove them as well so they don't appear in the future after running DISM.
Start the
  • Press the Fix button.
You're welcome. If everything is up and running, then we can mark this thread as solved... (y)
