[SOLVED] CBS MUM Missing
Start time: 2018-12-23 14:12:01.826
Using .txt script file at C:\Users\XYZ\Desktop\SFCFixScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\d577f1f5b4cc94dc317ce2b8dbc89cb1ebb231c59317c15349b4490fd774a5a1.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\2027addeb0a..2fd79aec23f_6595b64144ccf1df_1.0.7601.24234_df17abedf27a60c0.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\d577f1f5b4cc94dc317ce2b8dbc89cb1ebb231c59317c15349b4490fd774a5a1.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_2027addeb0ad22d162fbf2fd79aec23f_6595b64144ccf1df_1.0.7601.24234_none_df17abedf27a60c0.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\2027addeb0a..2fd79aec23f_6595b64144ccf1df_1.0.7601.24234_df17abedf27a60c0.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\d577f1f5b4cc94dc317ce2b8dbc89cb1ebb231c59317c15349b4490fd774a5a1.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_2027addeb0ad22d162fbf2fd79aec23f_6595b64144ccf1df_1.0.7601.24234_none_df17abedf27a60c0.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
Currently storing 927 datablocks.
Finish time: 2018-12-23 14:12:02.151
Script hash: Un+5zh15v4eMCZ1p8RJ5XFPkJykFflw4vu1XI0sIc+w=
CBS.log - https://mega.nz/#!aHRByaoa!9g1r09T7_TxyOzE_O0xYH1jYJQoeFrZL2Q3IXvIGaJU
If it fails, run sfc /scannow again and attach the zipped cbs.log to your next reply.
Start time: 2018-12-23 17:27:52.104
RegistryScript::
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\b492d65ba61..658394b3422_31bf3856ad364e35_6.1.7601.24204_f1aa417124bef177.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_b492d65ba61cbe416ed32658394b3422_31bf3856ad364e35_6.1.7601.24204_none_f1aa417124bef177.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\b492d65ba61..658394b3422_31bf3856ad364e35_6.1.7601.24204_f1aa417124bef177.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_b492d65ba61cbe416ed32658394b3422_31bf3856ad364e35_6.1.7601.24204_none_f1aa417124bef177.
Currently storing 929 datablocks.
Finish time: 2018-12-23 17:27:52.465
Script hash: gxyVnauFtoZu9XH2VKgGKiUAKDXEWJ/xbwCmfgYyfZU=
CBS.log - https://mega.nz/#!aeBXVAAb!cUrWkySri1vyjgXpxyLQjBFRfIy8x188cCvUQa8qUpY
Start time: 2018-12-23 20:51:00.065
Using .txt script file at C:\Users\XYZ\Desktop\SFCFixScript.txt [2]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\14f934fa032..7d9e4c9d6a1_31bf3856ad364e35_6.1.7601.24234_14b73d00e182c4d8.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_14f934fa032c76b5ec2ce7d9e4c9d6a1_31bf3856ad364e35_6.1.7601.24234_none_14b73d00e182c4d8.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\14f934fa032..7d9e4c9d6a1_31bf3856ad364e35_6.1.7601.24234_14b73d00e182c4d8.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_14f934fa032c76b5ec2ce7d9e4c9d6a1_31bf3856ad364e35_6.1.7601.24234_none_14b73d00e182c4d8.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\14f934fa032..7d9e4c9d6a1_31bf3856ad364e35_6.1.7601.24234_14b73d00e182c4d8.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_14f934fa032c76b5ec2ce7d9e4c9d6a1_31bf3856ad364e35_6.1.7601.24234_none_14b73d00e182c4d8.
Trace::
Failed to trace component diskmgt.CHM with return code 1 and conditional return code ERROR_FILE_NOT_FOUND.
Currently storing 931 datablocks.
Finish time: 2018-12-23 20:51:00.434
Script hash: IqWhyOCSW41Kmz+USIEI5gEelcqWqoqhLebGlM20x20=
CBS.log - https://mega.nz/#!aG4iFKiS!2w7ZeyousqLVvr1PetPhqkvF_ZgNegz6maE7M1eylsI
SFCFix version 3.0.1.0 by niemiro.
Start time: 2018-12-27 12:42:42.917
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\20bdc2fd55d7869319f4b18c0269a13dc38785cb427736c815d668f117371fab.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\45b4e4d2e00..13d0fed91df_31bf3856ad364e35_6.1.7601.24231_93af4b037ecbaaf2.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\20bdc2fd55d7869319f4b18c0269a13dc38785cb427736c815d668f117371fab.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_45b4e4d2e00f0e5a2581513d0fed91df_31bf3856ad364e35_6.1.7601.24231_none_93af4b037ecbaaf2.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\45b4e4d2e00..13d0fed91df_31bf3856ad364e35_6.1.7601.24231_93af4b037ecbaaf2.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\20bdc2fd55d7869319f4b18c0269a13dc38785cb427736c815d668f117371fab.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_45b4e4d2e00f0e5a2581513d0fed91df_31bf3856ad364e35_6.1.7601.24231_none_93af4b037ecbaaf2.
SFCFix version 3.0.1.0 by niemiro has completed.
Currently storing 934 datablocks.
Finish time: 2018-12-27 12:42:43.334
Script hash: ZCFzoEqg1N/1pDZ3uBrq6fcGCjptwPTmS4NgxkbVD6Q=
CBS.log - https://mega.nz/#!GHoQyY7D!_NtAj4YT75-Sv3KsvafR1vRzBDT5kuDnA5v4gqCDQK4
Start time: 2018-12-27 21:34:42.761
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\d8424a6acfc..7e536ae6383_31bf3856ad364e35_6.1.7601.24231_651d9b991bcf9ce1.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\6ac5751cdf0fee057f12fe03f7390f00afbb5be64f8a2c3a6fbb8cec649adfe3.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_d8424a6acfcd2976e5ecc7e536ae6383_31bf3856ad364e35_6.1.7601.24231_none_651d9b991bcf9ce1.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\d8424a6acfc..7e536ae6383_31bf3856ad364e35_6.1.7601.24231_651d9b991bcf9ce1.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\6ac5751cdf0fee057f12fe03f7390f00afbb5be64f8a2c3a6fbb8cec649adfe3.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_d8424a6acfcd2976e5ecc7e536ae6383_31bf3856ad364e35_6.1.7601.24231_none_651d9b991bcf9ce1.
Currently storing 937 datablocks.
Finish time: 2018-12-27 21:34:43.796
Script hash: 0SpWXg3NHv1dSc5dGKaVoCFxmuppu44Z3WWiLOruSfU=
CBS.log - https://mega.nz/#!POpjlISb!KH99fVGq0V6lNhFLr0uB6BVyl41PCwKC37lKWMHiG88
Start time: 2018-12-28 14:11:50.135
Using .txt script file at C:\Users\XYZ\Desktop\SFCFixScript.txt [3]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\523b4cb207a..ad5e60bb410_31bf3856ad364e35_6.1.7601.24231_7938b27804106f38.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\17af543b2dfb8f45d027dc0b73b1ca1f59fe20950c04ff63188460c807683a71.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_523b4cb207a6aa5c38e07ad5e60bb410_31bf3856ad364e35_6.1.7601.24231_none_7938b27804106f38.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\523b4cb207a..ad5e60bb410_31bf3856ad364e35_6.1.7601.24231_7938b27804106f38.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\17af543b2dfb8f45d027dc0b73b1ca1f59fe20950c04ff63188460c807683a71.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_523b4cb207a6aa5c38e07ad5e60bb410_31bf3856ad364e35_6.1.7601.24231_none_7938b27804106f38.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\523b4cb207a..ad5e60bb410_31bf3856ad364e35_6.1.7601.24231_7938b27804106f38.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\17af543b2dfb8f45d027dc0b73b1ca1f59fe20950c04ff63188460c807683a71.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_523b4cb207a6aa5c38e07ad5e60bb410_31bf3856ad364e35_6.1.7601.24231_none_7938b27804106f38.
Currently storing 940 datablocks.
Finish time: 2018-12-28 14:11:50.614
Script hash: tbPFUzrW5dpBHGlcu6HVT4DLEzJsJx24MFTx2d0eV2A=
CBS.log - https://mega.nz/#!yPhUnIAZ!B7JTht5kllBME3xuVMrb7IuVp3Fg-FG8hIItozfoxR8
Start time: 2018-12-29 12:05:55.284
RegistryScript::
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\83571cdf627..66936d68032_31bf3856ad364e35_6.1.7601.24231_5429ed2d4c7dd6ab.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\3263a57990606c7decd5b89574994bc81899242f10366441cd4ba7046cd7f0c5.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_83571cdf6272c847d0e2966936d68032_31bf3856ad364e35_6.1.7601.24231_none_5429ed2d4c7dd6ab.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\83571cdf627..66936d68032_31bf3856ad364e35_6.1.7601.24231_5429ed2d4c7dd6ab.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\3263a57990606c7decd5b89574994bc81899242f10366441cd4ba7046cd7f0c5.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_83571cdf6272c847d0e2966936d68032_31bf3856ad364e35_6.1.7601.24231_none_5429ed2d4c7dd6ab.
Currently storing 943 datablocks.
Finish time: 2018-12-29 12:05:55.717
Script hash: NEjoasqS7bxxD4i3oZARCErkNb7uXXl5bGsbO5969XI=
CBS.log - https://mega.nz/#!nfYxkYCS!m_gRKMzAxpE9QDPH3H-KvJW60GEczGxEnxvZkR88k4Y
Start time: 2018-12-29 15:44:57.222
RegistryScript::
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\61e05e12761..ca71fb4106c_31bf3856ad364e35_6.1.7601.24231_e174f74142d00327.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\72a44e2c30689521479ee5aa56ad804111ff5928cde4879c1d953492ba85abe6.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_61e05e127612494c8bfc1ca71fb4106c_31bf3856ad364e35_6.1.7601.24231_none_e174f74142d00327.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\61e05e12761..ca71fb4106c_31bf3856ad364e35_6.1.7601.24231_e174f74142d00327.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\72a44e2c30689521479ee5aa56ad804111ff5928cde4879c1d953492ba85abe6.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_61e05e127612494c8bfc1ca71fb4106c_31bf3856ad364e35_6.1.7601.24231_none_e174f74142d00327.
Currently storing 946 datablocks.
Finish time: 2018-12-29 15:44:58.237
Script hash: hb/Z8lDIe/F5wKIxCYhCaHI0AG7esdGCcSQdqzeKxtQ=
CBS.log - https://mega.nz/#!zaA1wKQS!B5OPo7cq6kZGNZFqN2if6hlN3IV4NIWWedsxesmB42c
Start time: 2018-12-29 20:18:55.541
RegistryScript::
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5003febd569..db899a06968_31bf3856ad364e35_6.1.7601.24241_15eab82817c16c56.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\23b6322b48dda1b39a1860ff7cf0b763dda62206455fbefc9a95aab69f7813df.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_5003febd569d7058f4020db899a06968_31bf3856ad364e35_6.1.7601.24241_none_15eab82817c16c56.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\5003febd569..db899a06968_31bf3856ad364e35_6.1.7601.24241_15eab82817c16c56.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Catalogs\23b6322b48dda1b39a1860ff7cf0b763dda62206455fbefc9a95aab69f7813df.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_5003febd569d7058f4020db899a06968_31bf3856ad364e35_6.1.7601.24241_none_15eab82817c16c56.
Currently storing 949 datablocks.
Finish time: 2018-12-29 20:18:55.918
Script hash: P6DzU8BYuO25wefm1jCMtefDVOChc7GQw9NXmQn0+Tg=
CBS.log - https://mega.nz/#!CKohGQJS!3EDOB7zk_P9B1FIfLk4NwN6XGpCuhegFKGLsoLXHxt8
