Class 101 for 0x101 Bugchecks
Vir Gnarus - I think he is referring to these two posts by you and Richard (niemiro) -
Thanks a lot for this very informative post.
I have a user with this kernel dump: MEMORY.zip
It looks almost identical to the one you showed here, and I wondered whether you could think of anything other than hardware? I guess I will ask to update chipset drivers, and see if that does it. A bit desperate, I know.
Also, the OP claims that the computer works fine in Safe Mode, but crashes in normal mode. Finally, I notice that this computer seems to have 8 cores. That seems like quite a few. Do you think this may even be a multi-processor machine, perhaps even a small server? I will ask the OP.
Thanks a lot for any insight you may be able to offer.
Microsoft (R) Windows Debugger Version 6.2.8229.0 AMD64
Loading Dump File [D:\MEMORY (2).DMP]
Kernel Summary Dump File: Only kernel address space is available
Symbol search path is: SRV*D:\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (8 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS Personal
Built by: 6002.18607.amd64fre.vistasp2_gdr.120402-0336
Machine Name:
Kernel base = 0xfffff800`03003000 PsLoadedModuleList = 0xfffff800`031c7dd0
Debug session time: Sun Jun 24 14:10:20.781 2012 (UTC + 1:00)
System Uptime: 0 days 0:01:39.562
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck 101, {18, 0, fffffa60019d8180, 3}
*** ERROR: Module load completed but symbols could not be loaded for intelppm.sys
Probably caused by : Unknown_Image ( ANALYSIS_INCONCLUSIVE )
Followup: MachineOwner
0: kd> !analyze -v
CLOCK_WATCHDOG_TIMEOUT (101)
An expected clock interrupt was not received on a secondary processor in an
MP system within the allocated interval. This indicates that the specified
processor is hung and not processing interrupts.
Arguments:
Arg1: 0000000000000018, Clock interrupt time out interval in nominal clock ticks.
Arg2: 0000000000000000, 0.
Arg3: fffffa60019d8180, The PRCB address of the hung processor.
Arg4: 0000000000000003, 0.
Debugging Details:
BUGCHECK_STR:  CLOCK_WATCHDOG_TIMEOUT_8_PROC
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
PROCESS_NAME:  System
CURRENT_IRQL:  d
STACK_TEXT:
fffff800`04416a98 fffff800`030193a0 : 00000000`00000101 00000000`00000018 00000000`00000000 fffffa60`019d8180 : nt!KeBugCheckEx
fffff800`04416aa0 fffff800`030543aa : 00000000`00000000  fffff800`04416bc0 fffffa80`08765330 fffff800`03548320 : nt! ??  ::FNODOBFM::`string'+0x2de4
fffff800`04416ae0 fffff800`0352b8af : 00000000`00000000  fffff800`04416bc0 fffff800`03548320 fffffa80`08d91170 :  nt!KeUpdateSystemTime+0xea
fffff800`04416b10 fffff800`03053b6d : 00000000`00000000  fffff800`03548320 00000000`00000000 fffffa60`0390b6d6 :  hal!HalpRtcClockInterrupt+0x127
fffff800`04416b40 fffffa60`00d407a2 : fffffa60`00d3f685  fffff800`04410000 00000000`00000000 00000000`00000001 :  nt!KiInterruptDispatchNoLock+0x14d
fffff800`04416cd8 fffffa60`00d3f685 : fffff800`04410000 00000000`00000000 00000000`00000001 00000000`0000000c : intelppm+0x37a2
fffff800`04416ce0 fffff800`0305f173 : 0000003d`d5f3b80e 00000000`00000000 fffffa80`00000001 fffff800`03179a80 : intelppm+0x2685
fffff800`04416d10 fffff800`0305ee91 : fffff800`03176680 fffff800`00000000 00000000`0f088bae 00000000`00000000 : nt!PoIdle+0x183
fffff800`04416d80 fffff800`0322e860 : 00000000`00000000  00000000`00000000 00000000`00000000 00000000`00000000 :  nt!KiIdleLoop+0x21
fffff800`04416db0 00000000`fffff800 : 00000000`00000000  00000000`00000000 00000000`00000000 00000000`00000000 :  nt!zzz_AsmCodeRange_End+0x4
fffff800`044100b0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00680000`00000000 : 0xfffff800
STACK_COMMAND:  kb
SYMBOL_NAME:  ANALYSIS_INCONCLUSIVE
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: Unknown_Module
IMAGE_NAME:  Unknown_Image
DEBUG_FLR_IMAGE_TIMESTAMP:  0
FAILURE_BUCKET_ID:  X64_CLOCK_WATCHDOG_TIMEOUT_8_PROC_ANALYSIS_INCONCLUSIVE
0: kd> !prcb 0
PRCB for Processor 0 at fffff80003176680:
Current IRQL -- 13
Threads--  Current fffff8000317bb80 Next 0000000000000000 Idle fffff8000317bb80
Number 0 SetMember 1
Interrupt Count -- 0001471f
Times -- Dpc    000000bc Interrupt 00000018
         Kernel 000018ab User      00000000
0: kd> !prcb 1
PRCB for Processor 1 at fffffa60005ec180:
Current IRQL -- 0
Threads--  Current fffffa60005f5d40 Next 0000000000000000 Idle fffffa60005f5d40
Number 1 SetMember 2
Interrupt Count -- 0000c511
Times -- Dpc    00000000 Interrupt 00000000
         Kernel 0000189a User      00000000
0: kd> !prcb 2
PRCB for Processor 2 at fffffa6001966180:
Current IRQL -- 0
Threads--  Current fffffa600196fd40 Next fffffa80054d7bb0 Idle fffffa600196fd40
Number 2 SetMember 4
Interrupt Count -- 0000bc7e
Times -- Dpc    00000015 Interrupt 00000000
         Kernel 000012ec User      00000000
0: kd> !prcb 3
PRCB for Processor 3 at fffffa60019d8180:
Current IRQL -- 0
Threads--  Current fffffa8009df3bb0 Next 0000000000000000 Idle fffffa60019e1d40
Number 3 SetMember 8
Interrupt Count -- 0000bf6c
Times -- Dpc    00000001 Interrupt 00000002
         Kernel 000012d2 User      00000000
0: kd> !prcb 4
PRCB for Processor 4 at fffffa6001a43180:
Current IRQL -- 0
Threads--  Current fffffa80054e6210 Next 0000000000000000 Idle fffffa6001a4cd40
Number 4 SetMember 10
Interrupt Count -- 0000939e
         Kernel 00001897 User      00000000
0: kd> !prcb 5
PRCB for Processor 5 at fffffa6001ab5180:
Current IRQL -- 0
Threads--  Current fffffa6001abed40 Next 0000000000000000 Idle fffffa6001abed40
Number 5 SetMember 20
Interrupt Count -- 000091dc
Times -- Dpc    00000000 Interrupt 00000010
         Kernel 00001895 User      00000000
0: kd> !prcb 6
PRCB for Processor 6 at fffffa6001b27180:
Current IRQL -- 0
Threads--  Current fffffa80054eebb0 Next 0000000000000000 Idle fffffa6001b30d40
Number 6 SetMember 40
Interrupt Count -- 0000bdf3
Times -- Dpc    00000001 Interrupt 00000004
         Kernel 00001155 User      00000000
0: kd> !prcb 7
PRCB for Processor 7 at fffffa6001b99180:
Current IRQL -- 0
Threads--  Current fffffa80069e6bb0 Next 0000000000000000 Idle fffffa6001ba2d40
Number 7 SetMember 80
Interrupt Count -- 0000bff6
Times -- Dpc    00000000 Interrupt 00000001
         Kernel 0000114e User      00000000
0: kd> !prcb 8
Cannot get PRCB address
0: kd> !irql 0
Debugger saved IRQL for processor 0x0 -- 13
0: kd> !irql 1
Debugger saved IRQL for processor 0x1 -- 0 (LOW_LEVEL)
0: kd> !irql 2
Debugger saved IRQL for processor 0x2 -- 0 (LOW_LEVEL)
0: kd> !irql 3
Debugger saved IRQL for processor 0x3 -- 0 (LOW_LEVEL)
0: kd> !irql 4
Debugger saved IRQL for processor 0x4 -- 0 (LOW_LEVEL)
0: kd> !irql 5
Debugger saved IRQL for processor 0x5 -- 0 (LOW_LEVEL)
0: kd> !irql 6
Debugger saved IRQL for processor 0x6 -- 0 (LOW_LEVEL)
0: kd> !irql 7
Debugger saved IRQL for processor 0x7 -- 0 (LOW_LEVEL)
0: kd> ~0
0: kd> kv
Child-SP          RetAddr           : Args to Child                                                           : Call Site
fffff800`04416b40 [COLOR=#ff0000][B]fffffa60`00d407a2[/B][/COLOR]  : fffffa60`00d3f685 fffff800`04410000 00000000`00000000  00000000`00000001 : nt!KiInterruptDispatchNoLock+0x14d (TrapFrame @  fffff800`04416b40)
fffff800`04416cd8 [B][COLOR=#0000ff]fffffa60`00d3f685[/COLOR][/B] : fffff800`04410000 00000000`00000000 00000000`00000001 00000000`0000000c : intelppm+0x37a2
0: kd> ~1
1: kd> kv
fffffa60`0191bcd8 fffffa60`00d3f685 : fffffa80`054d7720 fffffa60`005f5d40 fffffa60`00000001 fffffa60`0191bd50 : intelppm+0x37a2
fffffa60`0191bce0 fffff800`0305f173 : 00000000`00000001 fffffa80`054d7818 fffffa80`054d7720 fffffa60`005f5d40 : intelppm+0x2685
fffffa60`0191bd10 fffff800`0305ee91 : fffffa60`005ec180 fffffa60`00000000 00000000`0f096483 00000000`00000000 : nt!PoIdle+0x183
fffffa60`0191bd80 fffff800`0322e860 : 00000000`00000000  00000000`00000000 00000000`00000000 00000000`00000000 :  nt!KiIdleLoop+0x21
fffffa60`0191bdb0 00000000`fffffa60 : 00000000`00000000  00000000`00000000 00000000`00000000 00000000`00000000 :  nt!zzz_AsmCodeRange_End+0x4
fffffa60`005efd00 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00680000`00000000 : 0xfffffa60
1: kd> uf [B][COLOR=#ff0000]fffffa60`00d407a2[/COLOR][/B]
intelppm+0x37a0:
fffffa60`00d407a0 fb              sti
fffffa60`00d407a1 f4              hlt
fffffa60`00d407a2 c3              ret
1: kd> uf [B][COLOR=#0000ff]fffffa60`00d3f685[/COLOR][/B]
intelppm+0x267c:
fffffa60`00d3f67c 4883ec28        sub     rsp,28h
fffffa60`00d3f680 e81b110000      call    intelppm+0x37a0 (fffffa60`00d407a0)
fffffa60`00d3f685 33c0            xor     eax,eax
fffffa60`00d3f687 4883c428        add     rsp,28h
fffffa60`00d3f68b c3              ret
1: kd> ~3
3: kd> r if
if=1
3: kd> !thread
THREAD fffffa8009df3bb0  Cid 0234.0238  Teb: 000007fffffdd000 Win32Thread: fffff900c0004d50 RUNNING on processor 3
Not impersonating
DeviceMap                 fffff880000073d0
Owning Process            fffffa8009e03040       Image:         csrss.exe
Attached Process          N/A            Image:         N/A
Wait Start TickCount      5915           Ticks: 457 (0:00:00:07.140)
Context Switch Count      140            IdealProcessor: 3                 LargeStack
UserTime                  00:00:00.000
KernelTime                00:00:00.468
Win32 Start Address 0x0000000049d6153c
Stack Init fffffa600569cdb0 Current fffffa600569b360
Base fffffa600569d000 Limit fffffa6005695000 Call 0
Priority 13 BasePriority 13 PriorityDecrement 0 IoPriority 2 PagePriority 5
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for nvlddmkm.sys -
fffffa60`0569b6c8 fffff800`03527699 : 00000000`00000010  00000000`00000246 fffffa60`0569b6f0 00000000`00000018 :  hal!HalpPciReadMmConfigUlong+0x7
fffffa60`0569b6d0 fffff800`035274aa : 00000000`00000000  fffffa60`0569b800 00000000`00000040 fffff800`0351b000 :  hal!HalpPCIPerformConfigAccess+0x55
fffffa60`0569b700 fffff800`035272ef : fffffa60`0569b800  00000000`00000000 00000000`00000000 fffffa60`0569b8d0 :  hal!HalpPCIConfigHoldingConfigLock+0x17a
fffffa60`0569b750 fffff800`035270d8 : 00000000`00000000  fffffa60`0569b8d0 fffffa60`0569b800 00000000`00000040 :  hal!HalpPCIConfig+0x87
fffffa60`0569b790 fffff800`03526d1c : 00000000`00000000  00000000`00000000 00000000`00000040 fffff800`0353aa80 :  hal!HalpReadPCIConfig+0x60
fffffa60`0569b7d0 fffff800`03528190 : 00000000`00000002  fffff800`03526d9a 00000000`00000000 00000000`0000000a :  hal!HalpGetPCIData+0x89
fffffa60`0569b8a0 fffffa60`02c17c44 : 00000000`00000000  00000000`00000000 00000000`00000028 fffffa60`0569b9d0 :  hal!HalGetBusDataByOffset+0x9c
fffffa60`0569b990 fffffa60`02cdc48e : 00000000`00000000  00000000`0000ffff 00000000`00000007 00000000`00000000 :  nvlddmkm+0x208c44
fffffa60`0569b9d0 fffffa60`02cdffa4 : fffffa80`ffff8086  fffffa80`08a72870 fffffa60`03537888 fffffa80`08a72c41 :  nvlddmkm+0x2cd48e
fffffa60`0569ba50 fffffa60`02ce0344 : fffffa80`09f40300  fffffa80`09f4d000 fffffa80`08a72870 fffffa80`08757610 :  nvlddmkm+0x2d0fa4
fffffa60`0569bab0 fffffa60`02cd2867 : fffffa80`08a705e3  fffffa80`08a72870 fffffa80`08a710de fffffa80`08a72870 :  nvlddmkm+0x2d1344
fffffa60`0569bb40 fffffa60`02c0231e : fffffa80`09f4d000  fffffa80`08a72870 fffffa80`08a72870 fffffa80`09e5e010 :  nvlddmkm+0x2c3867
fffffa60`0569bb70 fffffa60`02d7f2db : fffffa80`09e5e010  fffffa80`09e5e010 fffffa80`08a72870 00000000`00000012 :  nvlddmkm+0x1f331e
fffffa60`0569bbb0 fffffa60`02cc860c : 00000000`00000000  00000000`00000000 00000000`00000001 00000000`00000012 :  nvlddmkm+0x3702db
fffffa60`0569bbf0 fffffa60`02ccd5c8 : 00000000`00000000  00000000`00000012 00000000`00000000 fffffa80`09f63d30 :  nvlddmkm+0x2b960c
fffffa60`0569bc20 fffffa60`02c383e5 : 00000000`00000000  fffffa80`09f4d000 00000000`00000000 fffffa80`095ca000 :  nvlddmkm+0x2be5c8
fffffa60`0569bcb0 fffffa60`02c0a5cd : fffffa80`09f4d000  fffffa80`09f4d000 00000000`00000001 00000000`00000001 :  nvlddmkm+0x2293e5
fffffa60`0569bce0 fffffa60`02c0a73b : fffffa60`00000000  00000000`d0000000 00000000`00000000 00000000`00000000 :  nvlddmkm+0x1fb5cd
fffffa60`0569bdb0 fffffa60`02b2ae91 : 00000000`00000000  00000000`00000000 00000000`d0000000 00000000`00000000 :  nvlddmkm+0x1fb73b
fffffa60`0569be70 fffffa60`02b2b3d0 : fffffa80`08d3d000  fffffa60`02b2ae0f 00000000`00000001 00000000`00000000 :  nvlddmkm+0x11be91
fffffa60`0569bf20 fffffa60`02ae8292 : fffffa80`0017f71e  fffffa80`08d3d000 fffffa80`09ea2240 fffffa80`09ea2240 :  nvlddmkm+0x11c3d0
fffffa60`0569bf60 fffffa60`02a6473a : fffffa80`08d3d000 fffffa60`00000001 fffffa80`08d3d000 00000000`00000000 : nvlddmkm+0xd9292
fffffa60`0569c020 fffffa60`03749ca9 : fffffa80`08d3d000 fffffa80`08d3d000 fffffa60`0569c990 fffffa60`0569c8d0 : nvlddmkm+0x5573a
fffffa60`0569c560 fffffa60`03753389 : fffffa60`03749c27  fffffa80`08d3d000 fffffa60`0569c990 fffffa80`08b2d72c :  nvlddmkm!nvDumpConfig+0x23f999
fffffa60`0569c600 fffffa60`03756d25 : fffffa80`08b2d72c  fffffa80`08d3d000 fffffa60`0569c990 00000000`00000000 :  nvlddmkm!nvDumpConfig+0x249079
fffffa60`0569c7f0 fffffa60`03882b46 : fffffa80`08d3d000  fffffa80`08b2d72c fffffa80`08b2d728 fffff800`030df8b8 :  nvlddmkm!nvDumpConfig+0x24ca15
fffffa60`0569c830 fffffa60`0388073a : 00000000`40020056  00000000`00000000 fffffa80`08b2d040 00000000`00000000 :  dxgkrnl!DpiDxgkDdiStartDevice+0x62
fffffa60`0569c880 fffffa60`03880baa : fffffa80`00000000  00000000`00000000 00000000`00000000 fffffa80`08b3fd80 :  dxgkrnl!DpiFdoStartAdapter+0x382
fffffa60`0569c9e0 fffffa60`0387b66f : 00000000`00000000  00000000`00000000 00000000`00000000 fffffa60`0569cca0 :  dxgkrnl!DpiFdoStartAdapterThread+0x17a
fffffa60`0569ca70 fffffa60`038f71be : fffffa60`00000000  00000000`00000000 00000000`00000000 00000000`00292d00 :  dxgkrnl!DpiSessionCreateCallback+0x1b
fffffa60`0569caa0 fffffa60`038f70f6 : 00000000`00000000  00000000`00000054 fffffa80`09e03040 00000000`00000000 :  watchdog!SMgrSessionOpen+0x42
fffffa60`0569cae0 fffff960`00043ecb : fffffa80`09e03040  00000000`000007ff fffffa60`0569cb48 00000000`00000000 :  watchdog!SMgrNotifySessionChange+0x22
fffffa60`0569cb20 fffff960`00046a9c : fffffa80`0000067b  fffffa60`0569cca0 fffffa80`054d5080 00000000`000007ff :  win32k!InitializeGreCSRSS+0x23
fffffa60`0569cbe0 fffff800`0305a573 : fffffa80`09df3bb0  000007fe`fd7d8a20 fffffa80`09f3f630 00000000`0018f808 :  win32k!NtUserInitialize+0x13c
fffffa60`0569cc20 000007fe`fd72cd9a : 00000000`00000000  00000000`00000000 00000000`00000000 00000000`00000000 :  nt!KiSystemServiceCopyEnd+0x13 (TrapFrame @ fffffa60`0569cc20)
00000000`0018f768 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x7fe`fd72cd9a
3: kd> r
rax=00000000ffffffff rbx=0000000000000028 rcx=ffffffffffd18000
rdx=fffffa600569b818 rsi=fffffa600569b818 rdi=0000000000000018
rip=fffff80003533b47 rsp=fffffa600569b6c8 rbp=ffffffffffd18000
 r8=0000000000000018  r9=0000000000000018 r10=0000000000000000
r11=0000000000000000 r12=fffff8000353a980 r13=0000000000000003
r14=fffffa600569b907 r15=fffff800035424a0
iopl=0         nv up ei pl zr na po nc
cs=0010  ss=0018  ds=0000  es=0000  fs=0000  gs=0000             efl=00000246
hal!HalpPciReadMmConfigUlong+0x7:
fffff800`03533b47 8902            mov     dword ptr [rdx],eax ds:fffffa60`0569b818=ffffffff
Good job on the approach. Looking at intelppm.sys wasn't really necessary since in this case when you look at the running thread for the faulting proc (proc 3) you can see that intelppm was not involved but rather nvlddmkm.sys, or the PCI-E bus, as the last few frames in the callstack show. In the specific situation I was dealing with in the OP, the amd chipset driver was responsible, but not in your case. I'll take a look at the kernel dump myself, but from what I see it looks like you'll want to ask the guy to remove the graphics card, clean up any foreign material that may be in the slot, and then reinsert it, as well as update graphics drivers if they haven't already.
I'm concerned about one thing though, in that you actually are retrieving a thread with all its info n stuff from the faulting proc, which isn't really supposed to happen if that proc was actually frozen. I would think what took place is the IRQL that proc was on at the time was higher than clock interrupt but not higher than the bugcheck, but if that was the case why didn't it save the IRQL (which shows up as 0), or if it did successfully save it, then why on earth would a thread at IRQL 0 stop a clock interrupt?
Perplexing, but I'd like to look into it further. One of the things I'd like to do is check to see if anything in the callstack actually called to increase the IRQL (KeRaiseIRQL). There's a script someone made at codemachine.com that will parse through a module to see if there's any calls it makes to a function name that you give it, which is very convenient. It's not perfect, but does the job well. There's other ways of approaching this as well, but I'll determine that to the best of my ability when I take a look at it.
Stephen
Huh? Who? What? <.>;;
Apologies if it appears to be off topic, but I'm referring to posts #2 & #4 above. I have an identical BSOD address as the poster of #2 describes.
Hello, and welcome to Sysnative :)
I am really sorry, but the OP did not come back to us on that thread. It was a bit complicated. usasma took the first look, I took the second, but couldn't figure it out, so I asked for VirGnarus's help, but it actually ended when the OP PMed me, so I sent back VirGnarus's advice on the graphics card, but OP never responded to either that or the thread in question.
That could be a positive result, but it could also be gave up/took it in for repair or whatever.
I know this is completely not what you want to hear, but it is unfortunately what happened.
Richard
Richard
Thanks Richard, and others, for your replies.
I'll see how I go, but this has been a good starting point.
Cheers
Graham
I'd like to note that the only the IRQL of the bugchecking processor is saved in the kernel dump (at least on x64). The !irql command always says 0 (PASSIVE_LEVEL) and the r cr8 command always says F (HIGH_LEVEL) on any other processor.
That's unusual. Is this just specifically regarding 0x101 bughecks, or for any? Either way, that would mean that code disassembly or !verifier 8 will be needed to ascertain the IRQL for the rest of the processors.
How silly of me. I do recall reading that, but I could've sworn I remember that were certain conditions can be met to make it happen. It's been a while since I've debugged a 0x101 bugcheck, so I'm just going on pure assumption now.
I've noticed something interesting, in regards, to the hal!HalpHpetClockInterrupt function. If we dump the register context for the stack frame of the called function, then several bugcheck parameters are passed as arguments to hal!HalpHpetClockInterrupt:
0: kd> [COLOR=#008000].frame /r 3[/COLOR]
03 fffff880`0287e4c0 fffff800`0328e153 hal!HalpHpetClockInterrupt+0x8d
rax=fffffffffffffffb rbx=fffff80003832460 rcx=[COLOR=#ff0000]0000000000000101[/COLOR]
rdx=[COLOR=#0000cd]0000000000000019[/COLOR] rsi=fffff80003832460 rdi=fffffa8000adf610
rip=fffff8000380c895 rsp=fffff8800287e4c0 rbp=fffff8800287e570
 r8=0000000000000000  r9=[COLOR=#ff8c00]fffff88002f65180[/COLOR] r10=fffff8000321c000
r11=fffff8800287e3f0 r12=0000000000039fcb r13=0000058000000000
r14=0000000000000004 r15=fffff8800287eae0
cs=0010  ss=0000  ds=002b  es=002b  fs=0053  gs=002b             efl=00000246
hal!HalpHpetClockInterrupt+0x8d:
fffff800`0380c895 b001            mov     al,1
The R9 register contains the PRCB address of the hung processor, the RCX register contains the bugcheck code and the RDX register shows the clock interrupt timeout interval.
Write your reply...
