D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 7, 2015 #1 Hi, i have spent a lot of time trying to repair my system files, have used sfc/ dism but none have been fixed. Can someone Plz help with this. Thank You. Attachments sfc.txt 46.8 KB · Views: 10
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 7, 2015 #2 Hi and welcome to Sysnative. I need to collect some more information. Please do the following. Step#1 - Gather Info 1. Download SFCFix.exe and save this to your Desktop. 2. Save any open documents and close all open windows. 3. Double click on SFCFix.exe to open it. 4. Follow all on screen instructions and upon completion, a file should be created on your Desktop named SFCFix.txt. 5. Please post the contents of this log in your next post. Thank you.
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 7, 2015 #3 Hi, i have attempted what u listed but can't get past Stage4a on SFCFix it seems to have frozen and hasn't outputted the text file. Any other method to gather info? Thanks Attachments sfc.png 10 KB · Views: 4
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 7, 2015 #4 OK, let's try something else. I know you may have done this already but I need fresh logs and after a reboot so please do the following. So please reboot your machine and then do the procedure below. Thanks. Step#1 - DISM /RestoreHealth Scan Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Right-click on the Start button and select Command Prompt (Admin) When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following command into it, then press Enter Dism /Online /Cleanup-Image /RestoreHealth When DISM finishes scanning your component store, zip up and attach your CBS log to your next post: C:\Windows\Logs\CBS\CBS.log Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link.
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 7, 2015 #5 Thanks Brian, did as you said it returned error, here is CBS log. Plz send solution. Attachments CBS.zip 602.3 KB · Views: 4
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 7, 2015 #6 Thanks for the info. This will likely take a few rounds of fixing. Please start with the following. Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download. Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip. Drag the file SFCFix.zip onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please Attachments SFCFix.zip 533.2 KB · Views: 3
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 8, 2015 #7 Here it is :). What is the next step? SFCFix version 2.4.4.0 by niemiro. Start time: 2015-06-08 14:08:52.625 Microsoft Windows 8.1 Update 1 - amd64 Using .zip script file at C:\Users\Bilal\Desktop\SFCFix.zip [0] PowerCopy:: Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_780d37a4905eca55 Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.3.9600.16384_none_fb7050014fc6f9b0 Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.17031_none_043e952c12cce236 Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.16384_none_040ba2e812f297c4 Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_d42bd32848bc3b8b Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_machine.inf.resources_31bf3856ad364e35_6.3.9600.16384_en-us_35cb717fc1fcacea\machine.inf_loc Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_c_netservice.inf_31bf3856ad364e35_6.3.9600.16384_none_59dec0c3a6ff3fe5 Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_c_netclient.inf_31bf3856ad364e35_6.3.9600.16384_none_f353de29513b8cd3 Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-b..environment-windows_31bf3856ad364e35_6.3.9600.17031_none_5a29e979609beeff.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-b..ore-bootmanager-efi_31bf3856ad364e35_6.3.9600.17031_none_78723b2670312bfe.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-b..re-memorydiagnostic_31bf3856ad364e35_6.3.9600.17031_none_c926a0b8d86eaba4.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-coremmres_31bf3856ad364e35_6.3.9600.17031_none_35c3d9a9946587e1.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-kernel-power-events_31bf3856ad364e35_6.3.9600.17031_none_a3ed1e3d655ab7dd.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-playtodevice-dll_31bf3856ad364e35_6.3.9600.17031_none_602ffa6634d7308e.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-playtomanager_31bf3856ad364e35_6.3.9600.17031_none_97abbe64d05a710e.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-refs_31bf3856ad364e35_6.3.9600.17031_none_9767d2ebf0b7cf66.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-s..mimagebackupui-main_31bf3856ad364e35_6.3.9600.17031_none_384dbf4e3b4686a2.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-system-events_31bf3856ad364e35_6.3.9600.17031_none_f746cc52d6faecd7.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\wow64_microsoft-windows-a..on-experience-tools_31bf3856ad364e35_6.3.9600.17031_none_901023a4b0a42692.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\x86_microsoft-windows-c..graphy-cryptoconfig_31bf3856ad364e35_6.3.9600.17031_none_3b24193bb7de8076.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\x86_microsoft-windows-playtodevice-dll_31bf3856ad364e35_6.3.9600.17031_none_04115ee27c79bf58.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\x86_microsoft-windows-playtomanager_31bf3856ad364e35_6.3.9600.17031_none_3b8d22e117fcffd8.manifest Successfully took permissions for file or folder C:\WINDOWS\servicing\packages Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_780d37a4905eca55\comdlg32.dll.mui to C:\WINDOWS\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_780d37a4905eca55\comdlg32.dll.mui. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe to C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.3.9600.16384_none_fb7050014fc6f9b0\ext-ms-win-advapi32-registry-l1-1-0.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.3.9600.16384_none_fb7050014fc6f9b0\ext-ms-win-advapi32-registry-l1-1-0.dll. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.17031_none_043e952c12cce236\ext-ms-win-advapi32-msi-l1-1-0.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.17031_none_043e952c12cce236\ext-ms-win-advapi32-msi-l1-1-0.dll. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.17031_none_043e952c12cce236\ext-ms-win-advapi32-ntmarta-l1-1-0.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.17031_none_043e952c12cce236\ext-ms-win-advapi32-ntmarta-l1-1-0.dll. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.17031_none_043e952c12cce236\ext-ms-win-advapi32-psm-app-l1-1-0.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.17031_none_043e952c12cce236\ext-ms-win-advapi32-psm-app-l1-1-0.dll. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.16384_none_040ba2e812f297c4\ext-ms-win-advapi32-msi-l1-1-0.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.16384_none_040ba2e812f297c4\ext-ms-win-advapi32-msi-l1-1-0.dll. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.16384_none_040ba2e812f297c4\ext-ms-win-advapi32-ntmarta-l1-1-0.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.16384_none_040ba2e812f297c4\ext-ms-win-advapi32-ntmarta-l1-1-0.dll. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.16384_none_040ba2e812f297c4\ext-ms-win-advapi32-psm-app-l1-1-0.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.16384_none_040ba2e812f297c4\ext-ms-win-advapi32-psm-app-l1-1-0.dll. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_d42bd32848bc3b8b\comdlg32.dll.mui to C:\WINDOWS\winsxs\amd64_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_d42bd32848bc3b8b\comdlg32.dll.mui. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_machine.inf.resources_31bf3856ad364e35_6.3.9600.16384_en-us_35cb717fc1fcacea\machine.inf_loc to C:\WINDOWS\winsxs\amd64_machine.inf.resources_31bf3856ad364e35_6.3.9600.16384_en-us_35cb717fc1fcacea\machine.inf_loc. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_c_netservice.inf_31bf3856ad364e35_6.3.9600.16384_none_59dec0c3a6ff3fe5\c_netservice.inf to C:\WINDOWS\winsxs\amd64_c_netservice.inf_31bf3856ad364e35_6.3.9600.16384_none_59dec0c3a6ff3fe5\c_netservice.inf. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_c_netclient.inf_31bf3856ad364e35_6.3.9600.16384_none_f353de29513b8cd3\c_netclient.inf to C:\WINDOWS\winsxs\amd64_c_netclient.inf_31bf3856ad364e35_6.3.9600.16384_none_f353de29513b8cd3\c_netclient.inf. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\amd64_microsoft-windows-b..environment-windows_31bf3856ad364e35_6.3.9600.17031_none_5a29e979609beeff.manifest to C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-b..environment-windows_31bf3856ad364e35_6.3.9600.17031_none_5a29e979609beeff.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\amd64_microsoft-windows-b..ore-bootmanager-efi_31bf3856ad364e35_6.3.9600.17031_none_78723b2670312bfe.manifest to C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-b..ore-bootmanager-efi_31bf3856ad364e35_6.3.9600.17031_none_78723b2670312bfe.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\amd64_microsoft-windows-b..re-memorydiagnostic_31bf3856ad364e35_6.3.9600.17031_none_c926a0b8d86eaba4.manifest to C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-b..re-memorydiagnostic_31bf3856ad364e35_6.3.9600.17031_none_c926a0b8d86eaba4.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\amd64_microsoft-windows-coremmres_31bf3856ad364e35_6.3.9600.17031_none_35c3d9a9946587e1.manifest to C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-coremmres_31bf3856ad364e35_6.3.9600.17031_none_35c3d9a9946587e1.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\amd64_microsoft-windows-kernel-power-events_31bf3856ad364e35_6.3.9600.17031_none_a3ed1e3d655ab7dd.manifest to C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-kernel-power-events_31bf3856ad364e35_6.3.9600.17031_none_a3ed1e3d655ab7dd.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\amd64_microsoft-windows-playtodevice-dll_31bf3856ad364e35_6.3.9600.17031_none_602ffa6634d7308e.manifest to C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-playtodevice-dll_31bf3856ad364e35_6.3.9600.17031_none_602ffa6634d7308e.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\amd64_microsoft-windows-playtomanager_31bf3856ad364e35_6.3.9600.17031_none_97abbe64d05a710e.manifest to C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-playtomanager_31bf3856ad364e35_6.3.9600.17031_none_97abbe64d05a710e.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\amd64_microsoft-windows-refs_31bf3856ad364e35_6.3.9600.17031_none_9767d2ebf0b7cf66.manifest to C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-refs_31bf3856ad364e35_6.3.9600.17031_none_9767d2ebf0b7cf66.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\amd64_microsoft-windows-s..mimagebackupui-main_31bf3856ad364e35_6.3.9600.17031_none_384dbf4e3b4686a2.manifest to C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-s..mimagebackupui-main_31bf3856ad364e35_6.3.9600.17031_none_384dbf4e3b4686a2.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\amd64_microsoft-windows-system-events_31bf3856ad364e35_6.3.9600.17031_none_f746cc52d6faecd7.manifest to C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-system-events_31bf3856ad364e35_6.3.9600.17031_none_f746cc52d6faecd7.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\wow64_microsoft-windows-a..on-experience-tools_31bf3856ad364e35_6.3.9600.17031_none_901023a4b0a42692.manifest to C:\WINDOWS\winsxs\manifests\wow64_microsoft-windows-a..on-experience-tools_31bf3856ad364e35_6.3.9600.17031_none_901023a4b0a42692.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\x86_microsoft-windows-c..graphy-cryptoconfig_31bf3856ad364e35_6.3.9600.17031_none_3b24193bb7de8076.manifest to C:\WINDOWS\winsxs\manifests\x86_microsoft-windows-c..graphy-cryptoconfig_31bf3856ad364e35_6.3.9600.17031_none_3b24193bb7de8076.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\x86_microsoft-windows-playtodevice-dll_31bf3856ad364e35_6.3.9600.17031_none_04115ee27c79bf58.manifest to C:\WINDOWS\winsxs\manifests\x86_microsoft-windows-playtodevice-dll_31bf3856ad364e35_6.3.9600.17031_none_04115ee27c79bf58.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\x86_microsoft-windows-playtomanager_31bf3856ad364e35_6.3.9600.17031_none_3b8d22e117fcffd8.manifest to C:\WINDOWS\winsxs\manifests\x86_microsoft-windows-playtomanager_31bf3856ad364e35_6.3.9600.17031_none_3b8d22e117fcffd8.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.cat to C:\WINDOWS\servicing\packages\Package_108_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.cat. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.cat to C:\WINDOWS\servicing\packages\Package_109_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.cat. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.mum to C:\WINDOWS\servicing\packages\Package_110_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.mum. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.cat to C:\WINDOWS\servicing\packages\Package_1_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.cat. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.cat to C:\WINDOWS\servicing\packages\Package_2_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.cat. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Packages\Package_3_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.mum to C:\WINDOWS\servicing\packages\Package_3_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.mum. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Packages\Package_for_KB2903939_RTM~31bf3856ad364e35~amd64~~6.3.1.2.cat to C:\WINDOWS\servicing\packages\Package_for_KB2903939_RTM~31bf3856ad364e35~amd64~~6.3.1.2.cat. Successfully restored ownership for C:\WINDOWS\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_780d37a4905eca55 Successfully restored permissions on C:\WINDOWS\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_780d37a4905eca55 Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.3.9600.16384_none_fb7050014fc6f9b0 Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-minkernelapinamespace_31bf3856ad364e35_6.3.9600.16384_none_fb7050014fc6f9b0 Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.17031_none_043e952c12cce236 Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.17031_none_043e952c12cce236 Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.16384_none_040ba2e812f297c4 Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-mincoreapinamespace_31bf3856ad364e35_6.3.9600.16384_none_040ba2e812f297c4 Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_d42bd32848bc3b8b Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_d42bd32848bc3b8b Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d Successfully restored ownership for C:\WINDOWS\winsxs\amd64_machine.inf.resources_31bf3856ad364e35_6.3.9600.16384_en-us_35cb717fc1fcacea\machine.inf_loc Successfully restored permissions on C:\WINDOWS\winsxs\amd64_machine.inf.resources_31bf3856ad364e35_6.3.9600.16384_en-us_35cb717fc1fcacea\machine.inf_loc Successfully restored ownership for C:\WINDOWS\winsxs\amd64_c_netservice.inf_31bf3856ad364e35_6.3.9600.16384_none_59dec0c3a6ff3fe5 Successfully restored permissions on C:\WINDOWS\winsxs\amd64_c_netservice.inf_31bf3856ad364e35_6.3.9600.16384_none_59dec0c3a6ff3fe5 Successfully restored ownership for C:\WINDOWS\winsxs\amd64_c_netclient.inf_31bf3856ad364e35_6.3.9600.16384_none_f353de29513b8cd3 Successfully restored permissions on C:\WINDOWS\winsxs\amd64_c_netclient.inf_31bf3856ad364e35_6.3.9600.16384_none_f353de29513b8cd3 Successfully restored ownership for C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-b..environment-windows_31bf3856ad364e35_6.3.9600.17031_none_5a29e979609beeff.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-b..environment-windows_31bf3856ad364e35_6.3.9600.17031_none_5a29e979609beeff.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-b..ore-bootmanager-efi_31bf3856ad364e35_6.3.9600.17031_none_78723b2670312bfe.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-b..ore-bootmanager-efi_31bf3856ad364e35_6.3.9600.17031_none_78723b2670312bfe.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-b..re-memorydiagnostic_31bf3856ad364e35_6.3.9600.17031_none_c926a0b8d86eaba4.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-b..re-memorydiagnostic_31bf3856ad364e35_6.3.9600.17031_none_c926a0b8d86eaba4.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-coremmres_31bf3856ad364e35_6.3.9600.17031_none_35c3d9a9946587e1.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-coremmres_31bf3856ad364e35_6.3.9600.17031_none_35c3d9a9946587e1.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-kernel-power-events_31bf3856ad364e35_6.3.9600.17031_none_a3ed1e3d655ab7dd.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-kernel-power-events_31bf3856ad364e35_6.3.9600.17031_none_a3ed1e3d655ab7dd.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-playtodevice-dll_31bf3856ad364e35_6.3.9600.17031_none_602ffa6634d7308e.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-playtodevice-dll_31bf3856ad364e35_6.3.9600.17031_none_602ffa6634d7308e.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-playtomanager_31bf3856ad364e35_6.3.9600.17031_none_97abbe64d05a710e.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-playtomanager_31bf3856ad364e35_6.3.9600.17031_none_97abbe64d05a710e.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-refs_31bf3856ad364e35_6.3.9600.17031_none_9767d2ebf0b7cf66.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-refs_31bf3856ad364e35_6.3.9600.17031_none_9767d2ebf0b7cf66.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-s..mimagebackupui-main_31bf3856ad364e35_6.3.9600.17031_none_384dbf4e3b4686a2.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-s..mimagebackupui-main_31bf3856ad364e35_6.3.9600.17031_none_384dbf4e3b4686a2.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-system-events_31bf3856ad364e35_6.3.9600.17031_none_f746cc52d6faecd7.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\amd64_microsoft-windows-system-events_31bf3856ad364e35_6.3.9600.17031_none_f746cc52d6faecd7.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\wow64_microsoft-windows-a..on-experience-tools_31bf3856ad364e35_6.3.9600.17031_none_901023a4b0a42692.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\wow64_microsoft-windows-a..on-experience-tools_31bf3856ad364e35_6.3.9600.17031_none_901023a4b0a42692.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\x86_microsoft-windows-c..graphy-cryptoconfig_31bf3856ad364e35_6.3.9600.17031_none_3b24193bb7de8076.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\x86_microsoft-windows-c..graphy-cryptoconfig_31bf3856ad364e35_6.3.9600.17031_none_3b24193bb7de8076.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\x86_microsoft-windows-playtodevice-dll_31bf3856ad364e35_6.3.9600.17031_none_04115ee27c79bf58.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\x86_microsoft-windows-playtodevice-dll_31bf3856ad364e35_6.3.9600.17031_none_04115ee27c79bf58.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\x86_microsoft-windows-playtomanager_31bf3856ad364e35_6.3.9600.17031_none_3b8d22e117fcffd8.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\x86_microsoft-windows-playtomanager_31bf3856ad364e35_6.3.9600.17031_none_3b8d22e117fcffd8.manifest Successfully restored ownership for C:\WINDOWS\servicing\packages Successfully restored permissions on C:\WINDOWS\servicing\packages PowerCopy:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.4.0 by niemiro has completed. Currently storing 33 datablocks. Finish time: 2015-06-08 14:08:57.997 Script hash: vdFUPp6KG/yX1Ys0b7NGStg8FVbOkv3WtR0k8ySxv4A= ----------------------EOF-----------------------
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 8, 2015 #8 Replacements seem to have worked. Now we need a new log to see what's left. Step#1 - DISM /RestoreHealth Scan Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Right-click on the Start button and select Command Prompt (Admin) When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following command into it, then press Enter Dism /Online /Cleanup-Image /RestoreHealth When DISM finishes scanning your component store, zip up and attach your CBS log to your next post: C:\Windows\Logs\CBS\CBS.log Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link.
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 8, 2015 #9 Here is the CBS Log. great help thanks, gone down to 13. Attachments CBS.zip 13.3 KB · Views: 2
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 8, 2015 #10 Cool. Getting there. Please do the following. Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download. Download the file below, SFCScript.txt, and save this to your Desktop. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCScript.txt. Drag the file SFCScript.txt onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please Attachments SFCScript.txt 101 bytes · Views: 2
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 9, 2015 #11 Yes, here is the output SFCFix version 2.4.4.0 by niemiro. Start time: 2015-06-09 11:28:21.237 Microsoft Windows 8.1 Update 1 - amd64 Using .txt script file at C:\Users\Bilal\Desktop\SFCScript.txt [1] Trace:: Successfully traced component amd64_958c717812b0c792f037615f4796bcf1_31bf3856ad364e35_6.3.9600.16507_none_10932a3b6aa5935e. Package_1_for_KB2916626~31bf3856ad364e35~amd64~~6.3.1.0.2916626-1_neutral_GDR5 Trace:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.4.0 by niemiro has completed. Currently storing 33 datablocks. Finish time: 2015-06-09 11:28:21.333 Script hash: CQzEa1tiaKjPvvjgoZYvIgWdsioTykBIQ8DJFl7wJdg= ----------------------EOF-----------------------
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 9, 2015 #12 Perfect. Please do the following. Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download. Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip. Drag the file SFCFix.zip onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please Step#2 - DISM /RestoreHealth Scan Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Right-click on the Start button and select Command Prompt (Admin) When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following command into it, then press Enter Dism /Online /Cleanup-Image /RestoreHealth When DISM finishes scanning your component store, zip up and attach your CBS log to your next post: C:\Windows\Logs\CBS\CBS.log Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link. Items for your next post 1. SFCFix.txt 2. CBS.log Attachments SFCFix.zip 396 KB · Views: 1
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 9, 2015 #13 Here are the files. :) SFCFix version 2.4.4.0 by niemiro. Start time: 2015-06-09 14:16:57.165 Microsoft Windows 8.1 Update 1 - amd64 Using .zip script file at C:\Users\Bilal\Desktop\SFCFix.zip [0] PowerCopy:: Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_microsoft-windows-credwiz.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_9d1bbe77e3fb3236 Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_microsoft-windows-credui.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_ef31ced3c2b2a744 Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_microsoft-windows-console.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_0b388bd962c0a001 Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-credwiz.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_f93a59fb9c58a36c Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-credui.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_4b506a577b10187a Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-console.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_6757275d1b1e1137 Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\amd64_958c717812b0c792f037615f4796bcf1_31bf3856ad364e35_6.3.9600.16507_none_10932a3b6aa5935e.manifest Successfully took permissions for file or folder C:\WINDOWS\servicing\packages Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-credwiz.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_9d1bbe77e3fb3236\credwiz.exe.mui to C:\WINDOWS\winsxs\x86_microsoft-windows-credwiz.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_9d1bbe77e3fb3236\credwiz.exe.mui. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-credui.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_ef31ced3c2b2a744\credui.dll.mui to C:\WINDOWS\winsxs\x86_microsoft-windows-credui.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_ef31ced3c2b2a744\credui.dll.mui. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-console.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_0b388bd962c0a001\console.dll.mui to C:\WINDOWS\winsxs\x86_microsoft-windows-console.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_0b388bd962c0a001\console.dll.mui. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe to C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-credwiz.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_f93a59fb9c58a36c\credwiz.exe.mui to C:\WINDOWS\winsxs\amd64_microsoft-windows-credwiz.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_f93a59fb9c58a36c\credwiz.exe.mui. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-credui.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_4b506a577b10187a\credui.dll.mui to C:\WINDOWS\winsxs\amd64_microsoft-windows-credui.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_4b506a577b10187a\credui.dll.mui. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-console.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_6757275d1b1e1137\console.dll.mui to C:\WINDOWS\winsxs\amd64_microsoft-windows-console.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_6757275d1b1e1137\console.dll.mui. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\amd64_958c717812b0c792f037615f4796bcf1_31bf3856ad364e35_6.3.9600.16507_none_10932a3b6aa5935e.manifest to C:\WINDOWS\winsxs\manifests\amd64_958c717812b0c792f037615f4796bcf1_31bf3856ad364e35_6.3.9600.16507_none_10932a3b6aa5935e.manifest. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.mum to C:\WINDOWS\servicing\packages\Package_109_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.mum. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.mum to C:\WINDOWS\servicing\packages\Package_1_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.mum. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.mum to C:\WINDOWS\servicing\packages\Package_2_for_KB2903939~31bf3856ad364e35~amd64~~6.3.1.2.mum. Successfully restored ownership for C:\WINDOWS\winsxs\x86_microsoft-windows-credwiz.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_9d1bbe77e3fb3236 Successfully restored permissions on C:\WINDOWS\winsxs\x86_microsoft-windows-credwiz.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_9d1bbe77e3fb3236 Successfully restored ownership for C:\WINDOWS\winsxs\x86_microsoft-windows-credui.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_ef31ced3c2b2a744 Successfully restored permissions on C:\WINDOWS\winsxs\x86_microsoft-windows-credui.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_ef31ced3c2b2a744 Successfully restored ownership for C:\WINDOWS\winsxs\x86_microsoft-windows-console.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_0b388bd962c0a001 Successfully restored permissions on C:\WINDOWS\winsxs\x86_microsoft-windows-console.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_0b388bd962c0a001 Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-credwiz.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_f93a59fb9c58a36c Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-credwiz.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_f93a59fb9c58a36c Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-credui.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_4b506a577b10187a Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-credui.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_4b506a577b10187a Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-console.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_6757275d1b1e1137 Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-console.resources_31bf3856ad364e35_6.3.9600.16384_en-gb_6757275d1b1e1137 Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll Successfully restored ownership for C:\WINDOWS\winsxs\manifests\amd64_958c717812b0c792f037615f4796bcf1_31bf3856ad364e35_6.3.9600.16507_none_10932a3b6aa5935e.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\amd64_958c717812b0c792f037615f4796bcf1_31bf3856ad364e35_6.3.9600.16507_none_10932a3b6aa5935e.manifest Successfully restored ownership for C:\WINDOWS\servicing\packages Successfully restored permissions on C:\WINDOWS\servicing\packages PowerCopy:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.4.0 by niemiro has completed. Currently storing 43 datablocks. Finish time: 2015-06-09 14:17:00.933 Script hash: c4yz6HfunJvq/5BX+GGlfcE6R+o+UChsmlt4YTB0CUU= ----------------------EOF-------- Attachments SFCFix.txt 18.5 KB · Views: 1 CBS.zip 9.3 KB · Views: 1
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 9, 2015 #14 Almost there. Please do the following. Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download. Download the file below, SFCScript.txt, and save this to your Desktop. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCScript.txt. Drag the file SFCScript.txt onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please Attachments SFCScript.txt 177 bytes · Views: 2
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 10, 2015 #15 Thanks SFCFix version 2.4.5.0 by niemiro. Start time: 2015-06-10 09:59:57.050 Microsoft Windows 8.1 Update 1 - amd64 Using .txt script file at C:\Users\Bilal\Desktop\SFCScript.txt [0] Trace:: Successfully traced component amd64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_1cb7c81b3d430108. Package_1_for_KB2916626~31bf3856ad364e35~amd64~~6.3.1.0.2916626-1_neutral_GDR5 Successfully traced component wow64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_270c726d71a3c303. Package_1_for_KB2916626~31bf3856ad364e35~amd64~~6.3.1.0.2916626-1_neutral_GDR5 Trace:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.5.0 by niemiro has completed. Currently storing 43 datablocks. Finish time: 2015-06-10 09:59:57.801 Script hash: ZtgC/J2bMC3lB29A1CmHt3PzBGvtbOAj5DJAMVPbiY8= ----------------------EOF-----------------------
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 10, 2015 #16 Thank you. Let's see if this gets the last five cleaned up. We're not going to run DISM yet though. Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download. Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip. Drag the file SFCFix.zip onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please Step#2 - Verify Corruption is fixed 1. Right-click on the Start button and select Command Prompt (Admin) 2. When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following command into it, then press Enter sfc /scannow 3. Once it finishes, copy and paste the following into the command-prompt window and press Enter. copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt" 4. Once this has completed please go to your Desktop and you will find CBS.txt => Please upload CBS.txt to this thread Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link. Items for your next post 1. SFCFix.txt 2. CBS.txt Attachments SFCFix.zip 381.7 KB · Views: 4
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 11, 2015 #17 Hi, here they are thanks. SFCFix version 2.4.5.0 by niemiro. Start time: 2015-06-11 13:45:36.367 Microsoft Windows 8.1 Update 1 - amd64 Using .zip script file at C:\Users\Bilal\Desktop\SFCFix.zip [1] PowerCopy:: Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\amd64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_1cb7c81b3d430108.manifest Successfully took permissions for file or folder C:\WINDOWS\winsxs\manifests\wow64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_270c726d71a3c303.manifest WARNING: File C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe was not backed up as that would replace the current backup. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe to C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe. WARNING: File C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll was not backed up as that would replace the current backup. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll. WARNING: File C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll was not backed up as that would replace the current backup. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll. WARNING: File C:\WINDOWS\winsxs\manifests\amd64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_1cb7c81b3d430108.manifest was not backed up as that would replace the current backup. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\amd64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_1cb7c81b3d430108.manifest to C:\WINDOWS\winsxs\manifests\amd64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_1cb7c81b3d430108.manifest. WARNING: File C:\WINDOWS\winsxs\manifests\wow64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_270c726d71a3c303.manifest was not backed up as that would replace the current backup. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\Manifests\wow64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_270c726d71a3c303.manifest to C:\WINDOWS\winsxs\manifests\wow64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_270c726d71a3c303.manifest. Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll Successfully restored ownership for C:\WINDOWS\winsxs\manifests\amd64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_1cb7c81b3d430108.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\amd64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_1cb7c81b3d430108.manifest Successfully restored ownership for C:\WINDOWS\winsxs\manifests\wow64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_270c726d71a3c303.manifest Successfully restored permissions on C:\WINDOWS\winsxs\manifests\wow64_adobe-flash-for-windows_31bf3856ad364e35_6.3.9600.16507_none_270c726d71a3c303.manifest PowerCopy:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.5.0 by niemiro has completed. Currently storing 45 datablocks. Finish time: 2015-06-11 13:45:36.917 Script hash: KPQWwZAB3BI4qu7SaKhbX/C31Z6qZ910XRPPal757Bo= ----------------------EOF----------------------- Attachments CBS.zip 175.9 KB · Views: 2
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 11, 2015 #18 Thank you. These are a little tricky. I'm going to try to fix only one to see if it works. Please do the following. Step#1 - Registry Update - Mark to Expect Uncompressed File 1. Right-click on the Start button and select Command Prompt (Admin) 2. When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following commands into it one at a time then press Enter after each line. reg load HKLM\COMPONENTS %windir%\System32\config\COMPONENTS reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d" /v f!es.dll /t REG_DWORD /d 00000001 /f Step#2 - Verify Corruption is fixed 1. Right-click on the Start button and select Command Prompt (Admin) 2. When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following command into it, then press Enter sfc /scannow 3. Once it finishes, copy and paste the following into the command-prompt window and press Enter. copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt" 4. Once this has completed please go to your Desktop and you will find CBS.txt => Please upload CBS.txt to this thread Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link.
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 11, 2015 #19 Yes, the commands outputted operation successful message, here is the CBS log, thanks. Attachments cbs.zip 507.6 KB · Views: 2
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 11, 2015 #20 Thanks. Please do the following. Step#1 - Registry Query 1. Right-click on the Start button and select Command Prompt (Admin) 2. When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following commands into it one at a time then press Enter after each line. reg load HKLM\COMPONENTS %windir%\System32\config\COMPONENTS reg query "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d" /v f!es.dll > 1 && notepad 1 3. Notepad will open with some info. Please post this. Thank you.
