D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 11, 2015 #21 Here is the notepad info:- HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d f!es.dll REG_DWORD 0x1
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 11, 2015 #22 Perfect. One more thing which will give me a direction to go. Same thing as before but we are changing the value. Step#1 - Registry Update - Mark to Expect Uncompressed File 1. Right-click on the Start button and select Command Prompt (Admin) 2. When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following commands into it one at a time then press Enter after each line. reg load HKLM\COMPONENTS %windir%\System32\config\COMPONENTS reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d" /v f!es.dll /t REG_DWORD /d 00000003 /f Step#2 - Verify Corruption is fixed 1. Right-click on the Start button and select Command Prompt (Admin) 2. When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following command into it, then press Enter sfc /scannow 3. Once it finishes, copy and paste the following into the command-prompt window and press Enter. copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt" 4. Once this has completed please go to your Desktop and you will find CBS.txt => Please upload CBS.txt to this thread Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link.
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 11, 2015 #23 This is what notepad displayed HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d f!es.dll REG_DWORD 0x1
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 11, 2015 #24 The most recent instructions I posted would not have opened up notepad. You may have followed the incorrect instructions?
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 11, 2015 #25 Nah, i thought for some reason my previous message didn't show up so i re-posted it, here is the CBS log for your latest instruction. Attachments cbs.zip 669.3 KB · Views: 4
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 11, 2015 #26 OK, I have a direction now. I need a copy of your COMPONENTS and SOFTWARE hives. Please do the following. Retrieve Components/Software Hives Please download the Freeware RegBak from here: Acelogix Software - Download products You will find it at the bottom of the page that the link brings you to. Go ahead and install this program and accept all the defaults. After the last install screen the program should open. Click the New Backup button. Accept the defaults and simply click Start. When it says Finished successfully, click the Close button. This will bring you back to the main screen of the program. You will see one entry in this list with the date that you did it. Right-click on this line-item and select Explore Backup... This will bring you into the folder where the backup was made. You should see a Users folder and a Windows folder along with a couple other files. Double-click on the Windows folder to open it. Then open the System32 folder and then config folder. You should see around 6 files in here, two of which are named COMPONENTS and SOFTWARE. Copy these two files to your Desktop. If the COMPONENTS file does not exist, please fetch it instead from C:\Windows\System32\config\COMPONENTS. Now right click on these files on your desktop and select Send to > Compressed (zipped) folder. Then please upload the zip file(s) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Dropbox or One Drive or SendSpace and then just provide the link in your reply. You can close any open windows you have as well as the RegBack program now. Last edited: Jun 11, 2015
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 11, 2015 #27 One of my colleagues was able to source the remaining files you need so you don't have to do the previous step. The following should get you fixed up. Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download. Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip. Drag the file SFCFix.zip onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please Step#2 - Verify Corruption is fixed 1. Right-click on the Start button and select Command Prompt (Admin) 2. When command prompt opens, Copy (Ctrl+C) and Paste (Right-click > Paste) the following command into it, then press Enter sfc /scannow 3. Once it finishes, copy and paste the following into the command-prompt window and press Enter. copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt" 4. Once this has completed please go to your Desktop and you will find CBS.txt => Please upload CBS.txt to this thread Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link. Items for your next post 1. SFCFix.txt 2. CBS.txt Attachments SFCFix.zip 662.8 KB · Views: 4
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 11, 2015 #28 Ok thanks :) SFCFix version 2.4.5.0 by niemiro. Start time: 2015-06-12 01:41:54.171 Microsoft Windows 8.1 Update 1 - amd64 Using .zip script file at C:\Users\Bilal\Desktop\SFCFix.zip [0] PowerCopy:: Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll WARNING: File C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe was not backed up as that would replace the current backup. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe to C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe. WARNING: File C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll was not backed up as that would replace the current backup. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll. WARNING: File C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll was not backed up as that would replace the current backup. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll. Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-t..ces-workspacebroker_31bf3856ad364e35_6.3.9600.16384_none_8000a158f4bfcceb\wkspbroker.exe Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-msf-core_31bf3856ad364e35_6.3.9600.16384_none_328b3da2ba99ca5c\WinSync.dll Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-c..complus-eventsystem_31bf3856ad364e35_6.3.9600.16384_none_fdabff2825b4a69d\es.dll PowerCopy:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.5.0 by niemiro has completed. Currently storing 45 datablocks. Finish time: 2015-06-12 01:41:54.899 Script hash: OwAc8zcH/57UuJuX3Yqy9RKLMke9jsGtJtnU45Irr38= ----------------------EOF----------------------- Attachments cbs.zip 159.6 KB · Views: 2
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 11, 2015 #29 Looks good. Your Sysprep files are corrupt. To fix, please do the following. Code: 2015-06-12 01:58:07, Info CSI 0000504d@2015/6/12:00:58:07.581 Sysprep Warning: Corruption detected. Sysprep Commands will be ignored Step#1 - SFCFix Script Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Download SFCFix.exe (by niemiro) and save this to your Desktop. If you still have this on your desktop from downloading previously, you don't need to re-download. Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it. Save any open documents and close all open windows. On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip. Drag the file SFCFix.zip onto the file SFCFix.exe and release it. SFCFix will now process the script. Upon completion, a file should be created on your Desktop: SFCFix.txt. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please Attachments SFCFix.zip 5.9 KB · Views: 5
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 12, 2015 #30 Thank You, here it is:- SFCFix version 2.4.5.0 by niemiro. Start time: 2015-06-12 09:21:49.491 Microsoft Windows 8.1 Update 3 - amd64 Using .zip script file at C:\Users\Bilal\Desktop\SFCFix.zip [0] PowerCopy:: Successfully took permissions for file or folder C:\WINDOWS\Sysnative\Sysprep\ActionFiles\Cleanup.xml Successfully took permissions for file or folder C:\WINDOWS\Sysnative\Sysprep\ActionFiles\Generalize.xml Successfully took permissions for file or folder C:\WINDOWS\Sysnative\Sysprep\ActionFiles\Respecialize.xml Successfully took permissions for file or folder C:\WINDOWS\Sysnative\Sysprep\ActionFiles\Specialize.xml Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\ActionFiles\Cleanup.xml to C:\WINDOWS\System32\Sysprep\ActionFiles\Cleanup.xml. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\ActionFiles\Generalize.xml to C:\WINDOWS\System32\Sysprep\ActionFiles\Generalize.xml. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\ActionFiles\Respecialize.xml to C:\WINDOWS\System32\Sysprep\ActionFiles\Respecialize.xml. Successfully copied file C:\Users\Bilal\AppData\Local\niemiro\Archive\ActionFiles\Specialize.xml to C:\WINDOWS\System32\Sysprep\ActionFiles\Specialize.xml. Successfully restored ownership for C:\WINDOWS\Sysnative\Sysprep\ActionFiles\Cleanup.xml Successfully restored permissions on C:\WINDOWS\Sysnative\Sysprep\ActionFiles\Cleanup.xml Successfully restored ownership for C:\WINDOWS\Sysnative\Sysprep\ActionFiles\Generalize.xml Successfully restored permissions on C:\WINDOWS\Sysnative\Sysprep\ActionFiles\Generalize.xml Successfully restored ownership for C:\WINDOWS\Sysnative\Sysprep\ActionFiles\Respecialize.xml Successfully restored permissions on C:\WINDOWS\Sysnative\Sysprep\ActionFiles\Respecialize.xml Successfully restored ownership for C:\WINDOWS\Sysnative\Sysprep\ActionFiles\Specialize.xml Successfully restored permissions on C:\WINDOWS\Sysnative\Sysprep\ActionFiles\Specialize.xml PowerCopy:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.5.0 by niemiro has completed. Currently storing 49 datablocks. Finish time: 2015-06-12 09:21:50.109 Script hash: kOv2cGCpwN9mN8LRrAL1MM0+CBSYx0Cjp/epvIDsfd8= ----------------------EOF-----------------------
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,134 Location United States Jun 12, 2015 #31 Awesome. All your corruption has been resolved.
D djbillz7dtmak Member Joined Jun 7, 2015 Posts 16 Location Sheffield Jun 12, 2015 #32 Great!! Thanks so much it means a lot. Finally i can update the OS after 13 months! Top Professionals Brian and Co. keep up the good work. :)
