Corrupt/Missing Winsxs manafest: No DVD in System
NOTE: I have extracted Install.win to e:\Windows\winsxs
Start time: 2014-10-10 15:39:37.472
Using .txt script file at C:\Users\DonB\Desktop\SFCFixScript.txt [0]
Trace::
Failed to trace component x86_microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.91_none_dc9917e997f80c63 with return code -3.
Failed to trace component x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.91_none_5c400d5e63e93b68 with return code -3.
Failed to trace component x86_policy.8.0.microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.91_none_54c1279468b7b84b with return code -3.
Failed to trace component x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.91_none_db5f5c9d98cb161f with return code -3.
Failed to trace component x86_microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.91_none_d6c3f1519bae0514 with return code -3.
Failed to trace component x86_policy.8.0.microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.91_none_58b1a5ca663317c4 with return code -3.
Currently storing 227 datablocks.
Finish time: 2014-10-10 15:39:38.512
Script hash: wipUJKeuec8LeynJGCQJp1W5fQET6ii7QXxg+mHcniI=
Thanks, DonB
Thanks DonB.
These files have not been easy to locate. Judging by the version numbers they are from an old VC redistribute, but I am not having any luck finding the name of the update. I can see if I can manually find the file via the registry.
SFCFix Collect COMPONENTS
  2. Download SFCFixScript.txt, and save this to your Desktop. Ensure that this file is named SFCFixScript.txt - do not rename it.
  3. On your Desktop, you should now see two files: SFCFix.exe and SFCFixScript.txt.
  4. Drag the file SFCFixScript.txt onto the file SFCFix.exe and release it.
  5. SFCFix will now begin to upload your CBS logfiles to our server.
  6. Upon completion, a log should be created on your Desktop: SFCFix.txt.
  7. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text.
If all goes well, you should see that your logfiles have now been added to your thread.
Thanks Don, they are from a very early release of VC. The files VC80 are from Visual C++ 2005, the first version was 41 and we are looking for 91.
I will have a search through the registry to see if I can find them.
Sorry the delay Don.
Please go Here and download MiniToolBox and save this file to your desktop.
Go to your desktop and launch MiniToolBox.exe - > Select the following options:
  • Installed programs
Press Go
Once finished a notepad file called Result.txt will open. Please post the contents back into this thread.
MiniToolBox by Farbar Version: 21-07-2014
Ran by DonB (administrator) on 04-11-2014 at 17:21:29
Running from "C:\Users\DonB\Downloads"
Microsoft Windows 7 Professional Service Pack 1 (X64)
Boot Mode: Normal
=========================== Installed Programs ============================
6000E609_eDocs (x32 Version: 1.00.0000 - Hewlett-Packard) Hidden
64 Bit HP CIO Components Installer (Version: 6.2.1 - Hewlett-Packard) Hidden
64 Bit HP CIO Components Installer (Version: 7.2.8 - Hewlett-Packard) Hidden
7-Zip 9.34 (x64 edition) (HKLM\...\{23170F69-40C1-2702-0934-000001000000}) (Version: 9.34.00.0 - Igor Pavlov)
Adobe Flash Player 15 ActiveX (HKLM-x32\...\Adobe Flash Player ActiveX) (Version: 15.0.0.189 - Adobe Systems Incorporated)
Adobe Flash Player 15 Plugin (HKLM-x32\...\Adobe Flash Player Plugin) (Version: 15.0.0.189 - Adobe Systems Incorporated)
Adobe Shockwave Player 12.1 (HKLM-x32\...\Adobe Shockwave Player) (Version: 12.1.3.153 - Adobe Systems, Inc.)
Allway Sync version 14.2.1 (HKLM\...\Allway Sync_is1) (Version: - Botkind Inc)
Amazon Kindle (HKLM-x32\...\Amazon Kindle) (Version: - Amazon)
Asterisk Key 10.0 (HKLM-x32\...\asterisk key) (Version: - )
ASUS Xonar DX Audio Driver (HKLM\...\C-Media Oxygen HD Audio Driver) (Version: - )
Bejeweled® 3 (HKLM-x32\...\{E99C27B2-EB2E-4244-9F5C-A96F55100F0C}) (Version: 1.1.13.4753 - Electronic Arts, Inc.)
Bing Maps 3D (HKLM\...\{6ACE7F46-FACE-4125-AE86-672F4F2A6A28}) (Version: 4.0.903.16005 - Microsoft Corporation)
BitComet 1.37 64-bit (HKLM-x32\...\BitComet_x64) (Version: 1.37 - CometNetwork)
Bitdefender Antivirus Free Edition (HKLM\...\BitDefender Gonzales) (Version: 1.0.21.1099 - Bitdefender)
Blackjack Tutor version 1.0.28 (HKLM-x32\...\BJTutor_is1) (Version: - )
BPDSoftware_Ini (x32 Version: 1.00.0000 - Hewlett-Packard) Hidden
BufferChm (x32 Version: 130.0.331.000 - Hewlett-Packard) Hidden
BufferChm (x32 Version: 140.0.213.000 - Hewlett-Packard) Hidden
CameraHelperMsi (x32 Version: 13.51.815.0 - Logitech) Hidden
CCleaner (HKLM\...\CCleaner) (Version: 4.19 - Piriform)
CD Recovery Toolbox Free 2.1 (HKLM-x32\...\CD Recovery Toolbox Free_is1) (Version: - Recovery Toolbox, Inc.)
ChessBin (HKCU\...\9afbbbdbe4a6ba65) (Version: 0.0.8.0 - ChessBin.com)
CleanMem (HKLM-x32\...\CleanMem) (Version: v2.5.0 - PcWinTech.com)
COMODO Programs Manager (HKLM\...\{D968E920-3A49-48EB-BA1D-8964DCDF0CA9}) (Version: 1.3_build_30 - COMODO)
ContaCam (HKLM-x32\...\ContaCam) (Version: 4.9.7 - Contaware.com)
Converber 2.3.1 (HKLM-x32\...\Converber) (Version: 2.3.1 - Xyntec Automation Inc.)
Crazy Birds (HKLM-x32\...\CrazyBirds_is1) (Version: 1.0 - Media Contact LLC)
D3DX10 (x32 Version: 15.4.2368.0902 - Microsoft) Hidden
D7200 (x32 Version: 130.0.365.000 - Hewlett-Packard) Hidden
D7200_Help (x32 Version: 100.0.206.000 - Hewlett-Packard) Hidden
Data Lifeguard Diagnostic for Windows 1.27 (HKLM-x32\...\{519C4DB6-B53B-4F5C-8297-89B2BE949FA5}_is1) (Version: - Western Digital Corporation)
Defraggler (HKLM\...\Defraggler) (Version: 2.18 - Piriform)
Destination Component (x32 Version: 090.000.091.086 - Hewlett-Packard) Hidden
DeviceDiscovery (x32 Version: 130.0.465.000 - Hewlett-Packard) Hidden
DeviceDiscovery (x32 Version: 140.0.213.000 - Hewlett-Packard) Hidden
DeviceManagementQFolder (x32 Version: 1.00.0000 - Hewlett-Packard) Hidden
DirectX for Managed Code Update (Summer 2004) (x32 Version: 9.02.2904 - Microsoft) Hidden
DiskFresh 1.1 (HKLM\...\DiskFresh_is1) (Version: - Puran Software)
Driver Booster 2 (HKLM-x32\...\Driver Booster_is1) (Version: 2.0 - IObit)
DriverIdentifier 4.2.8 (HKLM-x32\...\{40A3E5DB-5EF8-4F04-BF3E-7AB87C4AE85A}_is1) (Version: - DriverIdentifier)
erLT (x32 Version: 1.20.138.34 - Logitech, Inc.) Hidden
Etron USB3.0 Host Controller (HKLM-x32\...\InstallShield_{DFBB738C-71D8-4DC5-B8D2-D65C37680E27}) (Version: 0.118 - Etron Technology)
Etron USB3.0 Host Controller (x32 Version: 0.118 - Etron Technology) Hidden
FairStars CD Ripper 1.80 (HKLM-x32\...\FairStars CD Ripper_is1) (Version: - FairStars Soft)
foobar2000 v1.1.15 (HKLM-x32\...\foobar2000) (Version: 1.1.17 - Peter Pawlowski)
FormatFactory 3.3.5.0 (HKLM-x32\...\FormatFactory) (Version: 3.3.5.0 - Format Factory)
FossaMail 24.7.0 (x64 en-US) (HKLM\...\FossaMail 24.7.0 (x64 en-US)) (Version: 24.7.0 - Mozilla)
Galaxy Invaders 1.0 (HKLM-x32\...\Galaxy Invaders_is1) (Version: - )
Gin Rummy/Video Poker 3.0.8 (HKLM-x32\...\VPRummy_is1) (Version: - )
GPBaseService2 (x32 Version: 140.0.212.000 - Hewlett-Packard) Hidden
GreedyGammon 1.0.6 (HKLM-x32\...\GreedyGammon_is1) (Version: - )
Hewlett-Packard ACLM.NET v1.1.0.0 (x32 Version: 1.00.0000 - Hewlett-Packard) Hidden
HiJackThis (HKLM-x32\...\{45A66726-69BC-466B-A7A4-12FCBA4883D7}) (Version: 1.0.0 - Trend Micro)
HP Update (HKLM-x32\...\{912D30CF-F39E-4B31-AD9A-123C6B794EE2}) (Version: 5.005.002.002 - Hewlett-Packard)
HPDiagnosticAlert (x32 Version: 1.00.0000 - Microsoft) Hidden
HPPhotoGadget (x32 Version: 130.0.282.000 - Hewlett-Packard) Hidden
HPProductAssistant (x32 Version: 130.0.371.000 - Hewlett-Packard) Hidden
HPProductAssistant (x32 Version: 140.0.213.000 - Hewlett-Packard) Hidden
ImgBurn (HKLM-x32\...\ImgBurn) (Version: 2.5.7.0 - LIGHTNING UK!)
ISO Workshop 5.6 (HKLM-x32\...\ISO Workshop_is1) (Version: - Glorylogic)
Java 8 Update 25 (64-bit) (HKLM\...\{26A24AE4-039D-4CA4-87B4-2F86418025F0}) (Version: 8.0.250 - Oracle Corporation)
Java 8 Update 25 (HKLM-x32\...\{26A24AE4-039D-4CA4-87B4-2F83218025F0}) (Version: 8.0.250 - Oracle Corporation)
Java Auto Updater (x32 Version: 2.8.25.18 - Oracle Corporation) Hidden
JD Game Pack 19 (HKLM-x32\...\{174F43A8-2A2F-4A98-81EE-D726B6004DBB}_is1) (Version: 19.2.1.7 - Jecko Development)
Jewel Quest (HKLM-x32\...\Jewel Quest_is1) (Version: 1.0 - Media Contact LLC)
Junk Mail filter update (x32 Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
KC Softwares SUMo (HKLM-x32\...\KC Softwares SUMo_is1) (Version: 3.11.5.248 - KC Softwares)
Lazesoft Recovery Suite version 3.5 Professional Edition (HKLM-x32\...\LS-32CB12D5-CC47-4BC8-BC97-0613CDCB0406_is1) (Version: 3.5 - Lazesoft)
LearnPoker version 1.0.7 (HKLM-x32\...\Learn to Play Poker_is1) (Version: - )
LibreOffice 4.3 Help Pack (English (United States)) (HKLM-x32\...\{7E09D6AE-5AD5-4A9F-8809-AB42A980D7F7}) (Version: 4.3.3.2 - The Document Foundation)
LibreOffice 4.3.2.2 (HKLM-x32\...\{9C13F99C-6E1A-4126-AE91-EAA2DADE08D6}) (Version: 4.3.2.2 - The Document Foundation)
LWS Facebook (x32 Version: 13.50.854.0 - Logitech) Hidden
LWS Gallery (x32 Version: 13.51.827.0 - Logitech) Hidden
LWS Help_main (x32 Version: 13.51.828.0 - Logitech) Hidden
LWS Launcher (x32 Version: 13.51.828.0 - Logitech) Hidden
LWS Motion Detection (x32 Version: 13.51.815.0 - Logitech) Hidden
LWS Pictures And Video (x32 Version: 13.51.815.0 - Logitech) Hidden
LWS Twitter (x32 Version: 13.30.1346.0 - Logitech) Hidden
LWS Video Mask Maker (x32 Version: 13.10.1216.0 - Logitech) Hidden
LWS Webcam Software (x32 Version: 13.51.815.0 - Logitech) Hidden
LWS WLM Plugin (x32 Version: 1.30.1201.0 - Logitech) Hidden
LWS YouTube Plugin (x32 Version: 13.31.1038.0 - Logitech) Hidden
Macrium Reflect Professional Edition (HKLM\...\MacriumReflect) (Version: 5.2 - Paramount Software (UK) Ltd.)
Macrium Reflect Professional Edition (Version: 5.3.7109 - Paramount Software (UK) Ltd.) Hidden
MahJong Suite 2012 v9.0 (HKLM-x32\...\MahJong Suite_is1) (Version: - TreeCardGames)
Malwarebytes Anti-Malware version 2.0.3.1025 (HKLM-x32\...\Malwarebytes Anti-Malware_is1) (Version: 2.0.3.1025 - Malwarebytes Corporation)
MarketResearch (x32 Version: 130.0.374.000 - Hewlett-Packard) Hidden
MarketResearch (x32 Version: 140.0.214.000 - Hewlett-Packard) Hidden
Messenger Key 10.0 (HKLM-x32\...\Messenger Key) (Version: - )
Microsoft .NET Framework 4.5.2 (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1033) (Version: 4.5.51209 - Microsoft Corporation)
Microsoft .NET Framework 4.5.2 (Version: 4.5.51209 - Microsoft Corporation) Hidden
Microsoft Application Error Reporting (Version: 12.0.6015.5000 - Microsoft Corporation) Hidden
Microsoft Choice Guard (x32 Version: 2.0.48.0 - Microsoft Corporation) Hidden
Microsoft Easy Assist v2 (HKLM-x32\...\{326957C7-83FD-4550-A59A-849B7B4297DE}) (Version: 8.1.6416.0 - Microsoft Corporation)
Microsoft OneDrive (HKCU\...\OneDriveSetup.exe) (Version: 17.3.1229.0918 - Microsoft Corporation)
Microsoft Silverlight (HKLM\...\{89F4137D-6C26-4A84-BDB8-2E5A4BB71E00}) (Version: 5.1.30214.0 - Microsoft Corporation)
Microsoft Visual C++ 2005 ATL Update kb973923 - x64 8.0.50727.4053 (HKLM\...\{B6E3757B-5E77-3915-866A-CCFC4B8D194C}) (Version: - )
Microsoft Visual C++ 2005 Redistributable (x64) (HKLM\...\{AD8A2FA1-06E7-4B0D-927D-6E54B3D31028}) (Version: - )
Microsoft Visual C++ 2008 Redistributable - KB2467174 - x64 9.0.30729.5570 (HKLM\...\{8338783A-0968-3B85-AFC7-BAAE0A63DC50}) (Version: 9.0.30729.5570 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.21022 (HKLM\...\{350AA351-21FA-3270-8B7A-835434E766AD}) (Version: 9.0.21022 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729 (HKLM\...\{14297226-E0A0-3781-8911-E9D529552663}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729 (HKLM\...\{4FFA2088-8317-3B14-93CD-4C699DB37843}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 (HKLM\...\{8220EEFE-38CD-377E-8595-13398D740ACE}) (Version: 9.0.30729 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.4148 (HKLM\...\{4B6C7001-C7D6-3710-913E-5BC23FCE91E6}) (Version: 9.0.30729.4148 - Microsoft Corporation)
Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.6161 (HKLM\...\{5FCE6D76-F5DC-37AB-B2B8-22AB8CEDB1D4}) (Version: 9.0.30729.6161 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x64) - 11.0.61030 (HKLM-x32\...\{ca67548a-5ebe-413a-b50c-4b9ceb6d66c6}) (Version: 11.0.61030.0 - Microsoft Corporation)
Microsoft Visual C++ 2012 x64 Additional Runtime - 11.0.61030 (Version: 11.0.61030 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2012 x64 Minimum Runtime - 11.0.61030 (Version: 11.0.61030 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2013 Redistributable (x64) - 12.0.21005 (HKLM-x32\...\{7f51bdb9-ee21-49ee-94d6-90afc321780e}) (Version: 12.0.21005.1 - Microsoft Corporation)
Microsoft Visual C++ 2013 x64 Additional Runtime - 12.0.21005 (Version: 12.0.21005 - Microsoft Corporation) Hidden
Microsoft Visual C++ 2013 x64 Minimum Runtime - 12.0.21005 (Version: 12.0.21005 - Microsoft Corporation) Hidden
Microsoft Windows Media Video 9 VCM (HKLM-x32\...\WMV9_VCM) (Version: - )
MiniTool Power Data Recovery (HKLM-x32\...\MiniTool Power Data Recovery_is1) (Version: - MiniTool Solution Ltd.)
Monopoly (HKLM-x32\...\{20FA8AEE-E785-4F79-98EB-2067A8F395F4}) (Version: - )
Mp3tag v2.65 (HKLM-x32\...\Mp3tag) (Version: v2.65 - Florian Heidenreich)
MPC-HC 1.7.7 (64-bit) (HKLM\...\{2ACBF1FA-F5C3-4B19-A774-B22A31F231B9}_is1) (Version: 1.7.7 - MPC-HC Team)
MSVCRT (x32 Version: 15.4.2862.0708 - Microsoft) Hidden
MSVCRT_amd64 (x32 Version: 15.4.2862.0708 - Microsoft) Hidden
MSVCRT110 (x32 Version: 16.4.1108.0727 - Microsoft) Hidden
MSVCRT110_amd64 (Version: 16.4.1109.0912 - Microsoft) Hidden
MSXML 4.0 SP2 (KB954430) (HKLM-x32\...\{86493ADD-824D-4B8E-BD72-8C5DCDC52A71}) (Version: 4.20.9870.0 - Microsoft Corporation)
MSXML 4.0 SP2 (KB973688) (HKLM-x32\...\{F662A8E6-F4DC-41A2-901E-8C11F044BDEC}) (Version: 4.20.9876.0 - Microsoft Corporation)
MSXML 4.0 SP3 Parser (HKLM-x32\...\{196467F1-C11F-4F76-858B-5812ADC83B94}) (Version: 4.30.2100.0 - Microsoft Corporation)
MSXML 4.0 SP3 Parser (KB2721691) (HKLM-x32\...\{355B5AC0-CEEE-42C5-AD4D-7F3CFD806C36}) (Version: 4.30.2114.0 - Microsoft Corporation)
MSXML 4.0 SP3 Parser (KB2758694) (HKLM-x32\...\{1D95BA90-F4F8-47EC-A882-441C99D30C1E}) (Version: 4.30.2117.0 - Microsoft Corporation)
MSXML 4.0 SP3 Parser (KB973685) (HKLM-x32\...\{859DFA95-E4A6-48CD-B88E-A3E483E89B44}) (Version: 4.30.2107.0 - Microsoft Corporation)
MultiHasher 2.7 (HKLM-x32\...\{6D8A77EC-1D83-4F07-9038-6913EFEACA1F}_is1) (Version: 2.7.0.0 - abelhadigital.com)
NetSetMan 3.7.3 (HKLM-x32\...\NetSetMan_is1) (Version: 3.7.3 - Ilja Herlein)
Network64 (Version: 140.0.215.000 - Hewlett-Packard) Hidden
Network64 (Version: 140.0.221.000 - Hewlett-Packard) Hidden
Nielsen (HKLM-x32\...\NetSight) (Version: - )
Nitronic Rush (2012-03-03) version 20120303.0 (HKLM-x32\...\{9B55759D-424F-4CB1-B84E-AAE83CC1D20A}_is1) (Version: 20120303.0 - DigiPen)
NVIDIA 3D Vision Controller Driver 344.11 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 344.11 - NVIDIA Corporation)
NVIDIA 3D Vision Driver 344.11 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 344.11 - NVIDIA Corporation)
NVIDIA Control Panel 344.11 (Version: 344.11 - NVIDIA Corporation) Hidden
NVIDIA Graphics Driver 344.11 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 344.11 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.32.1 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.32.1 - NVIDIA Corporation)
NVIDIA Install Application (Version: 2.1002.162.1274 - NVIDIA Corporation) Hidden
NVIDIA PhysX (x32 Version: 9.14.0702 - NVIDIA Corporation) Hidden
NVIDIA Stereoscopic 3D Driver (x32 Version: 7.17.12.6514 - NVIDIA Corporation) Hidden
Ocean Quest (HKLM-x32\...\Ocean Quest_is1) (Version: 1.0 - Media Contact LLC)
OpenAL (HKLM-x32\...\OpenAL) (Version: - )
Origin (HKLM-x32\...\Origin) (Version: 9.4.22.2815 - Electronic Arts, Inc.)
Pale Moon 25.0.2 (x64 en-US) (HKLM\...\Pale Moon 25.0.2 (x64 en-US)) (Version: 25.0.2 - Moonchild Productions)
PanoStandAlone (x32 Version: 90.0.146.000 - Hewlett-Packard) Hidden
PDF-Viewer (HKLM\...\{A278382D-4F1B-4D47-9885-8523F7261E8D}_is1) (Version: 2.5.311.0 - Tracker Software Products Ltd)
Playlist Creator 3.6.2 (HKLM-x32\...\Playlist Creator 3.6.2) (Version: 3.6.2.0 - oddgravity)
PlayReady PC Runtime x86 (HKLM-x32\...\{CCA5EAAD-92F4-4B7A-B5EE-14294C66AB61}) (Version: 1.3.0 - Microsoft Corporation)
Presilo 0.4.4.0 (HKLM-x32\...\Presilo Label Builder_is1) (Version: - Anderson Wilson)
PrintMaster Gold 17 (HKLM-x32\...\{C4DCAD15-B754-4FD9-8035-713FE919B118}) (Version: 17.00.0000 - Broderbund Software)
PS_SF_02_ProductContext (x32 Version: 130.0.365.000 - Hewlett-Packard) Hidden
PS_SF_02_Software_Min (x32 Version: 130.0.365.000 - Hewlett-Packard) Hidden
Quick Poker 3.3 (remove only) (HKLM-x32\...\Quick Poker 3.3) (Version: - )
Rainlendar2 (remove only) (HKLM-x32\...\Rainlendar2) (Version: - )
RarmaRadio 2.69 (HKLM-x32\...\RarmaRadio_is1) (Version: - RaimerSoft)
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.78.1218.2013 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7266 - Realtek Semiconductor Corp.)
recALL version 14.08c (HKLM-x32\...\recALL_is1) (Version: 14.08c - )
ScannerCopy (x32 Version: 9.0.0.0 - Hewlett-Packard) Hidden
Skypeâ„¢ 6.21 (HKLM-x32\...\{24991BA0-F0EE-44AD-9CC8-5EC50AECF6B7}) (Version: 6.21.104 - Skype Technologies S.A.)
SmartClose 1.3 (HKLM-x32\...\SmartClose.{7F22CBCB-92B5-4F5D-9A34-BB690215BEF2}_is1) (Version: 1.3 - BM-productions)
SmartWebPrinting (x32 Version: 130.0.457.000 - Hewlett-Packard) Hidden
SolutionCenter (x32 Version: 130.0.373.000 - Hewlett-Packard) Hidden
SolutionCenter (x32 Version: 140.0.214.000 - Hewlett-Packard) Hidden
Status (x32 Version: 130.0.469.000 - Hewlett-Packard) Hidden
Status (x32 Version: 140.0.256.000 - Hewlett-Packard) Hidden
Super Bikes (HKLM-x32\...\Super Bikes_is1) (Version: 1.0 - Media Contact LLC)
Super Collapse! 3 Endless (HKLM-x32\...\{D856D109-74FF-4008-BE3F-8E516DA784FF}) (Version: 1.0.0.0 - RealNetworks, Inc.)
SUPERAntiSpyware (HKLM\...\{CDDCBBF1-2703-46BC-938B-BCC81A1EEAAA}) (Version: 6.0.1158 - SUPERAntiSpyware.com)
swMSM (HKLM-x32\...\{612C34C7-5E90-47D8-9B5C-0F717DD82726}) (Version: - )
Toolbox (x32 Version: 130.0.648.000 - Hewlett-Packard) Hidden
Toolbox (x32 Version: 140.0.428.000 - Hewlett-Packard) Hidden
tools-freebsd (x32 Version: 9.6.2.2249910 - VMware, Inc.) Hidden
tools-linux (x32 Version: 9.6.2.2249910 - VMware, Inc.) Hidden
tools-netware (x32 Version: 9.6.2.2249910 - VMware, Inc.) Hidden
tools-solaris (x32 Version: 9.6.2.2249910 - VMware, Inc.) Hidden
tools-windows (x32 Version: 9.6.2.2249910 - VMware, Inc.) Hidden
tools-winPre2k (x32 Version: 9.6.2.2249910 - VMware, Inc.) Hidden
TrayApp (x32 Version: 130.0.422.000 - Hewlett-Packard) Hidden
TrayApp (x32 Version: 140.0.213.000 - Hewlett-Packard) Hidden
Tweaking.com - Envelope Printer (HKLM-x32\...\Tweaking.com - Envelope Printer) (Version: 1.6.0 - Tweaking.com)
Tweaking.com - Registry Backup (HKLM-x32\...\Tweaking.com - Registry Backup) (Version: 1.10.1 - Tweaking.com)
Tweaking.com - Windows Repair (All in One) (HKLM-x32\...\Tweaking.com - Windows Repair (All in One)) (Version: 2.10.0 - Tweaking.com)
UltimateZip 7.0 (HKLM-x32\...\UltimateZip_is1) (Version: 7.0.8.1 - SWE von Schleusen)
UnloadSupport (x32 Version: 11.0.0 - Hewlett-Packard) Hidden
Unlocker 1.9.2 (HKLM\...\Unlocker) (Version: 1.9.2 - Cedrick Collomb)
USB Safely Remove 5.2 (HKLM-x32\...\USB Safely Remove_is1) (Version: - SafelyRemove.com)
Visual BCD (HKLM-x32\...\{A963ACDA-55B5-48B4-8FC4-1B2F674B1C31}) (Version: 0.9 - BoYans)
Visual C++ 8.0 Runtime Setup Package (x64) (HKLM-x32\...\{2FDBBCEA-62DB-45F4-B6E5-0E1FB2A1F29D}) (Version: 9.0.0.623 - AVG Technologies CZ, s.r.o.)
Visual Studio 2008 x64 Redistributables (HKLM-x32\...\{FCDBEA60-79F0-4FAE-BBA8-55A26C609A49}) (Version: 10.0.0.2 - AVG Technologies)
VMware Player (HKLM-x32\...\VMware_Player) (Version: 6.0.4 - VMware, Inc)
VMware Player (Version: 6.0.4 - VMware, Inc.) Hidden
VMware vCenter Converter Standalone (HKLM-x32\...\{2BCC4907-4205-4338-BDA5-94F183144C35}) (Version: 5.5.3.2183569 - VMware, Inc.)
VPHoldem version 1.0.136 (HKLM-x32\...\Texas Hold'em Video Poker_is1) (Version: - )
WeatherMate (HKLM-x32\...\{0B6A914A-DDD5-4B7B-B179-07C08B824B5A}) (Version: 3.4.6 - Ravi Bhavnani)
WebReg (x32 Version: 130.0.132.017 - Hewlett-Packard) Hidden
WebReg (x32 Version: 140.0.213.017 - Hewlett-Packard) Hidden
Windows Automated Installation Kit (HKLM\...\{31E8F586-4EF7-4500-844D-BA8756474FF1}) (Version: 2.0.0.0 - Microsoft Corporation)
Windows Calendar (HKLM\...\{0039DDF4-B5A3-4153-8B56-3BE0B27A60B4}) (Version: 6.1.7601.17514 - Microsoft Corporation)
Windows Live Call (x32 Version: 14.0.8117.0416 - Microsoft Corporation) Hidden
Windows Live Communications Platform (x32 Version: 14.0.8117.416 - Microsoft Corporation) Hidden
Windows Live Communications Platform (x32 Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Windows Live Essentials (x32 Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Windows Live ID Sign-in Assistant (Version: 7.250.4311.0 - Microsoft Corporation) Hidden
Windows Live Mail (x32 Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Windows Live MIME IFilter (Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Windows Live Photo Common (x32 Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Windows Live PIMT Platform (x32 Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Windows Live SOXE (x32 Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Windows Live SOXE Definitions (x32 Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Windows Live UX Platform (x32 Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Windows Live UX Platform Language Pack (x32 Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Windows Live Writer (x32 Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Windows Live Writer Resources (x32 Version: 16.4.3522.0110 - Microsoft Corporation) Hidden
Windows Media Player Firefox Plugin (HKLM-x32\...\{69FDFBB6-351D-4B8C-89D8-867DC9D0A2A4}) (Version: 1.0.0.8 - Microsoft Corp)
Windows Pinball (HKLM-x32\...\{156D6665-5555-4C44-B27B-AD8F33088E8C}) (Version: 1.0.2600.5512 - Microsoft Corporation)
**** End of log ****
Command query
  1. Click on the
  3. Inside the Command Prompt windows copy and paste the following commands
    reg query "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\AD8A2FA1-06E7-4B0D-927D-6E54B3D31028" /s > 0 & notepad 0
  4. Once finished a note pad file called 0 will open Please post the contents back into this thread.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{AD8A2FA1-06E7-4B0D-927D-6E54B3D31028}]
"DisplayName"="Microsoft Visual C++ 2005 Redistributable (x64)"
"InstallDate"="20141109"
This version was installed not that long ago:
Have you installed any C++ redist. on that day? if so do you still have the files?
Do not have the MSC+Redist 2005 x64 on my Control Panel Add Remove List. Still no DVD in PC.
1. Have USB with Win7Prox64, Win shows the DVD setup older than current running OS.
2. USB has COMPRESSED INTALL.WIM on it.
3. Ran SFC /scannow /offbootdir=i:\ /offwindir=f:\windows still has errors.
My guess: sfc only reads UNCOMPRESSED files in c:\windows\winsxs. I need SFCFIX to find and use files from an alternate hard drive folder, take down the corrupt crap and replace it. DISKPART List volume shows I have DVDs.
Thanks, Don.
Where my uncompressed Win7x64 Manifests are:
P:\WINDOWS SLIPSTREAMS ISO\GRMCPRXFREO_EN_DVD\Install Wim_unarc\install\Windows\winsxs
These files most likely wont be on there, they seem to be from a very very early release of V++.
I will ask some of the other staff here to see if anyone has these files.
lets try and uninstall this version of VC++ when you go into afd/remove programs, do you get one or two options to uninstall VC 2005?
