[SOLVED] "Corrupt : MpSvc.dll" & other errors
WARNING! The following fix is specific to the user's system in this thread only. No one else should follow these instructions, as it could damage your system. If you need assistance with an issue, please start a new thread and someone will assist you shortly.
  • Download the file SFCFix.zip and save it on your desktop.
  • Drag the SFCFix.zip file over the
    SFCFix.exe executable and release it.
  • Attach the file to your next reply.
Actually I ran SURT & had 0x80240009 error.
I ran sfc /scannow, without problem.
I ran again SURT, without problem & there is the result (took very less time than before) :
Please be patience. I'd like to verify the result of each fix.
  • Download the attached file SFCFix.zip and save it on your desktop.
Great.
If it fails, run sfc /scannow again and attach the zipped cbs.log to your next reply.
Hi Peter.
I found a way to solve the 80072EE2 error.
The "windows installer" service was on manuel. I changed it to automatic and then, windows update works.
Stay a 1053 error with windows defender services. Which is not a problem for me beacause I desactived it.
Then all looks ok.
Thanks for help
Okay, thanks for your feedback.
You may remove all the tools ans log files used in this thread to clean up.
This thread will be marked as solved.
Take care.
