Hi all!
I think teknovenus's idea to check the event viewer was good.
The event viewer shows often this error:
I'd uninstall that theHunter program and check if the problem will appear next days.
There's also an error about fast startup (before the other error about the shutdown): Windows failed fast startup with error status 0xC00000D4.
It can be disabled in Control Panel\Hardware and Sound\Power Options\System Settings - change settings that are currently unavailable - untick turn on fast startup - ok.
Activation context generation failed for "C:\Program Files (x86)\theHunter\launcher\launcher.exe".Error in manifest or policy file "" on line . A component version required by the application conflicts with another component version already active. Conflicting components are:. Component 1: C:\WINDOWS\WinSxS\manifests\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.9600.17031_none_6242a4b3ecbb55a1.manifest. Component 2: C:\WINDOWS\WinSxS\manifests\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.9600.17031_none_a9efdb8b01377ea7.manifest.
