scottmandu
Well-known member
Yes I am.
Hi xilolee,
I am not sure how the polices were set. I set them to disabled.
After a bit of digging I came to the realization that the problem with the internet time server connection may be with my internet provider (MTS). I stumbled on a thread that said:
"There is a known Security Issue with NTP Inbound that required MTS to block Port 123 Inbound, until it could be patched. The patch is currently rolling out (over the next several weeks), and once that is completed and tested we will be removing the block on the NTP port (123).
This block does not affect Outbound requests, but most devices expect the inbound to also be on port 123, so it will fail unless you can set your device to a different port.
However, MTS has a NTP Clock within the network that is not blocked. If you can set your device to point to ntp.mts.net your device can get the correct time."
If I use the internet time server "ntp.mts.net" my time synchronizes correctly, and all other servers timeout. I sure wish I would have been informed of this beforehand. It would have saved me quite a bit of time.
So my problem is resolved!
