[SOLVED] Devices intermittently not working on boot- reboot solves-various BSOD
ListChkdskResults log posted as follows:
------< Log generate on 10/3/2020 11:50:55 AM >------
Category: 0
Computer Name: Jeremy-PC
Event Code: 26212
Record Number: 3782
Source Name: Chkdsk
Time Written: 10-03-2020 @ 15:49:47
Event Type: Information
User:
Message: Chkdsk was executed in read-only mode on a volume snapshot.
Checking file system on C:
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
126208 file records processed.
File verification completed.
248 large file records processed.
0 bad file records processed.
2 EA records processed.
44 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 3)...
162586 index entries processed.
Index verification completed.
0 unindexed files scanned.
0 unindexed files recovered.
CHKDSK is verifying security descriptors (stage 3 of 3)...
126208 file SDs/SIDs processed.
Cleaning up 172 unused index entries from index $SII of file 0x9.
Cleaning up 172 unused index entries from index $SDH of file 0x9.
Cleaning up 172 unused security descriptors.
18190 data files processed.
37134168 USN bytes processed.
Windows has checked the file system and found no problems.
102406310 KB total disk space.
41811188 KB in 100478 files.
66040 KB in 18191 indexes.
0 KB in bad sectors.
232566 KB in use by the system.
60296516 KB available on disk.
25601577 total allocation units on disk.
15074129 allocation units available on disk.
Category: 0
Event Code: 1001
Record Number: 2283
Time Written: 09-02-2020 @ 21:25:38
User:
Message:
that you continue.
117760 file records processed.
234 large file records processed.
153136 index entries processed.
117760 file SDs/SIDs processed.
Cleaning up 51 unused index entries from index $SII of file 0x9.
Cleaning up 51 unused index entries from index $SDH of file 0x9.
Cleaning up 51 unused security descriptors.
17689 data files processed.
36415224 USN bytes processed.
37325212 KB in 71866 files.
52792 KB in 17690 indexes.
223298 KB in use by the system.
64805008 KB available on disk.
16201252 allocation units available on disk.
Internal Info:
00 cc 01 00 df 5d 01 00 68 c2 02 00 00 00 00 00 .....]..h.......
37 00 00 00 2c 00 00 00 00 00 00 00 00 00 00 00 7...,...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Category: 0
Event Code: 1001
Record Number: 1583
Time Written: 09-02-2020 @ 18:02:01
User:
Message:
that you continue.
218 large file records processed.
153482 index entries processed.
Cleaning up 32 unused index entries from index $SII of file 0x9.
Cleaning up 32 unused index entries from index $SDH of file 0x9.
Cleaning up 32 unused security descriptors.
17862 data files processed.
35720656 USN bytes processed.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
35366856 KB in 70155 files.
51636 KB in 17863 indexes.
222578 KB in use by the system.
66765240 KB available on disk.
16691310 allocation units available on disk.
Internal Info:
00 cc 01 00 dd 57 01 00 06 b7 02 00 00 00 00 00 .....W..........
Category: 0
Event Code: 1001
Record Number: 1275
Time Written: 09-02-2020 @ 00:47:23
User:
Message:
that you continue.
565 large file records processed.
153718 index entries processed.
Cleaning up 133 unused index entries from index $SII of file 0x9.
Cleaning up 133 unused index entries from index $SDH of file 0x9.
Cleaning up 133 unused security descriptors.
17980 data files processed.
33594120 USN bytes processed.
29128036 KB in 67789 files.
50956 KB in 17981 indexes.
220222 KB in use by the system.
73007096 KB available on disk.
18251774 allocation units available on disk.
Internal Info:
00 cc 01 00 15 4f 01 00 78 a5 02 00 00 00 00 00 .....O..x.......
34 00 00 00 2c 00 00 00 00 00 00 00 00 00 00 00 4...,...........
Jeremy
The following might take several hours to complete. You can do it overnight if you like.
Click on Start - All Programs - Accessories.
Right-click on Command-prompt and select Run as administrator.
When command prompt opens, copy and paste the following command into it, press enter afterwards.
chkdsk c: /f /r
At the question "Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)", press Y.
Restart the system.
Do not press any key during the restart. This will allow CHKDSK to start.
Wait for this to complete. Please note that this may take several hours. Let it run even if it looks like the process has stopped!
On completion, the system will restart automatically.
So, oddly this did not work even after two restarts. It just boots normal. The last time I attempted a chkdsk in windows it did finally end up going through but only after I booted the computer multiple times days later.
I am comfortable enough to do this off a boot disc so I will do that next and report back.
Jeremy
Well, I attempted the chkdsk off a boot disk and the boot disk threw an error of some sort. After multiple attempts to get back into Win7 it will boot but does not get to the desktop. I have a blank black screen with a cursor that I can move.
I'm leaning towards an issue with this motherboard is causing other issues. I have reached out to the company I purchased it from and I'm waiting to hear back. I haven't been able to use this computer since installing this motherboard due to multiple issues compounded.
Jeremy
P.S. I am able to utilize ctrl+alt+delete to pull up the menu like normally while in Windows. I attempted a restart through the power button located at bottom right but the computer just sits there on this black screen.
I think we better wait for the response. Please report back when the issue is solved or persist.
Two months later I'm back, still no word yet from the seller of the P5E3 WS Pro mobo but I purchased an Asus P5P43TD for a decent price and am currently running on that.
So far chkdsk ran as it was supposed to upon startup from 2 months ago and I was able to install my graphics card drivers without an issue!
Jeremy
Sounds good. Can we mark this thread as solved ?
Unless there is anything other tests you would like me to try or registry error checks you would like to see?
Jeremy
I expected no remaining issues after the above. Are there any remaining issues left ?
I don't know. Tonight is the first time I have been able to use the computer as I was waiting on this new motherboard.
Once I install a game I will make sure no other issues are present.
Jeremy
Okay. Please report the result.
I was able to game for about 3 hours last night without any issues. I think this is resolved.
Thanks for all of the help PeterJ!
Jeremy
Your welcome. I will mark this thread as solved.
Take care.
Small update-
I noticed that SpeedFan (version 4.52) is sticking on -17 after an intermittent amount of time within windows (I have it setup to start with windows) and today after I booted into windows while on the desktop my monitor went into sleep mode saying no input. The only thing I changed was I played with clock speed a little and voltages.
I did a hard CMOS reset (pulled battery, turned of PSU and unplugged until all lights went off on mobo, then waited 10 more seconds) fired it back up, set CMOS time and day and restarted. BSOD error 0x0000007b. I was able to F8 into Windows and load previous known configuration and it is working.
System restore will not let me create a new restore point however.
Any chance the SpeedFan issue is related? I uninstalled and reinstalled twice now.
Thanks
Jeremy
