- Mar 16, 2015
- 8,061
SFCFix scripts are fast
Uninstall a Windows Update - Command Prompt
Follow the instructions below to uninstall a Windows Update manually via the command prompt.
- On Windows Vista & 7, click on the Windows Start Menu, then enter cmd in the search box, right-click on the cmd icon and select Run as Administrator
- On Windows 8, drag your cursor in the bottom-left corner, and right-click on the metro menu preview, then select Command Prompt (Admin);
- On Windows 8.1, right click on the Windows logo in the bottom-left corner and select Command Prompt (Admin);
- Enter the command below (you can copy/paste it, to paste in the command prompt, right-click inside it and select Paste):
Code:wusa /uninstall /KB:3035583
- Let me know the outcome of the command: either it uninstall the update or either it says that the update isn't installed on the system;
