What is intel RST?Uninstall intel RST.
EDIT: I don't have rapid storage technology installed
Can I do something else to help you finding out the cause of high latency
Nonetheless, its drivers iaStorAV and iaStorA appear in your logs.
Also arcsas, nvraid, sisraid2, sisraid4, vsmraid, vstxraid.
I'll admit I have all of them too...
And at this point I'm not sure if they are remnants of previous installations or if they came with windows installation.
Yes, in my previous post of all installed software it's written 8.91.48.Did you already update your mouse software? This seems to be the newer software version for it: 8.91.48.
bcdedit
bcdedit /set {bootmgr} displaybootmenu yes
bcdedit /set {bootmgr} timeout 30
bcdedit /set {current} bootmenupolicy legacy
bcdedit
c:\>bcdedit
Windows Boot Manager
identificatore {bootmgr}
device partition=\Device\HarddiskVolume2
path \EFI\Microsoft\Boot\bootmgfw.efi
description Windows Boot Manager
locale it-IT
inherit {globalsettings}
integrityservices Enable
default {current}
resumeobject {5d5a201e-d643-11e4-a71c-9001aae18364}
displayorder {current}
toolsdisplayorder {memdiag}
timeout 30
displaybootmenu No
Caricatore di avvio di Windows
identificatore {current}
device partition=C:
path \WINDOWS\system32\winload.efi
description Windows 10 home x64
locale it-IT
inherit {bootloadersettings}
recoverysequence {4a081ca8-71be-11e6-80cd-eca86b8ec766}
recoveryenabled Yes
isolatedcontext Yes
allowedinmemorysettings 0x15000075
osdevice partition=C:
systemroot \WINDOWS
nx AlwaysOn
bootmenupolicy Standard
quietboot No
C:\>bcdedit /set {bootmgr} displaybootmenu yes
C:\>bcdedit /set {bootmgr} timeout 30
C:\>bcdedit /set {current} bootmenupolicy legacy
c:\>bcdedit
locale it-IT
default {current}
timeout 30
displaybootmenu Yes
device partition=C:
locale it-IT
recoveryenabled Yes
isolatedcontext Yes
systemroot \WINDOWS
nx AlwaysOn
bootmenupolicy Legacy
quietboot No
verifier /reset
I created the following method to speed up things a bit, to enable verifier settings like written in Jcgriff's verifier thread, using only third party drivers (hence excluding microsoft drivers).
This was tested only on Windows 10 home x64 (and partially on windows 7)
powershell -executionpolicy unrestricted "%userprofile%\desktop\EnableVerifier.ps1"
Verifier Flags: 0x0002892b
Standard Flags:
[X] 0x00000001 Special pool.
[X] 0x00000002 Force IRQL checking.
[X] 0x00000008 Pool tracking.
[ ] 0x00000010 I/O verification.
[X] 0x00000020 Deadlock detection.
[ ] 0x00000080 DMA checking.
[X] 0x00000100 Security checks.
[X] 0x00000800 Miscellaneous checks.
[X] 0x00020000 DDI compliance checking.
Additional Flags:
[ ] 0x00000004 Randomized low resources simulation.
[ ] 0x00000200 Force pending I/O requests.
[ ] 0x00000400 IRP logging.
[ ] 0x00002000 Invariant MDL checking for stack.
[ ] 0x00004000 Invariant MDL checking for driver.
[X] 0x00008000 Power framework delay fuzzing.
[ ] 0x00010000 Port/miniport interface checking.
[ ] 0x00040000 Systematic low resources simulation.
[ ] 0x00080000 DDI compliance checking (additional).
[ ] 0x00200000 NDIS/WIFI verification.
[ ] 0x00800000 Kernel synchronization delay fuzzing.
[ ] 0x01000000 VM switch verification.
[ ] 0x02000000 Code integrity checks.
[X] Indicates flag is enabled.
Boot Mode:
Resetonbootfail
Rules:
All rules are using default settings
Extensions:
wdm: rules.default
ndis: rules.default
Verified Drivers:
More data is available.
The system reboot is required for the changes to take effect.
