Error 4448, DISM stoped at 73 %, ISO repair failed
2. Try updating the system just like you have in the past.
Step#1 - Capture Process Monitor Trace 1. Download and run Process Monitor. Leave this running while you perform the next steps.2. Try updating the system just like you have in the past. 3. Stop Process Monitor as soon as it fails. You can simply do this by clicking the magnifying glass on the toolbar as shown below.
4. Select the File menu...Save... and save the file to your desktop. This is likely the default location. The name (unless changed) will be LogFile.PML. This is fine. 5. Zip up and attach the LogFile.PML file as well as your CBS.log
Dropbox - Logfile_08_11.rar
Dropbox - cbs08_11.txt
Step#1 - FRST Fix
Step#1 - FRST Fix
Well, I did it, whole process took about couple of seconds, not more than 30, and no restart was asked for or was initiated.
View attachment Fixlog.txt
OK, here you go
[/COLOR]SFCFix version 3.0.0.0 by niemiro.Start time: 2018-11-11 17:48:31.704
Microsoft Windows 10 Build 17134 - amd64
Using .txt script file at C:\Users\Zlatko\Desktop\SFCFixScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-t..iprovider.resources_31bf3856ad364e35_10.0.17134.1_en-us_2a43f5abf3791b4c.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-t..iprovider.resources_31bf3856ad364e35_10.0.17134.1_en-us_2a43f5abf3791b4c.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
Finish time: 2018-11-11 17:48:32.062
Script hash: rEGs6KaLZEB3JGzXLVDrT2HOBXRqiHQn0yDJkhEwIVA=
----------------------EOF-----------------------[COLOR=#3E3E3E]
Here you can find Windows update proceed with, but without problem, cause there is no update available in this moment for my comp, cause recently I update it, after i flush completely windup history, and after I perform again update, it did it successfully, meanwhile I was waiting for your further direction. so what to do next?
So, procmonitor cant capture anything in side this WU proces.
Is there anyone else on this forum with some constructive idea to solve this issue beside that one clean install, I know that one too, long time before I ask for help here? Or, the best maybe is to direct me to reliable another/other forum where members are more interested in more chalenging issues?
Thank you in front
There's nothing constructive about this. Hardware issues can only be resolved by replacing the faulty part for a brand new one. Then, and only then can the issue be fully resolved. As we have confirmed by several tools, you do have indeed have a faulty drive. I've personally been through several hundreds of these issues and I know what I'm talking about.
OK, lets say I take you serous, you talk about this truly, I have my next SSD drive, and I will use it for clean install for my PC where mine <faulty>> drive was, and <<faulty>> one will use to install in side other hardware, notebook, how I can check that he is really is bad? How can I confirm your claim/theory??
Several tools have confirmed it as you have seen by the screenshots. You could also put it in another machine and see that you will get errors (maybe not right away, but very soon).
