[SOLVED] Error 9c59 Internet Explorer will not install Win 7 Pro 32 bit
Install Update with DISM
  1. Download the attached update and save to your desktop. The file name will be Windows6.1-KB2834140-v2-x86.cab.zip.
  2. Right-click on this file and select Extract All... Click the Extract button. You can close the folder window that opens
  4. When you see Command Prompt on the list, right-click on it and select Run as administrator. Go ahead and allow if you receive the UAC prompt.
  5. Copy and paste the following command into the command prompt window and press enter.
    dism /online /add-package /packagepath:%userprofile%\desktop\Windows6.1-KB2834140-v2-x86.cab
    Restart Windows to complete this operation. <---You may not get this line.
    Do you want to restart the computer now (Y/N)? <---You may not get this line.
Go ahead and do so if prompted. Let me know what errors if any come up. If you do get errors, please zip/attach your CBS.log
Dear Softwaremaniac
Thank you for all your help on this. I ran into an issue with a containment folder that was created by Comodo when it was on my system and I ended up reinstalling Windows 7.
I installed IE11 straightaway after Windows 7 before any updates and it worked, so it is resolved.
