error code (0x80073712)
  8. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put
  8. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put tags around the log to break up the text.
Patience :) There are multiple manifests missing.
You can go ahead and try updates after running the fix.
Start time: 2018-11-03 23:02:19.621
Microsoft Windows 10 Build 17134 - amd64
Using .zip script file at C:\Users\Rie\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\Winsxs\Manifests\amd64_ea1a81f712156d00ab8bf0da0bbd67ec_31bf3856ad364e35_10.0.17134.191_none_3d990d412085023d.manifest
Successfully copied file C:\Users\Rie\AppData\Local\niemiro\Archive\Manifests\amd64_ea1a81f712156d00ab8bf0da0bbd67ec_31bf3856ad364e35_10.0.17134.191_none_3d990d412085023d.manifest to C:\WINDOWS\Winsxs\Manifests\amd64_ea1a81f712156d00ab8bf0da0bbd67ec_31bf3856ad364e35_10.0.17134.191_none_3d990d412085023d.manifest.
Successfully restored ownership for C:\WINDOWS\Winsxs\Manifests\amd64_ea1a81f712156d00ab8bf0da0bbd67ec_31bf3856ad364e35_10.0.17134.191_none_3d990d412085023d.manifest
Successfully restored permissions on C:\WINDOWS\Winsxs\Manifests\amd64_ea1a81f712156d00ab8bf0da0bbd67ec_31bf3856ad364e35_10.0.17134.191_none_3d990d412085023d.manifest
Currently storing 11 datablocks.
Finish time: 2018-11-03 23:02:27.343
Script hash: sUc7bm/tYLvGQVD53C0u6ydIxfZRjruPRiod5x3BzOs=
Failed update once again :(
