[SOLVED] Error Code 8007000D for 5 Updates - Win7 Pro
No problem. It looks like the previous fix didn't work. We will have to do this manually. Let's first start with the following.
Step#1 - Disable Windows Update
1. Click your Start button and type cmd.exe into the search box.
2. Right-click on cmd that comes up in the search results and select Run as administrator. Click Continue if prompted with the User Account Control dialog.
3. Copy/Paste the following into the command-prompt window and hit enter. Note: You will have to right-click your mouse in the command-prompt window and select paste. You can't use the keyboard shortcuts.
sc stop wuauserv && sc config wuauserv start= disabled
4. You should see something similar to the following. The important parts are in Red. If you see this, you did it correctly.
SERVICE_NAME: wuauserv
        TYPE               : 20  WIN32_SHARE_PROCESS
        STATE              : 3  [COLOR=#ff0000]STOP_PENDING[/COLOR]
                                (NOT_STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
        WIN32_EXIT_CODE    : 0  (0x0)
        SERVICE_EXIT_CODE  : 0  (0x0)
        CHECKPOINT         : 0x1
        WAIT_HINT          : 0x7530
[SC] ChangeServiceConfig [COLOR=#ff0000]SUCCESS[/COLOR]
Step#2 - Retrieve Components/Software Hives
Note: The Software have has confidential and sensitive information in it so please send me a PM with a link to that particular hive so it's not in the public form.
  • This will bring you into the folder where the backup was made. You should see a Users folder and a Windows folder along with a couple other files. Double-click on the Windows folder to open it. Then open the System32 folder and then config folder. You should see around 6 files in here, two of which are named COMPONENTS and SOFTWARE.
  • Copy these two files to your Desktop. If the COMPONENTS file does not exist, please fetch it instead from C:\Windows\System32\config\COMPONENTS.
  • Now right click on these files on your desktop and select Send to > Compressed (zipped) folder.
  • Then please upload the zip file(s) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Dropbox or One Drive or SendSpace and then just provide the link in your reply.
Step#1 - SFCFix Script
Hello again,
here is the resualt of the SFCFix
Start time: 2016-06-20 09:12:36.080
Using .txt script file at C:\Users\schruff\Desktop\SFCScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-c..ityclient.resources_31bf3856ad364e35_0.0.0.0_de-de_3bc71222b17e5ada.
WARNING: Failed to create backup for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-c..ityclient.resources_31bf3856ad364e35_0.0.0.0_de-de_3bc71222b17e5ada.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-c..ityclient.resources_31bf3856ad364e35_0.0.0.0_de-de_3bc71222b17e5ada.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-c..ityclient.resources_31bf3856ad364e35_0.0.0.0_de-de_3bc71222b17e5ada.
Finish time: 2016-06-20 09:12:36.141
Script hash: vrh9TjBeRY5eSqt9huBps+br2BTpQZyovF0oZI/vHyA=
Thanks. Now, let's re-enable Windows Update and try the update again.
Enable Windows Update
sc config wuauserv start= delayed-auto && sc start wuauserv
        STATE              : 2  [COLOR=#ff0000]START_PENDING[/COLOR]
        CHECKPOINT         : 0x0
        WAIT_HINT          : 0x7d0
        PID                : 1136
        FLAGS              :
Try to install update KB3146706 again
Perfect! Now I was able to install the 5 updates and the further updates from the last patchday, too.
Thanks again for the great help. :thumbsup2:
