[SOLVED] Error Code 800B0100
Good. All those files are fixed. Now please do the following.
Step#1 - SFC Scan
  1. Click on the Start
Brian,
When I shut the computer down last night it once again tried to reinstall the Updates for Windows 7 X64. This time it succeeded and the updates were "successful". I have to believe that installing the files in the package folder which we did was what Windows was waiting for. So my question is how did those files disappear? I had the correct folder C:\Windows\Temp\CheckSur\Servicing\Packages but the Packages folder was empty before I copied the files into it. Anyway I did the last thing you had asked me to do and the cbs.txt file is included.View attachment 19313 Please let me know if there is any reason to continue with this. I am happy that my problem has finally been solved and thank you very much for your help.
foxx
I'm happy your issue is resolved. The C:\Windows\Temp\CheckSur\Servicing\Packages directory would be empty. It's a temporary/working location that we place corrupted files so that SURT can pick them up and put them in the appropriate locations.
I checked your most recent log and all looks good. Take care.
