[SOLVED] Failed to install KB3061904 and KB3049563
The Don
Well-known member
On my windows 8.1 32bit pc I am unable to install the windows updates KB3061904 and KB3049563 :huh:
I would appreciate help getting past this hurdle.
Thanks
Hi and welcome to Sysnative. I need to collect some info. Please do the following.
Step#1 - SFC Scan
1. Right-click on the Start
This should replace the corrupt file. Please do the following.
Step#1 - SFCFix Script
Step#2 - SFC Scan
Items for your next post
1. SFCFix.txt
2. CBS.txt
Here you go BrianDrab
SFCFix version 2.4.4.0 by niemiro.
Start time: 2015-06-02 22:17:16.941
Microsoft Windows 8.1 Update 3 - x86
Using .zip script file at C:\Users\Donald\Desktop\Work in Progress\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.17728_none_6f076a37877898e3\icrav03.rat
Successfully copied file C:\Users\Donald\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.17728_none_6f076a37877898e3\icrav03.rat to C:\WINDOWS\winsxs\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.17728_none_6f076a37877898e3\icrav03.rat.
Successfully restored ownership for C:\WINDOWS\winsxs\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.17728_none_6f076a37877898e3\icrav03.rat
Successfully restored permissions on C:\WINDOWS\winsxs\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.17728_none_6f076a37877898e3\icrav03.rat
SFCFix version 2.4.4.0 by niemiro has completed.
Finish time: 2015-06-02 22:17:17.660
Script hash: YAq1gUCgafUKQNgUBUFdgwW9ELAeUvkb7aeaOfBOYGQ=
Darn. Didn't work but I see why. Windows was looking for the uncompressed version of that file and I provided a Delta compressed version. Let's try this again.
Step#2 - SFC Scan
1. SFCFix.txt
2. CBS.txt
Start time: 2015-06-03 20:36:23.020
WARNING: File C:\WINDOWS\winsxs\x86_microsoft-windows-ie-ratings_31bf3856ad364e35_11.0.9600.17728_none_6f076a37877898e3\icrav03.rat was not backed up as that would replace the current backup.
Finish time: 2015-06-03 20:36:23.469
Script hash: p/6zMFW05zj+5p+HqPMLM5On6Ty3gyncKSVaHkq39Yg=
Then there must be other corruption lurking about. Please do the following.
  3. When DISM finishes scanning your component store, zip up and attach your CBS log to your next post: You may have to copy the file to your desktop first.
    C:\Windows\Logs\CBS\CBS.log
And there was...
2015-06-04 13:32:48, Error                 CSI    00000059@2015/6/4:11:32:48.051 (F) base\wcp\componentstore\versionedindex.cpp(3568): Store corruption detected in function ComponentStore::CRawStoreLayout::CheckFamilyIndexForDeadWinnerComponent expression: (null)
  MissingWinningComponentKey on resource [96]"x86_microsoft-windows-ie-offlinefavorites_31bf3856ad364e35_11.0.9600.17728_none_08a10edb7c76eeb1"[gle=0x80004005]
To fix this I need two of your hives. Please follow the instructions below.
Retrieve Components/Software Hives
  • This will bring you into the folder where the backup was made. You should see a Users folder and a Windows folder along with a couple other files. Double-click on the Windows folder to open it. Then open the System32 folder and then config folder. You should see around 6 files in here, two of which are named COMPONENTS and SOFTWARE.
  • Copy these two files to your Desktop. If the COMPONENTS file does not exist, please fetch it instead from C:\Windows\System32\config\COMPONENTS.
  • Now right click on these files on your desktop and select Send to > Compressed (zipped) folder.
  • Then please upload the zip file(s) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Dropbox or One Drive or SendSpace and then just provide the link in your reply.
Thanks. I see the issue. This may be tricky to fix. Please run the following. It will create a file named Manifest17728.zip on your desktop. Please attach to your next post along with the SFCFix.txt log.
Okay starting the tricky bit....
Start time: 2015-06-04 19:41:49.438
Using .txt script file at C:\Users\Donald\Desktop\Work in Progress\SFCScript.txt [0]
Zip::
Successfully copied file C:\Windows\WinSxS\Manifests\x86_microsoft-windows-ie-offlinefavorites_31bf3856ad364e35_11.0.9600.17728_none_08a10edb7c76eeb1.manifest to zip file at C:\Users\Public\Desktop\Manifest17728.zip.
Zip:: directive completed successfully.
Finish time: 2015-06-04 19:41:51.742
Script hash: 7hTOSuuUBwZ6vdJahTJb4w7aZDEGbtj++QZWnRBItN0=
Please do the following. We are going to be uninstalling IE 11 temporarily so if you have Bookmarks that you want to save, please export them out to a file and save to your desktop. Instructions for this (if you need to) are here. You may want to print these instructions for reference as well. Lastly as a safeguard you may want to ensure that you have another browser installed (i.e. Firefox or Chrome) just in case IE refuses to re-install.
Uninstall IE 11 - Temporarily
button and select Programs and Features
2. Click on Turn Windows features on or off
3. Uncheck Internet Explorer 11 and then answer Yes to the message that comes up.
4. Click OK and Restart when prompted.
5. If successful you will no longer have IE installed.
6. Now follow steps 1 & 2 and then re-check Internet Explorer 11 and click OK. Reboot when prompted.
7. Internet Explorer will be back on your machine. You may re-import your bookmarks now if need be.
Let me know if this is successful.
