Is there any back-up type software installed for the USB-3 HDD?
Are the USB-3 drivers current?
Module Name: asmthub3
Display Name: ASMedia USB3 Hub Service
Driver Type: Kernel
Link Date: 9/14/2011 3:36:19 AM
Module Name: asmtxhci
Display Name: ASMEDIA XHCI Service
Driver Type: Kernel
Link Date: 9/14/2011 3:36:09 AM
Driver Type: Kernel
Link Date: 2/21/2012 3:54:06 AM
Driver Type: Kernel
Link Date: 2/21/2012 3:53:58 AM
BIOS
Brand: American Megatrends Inc.Version: 1208Date: 04/26/2012
I am also a little concerned because the data collection apps are telling me that my BIOS is the old one... I just updated it the other day to the latest revision!
EDIT:
SPECCY is showing the proper BIOS revision... But Perfmon is showing a BIOS from 2010...
BIOS
BIOS Version/Date American Megatrends Inc. 1208, [COLOR="#FF0000"]4/26/2012[/COLOR]
[01]: AMD64 Family 16 Model 10 Stepping 0 AuthenticAMD ~3300 Mhz
BIOS Version: American Megatrends Inc. 1208, [COLOR="#FF0000"]4/26/2012[/COLOR]
BIOS: BIOS Date: [COLOR="#FF0000"]10/20/10[/COLOR] 09:47:36 Ver: 08.00.10
Processor: AMD Phenom(tm) II X6 1100T Processor (6 CPUs), ~3.3GHz
9/9/2012 7:20 AM Application Error Faulting application name: Fuel.Service.exe, version: 1.0.0.0, time stamp: 0x501fefb5
Faulting module name: Device.dll, version: 4.1.0.0, time stamp: 0x4f55e10b
Exception code: 0xc0000005
Fault offset: 0x00000000000033c1
Faulting process id: 0x450
Faulting application start time: 0x01cd8e56d51a33fe
Faulting application path: C:\Program Files\ATI Technologies\ATI.ACE\Fuel\Fuel.Service.exe
Faulting module path: C:\Program Files\ATI Technologies\ATI.ACE\Fuel\Device.dll
Report Id: ce5e6607-fa4e-11e1-96df-14dae92214c6
9/9/2012 6:29 AM Application Error Faulting application name: Fuel.Service.exe, version: 1.0.0.0, time stamp: 0x501fefb5
Faulting process id: 0x4a8
Faulting application start time: 0x01cd8e53ce62a05c
Report Id: c2bb8946-fa47-11e1-b15c-14dae92214c6
9/9/2012 6:21 AM Application Error Faulting application name: Fuel.Service.exe, version: 1.0.0.0, time stamp: 0x501fefb5
Faulting process id: 0x464
Faulting application start time: 0x01cd8e531babf4a1
Report Id: 8ccf0e24-fa46-11e1-b8bc-14dae92214c6
9/9/2012 6:18 AM Application Error Faulting application name: Fuel.Service.exe, version: 1.0.0.0, time stamp: 0x501fefb5
Faulting process id: 0x19c
Faulting application start time: 0x01cd8e529a2003dc
Report Id: 1db55a28-fa46-11e1-9881-14dae92214c6
9/9/2012 6:11 AM Application Error Faulting application name: Fuel.Service.exe, version: 1.0.0.0, time stamp: 0x501fefb5
Faulting process id: 0x60c
Faulting application start time: 0x01cd8e51d1ced369
Report Id: 2cee999b-fa45-11e1-a1c1-14dae92214c6
9/9/2012 6:09 AM Application Error Faulting application name: Fuel.Service.exe, version: 1.0.0.0, time stamp: 0x501fefb5
Faulting process id: 0x610
Faulting application start time: 0x01cd8e519a674b0a
Report Id: e9b6e44b-fa44-11e1-8e1f-14dae92214c6
9/9/2012 6:07 AM Application Error Faulting application name: Fuel.Service.exe, version: 1.0.0.0, time stamp: 0x501fefb5
Faulting process id: 0x620
Faulting application start time: 0x01cd8e49f74e1af9
Report Id: b424b5e8-fa44-11e1-8e29-14dae92214c6
[B]Stock Core Speed: 3700 MHzStock [/B]
CPU
AMD Phenom II X6 1100T
Cores: 6
Threads: 6
Name: AMD Phenom II X6 1100T
Code Name: Thuban
Package: Socket AM3 (938)
Technology: 45nm
Specification: AMD Phenom(tm) II X6 1100T Processor
Family: F
Extended Family: 10
Model: A
Extended Model: A
Stepping: 0
Revision: PH-E0
Instructions: MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, AMD 64
Virtualization: Supported, Disabled
Hyperthreading: Not supported
Fan Speed: 1388 RPM
Bus Speed: 207.6 MHz
Rated Bus Speed: 1868.6 MHz
Stock Bus Speed: 200 MHz
Average Temperature: 25 °C
RAM
Memory slots
Total memory slots: 4
Used memory slots: 4
Free memory slots: 0
Memory
Type: DDR3
Channels #: Dual
[B]DRAM Frequency: 692.1 MHz[/B]
CAS# Latency (CL): 9 clocks
RAS# to CAS# Delay (tRCD): 9 clocks
RAS# Precharge (tRP): 9 clocksCycle Time (tRAS): 24 clocksBank Cycle Time (tRC): 33 clocksCommand Rate (CR): 1T
CPU
Cores: 6
Threads: 6
Code Name: Thuban
Technology: 45nm
Family: FExtended Family: 10Model: A
Extended Model: A
Stepping: 0
Revision: PH-E0
Fan Speed: 2596 RPM
Rated Bus Speed: 1868.4 MHz
Average Temperature: 22 °C
RAM
Memory slots
Memory
Type: DDR3
Channels #: Dual
[B]DRAM Frequency: 692.0 MHz[/B]
CPU
Cores: 6
Threads: 6
Code Name: Thuban
Technology: 45nm
Family: F
Extended Family: 10
Model: A
Extended Model: A
Stepping: 0
Revision: PH-E0
Fan Speed: 2576 RPM
Bus Speed: 179.0 MHz
Rated Bus Speed: 1789.8 MHz
Memory slots
Memory
Type: DDR3
Channels #: Dual
[COLOR="#FF0000"][B]DRAM Frequency: 596.6 MHz[/B][/COLOR]CAS# Latency (CL): 9 clocks
RAS# Precharge (tRP): 9 clocksCycle Time (tRAS): 24 clocksBank Cycle Time (tRC): 33 clocksCommand Rate (CR): 1TPhysical Memory
Memory Usage: 14 %Total Physical: 16 GBAvailable Physical: 14 GBTotal Virtual: 32 GBAvailable Virtual: 29 GB
+12V: 11.781 V
+5V: 4.956 V
CPU CORE: 1.212 V
VIN3: 1.668 V
VIN4: 2.160 V
+3.3V: 3.147 V
VIN6: 1.284 V
VIN7: 2.292 V
VIN8: 1.680 V
