Ghost Recon BreakPoint BSOD
There might be more, or the same block(s) are reported multiple times.
   2021-10-20T23:36:23.5260000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-10-19T23:56:37.3160000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-10-17T20:52:12.7730000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-10-07T20:05:16.9830000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-10-06T18:20:28.2230000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T16:24:02.1120000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T16:24:00.6130000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T16:22:09.7560000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T16:22:08.3160000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T16:19:51.8860000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T16:19:50.3890000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T16:16:39.5550000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T16:16:38.0560000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T16:12:51.6520000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T16:12:50.1510000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T16:07:46.8250000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T16:07:45.0450000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T15:51:05.2430000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T15:51:01.1480000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-21T15:46:54.9720000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-15T15:52:43.4020000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-15T15:52:41.9910000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-09-15T15:52:40.5730000Z        The device, \Device\Harddisk1\DR1, has a bad block.
   2021-08-29T11:51:30.7650000Z        The device, \Device\Harddisk1\DR1, has a bad block.
to make things clear battleye is not a software its an service that only gets activated when an battleye supported game is running, so even if i dont uninstall it, it will not give me a stop 0x124 because its not running, so this particular service is giving me a stop 0x124 and i dont know how to fix this service.
BattleEye is an anti-cheat engine which is software: a service is software. Stop 0x124's are 95% of time caused by hardware and considering the memory diagnostic program which you ran reported 3 errors, then I would suggest using different RAM sticks if possible. I've witnessed multiple occasions whereby memory diagnostic programs can be quite fickle.
