Help needed asap!!!gpu problem
I mean I didn't see the GPU there when i logged back on but few moments later screen went black restarted then i system restored. Keep in mind i have the ryzen 3900x cpu which has no onboard graphics. also my board is the x570 tomahawk
This what we can do you can reinstall device driver and when your computer becomes non-bootable we can have a look at Startup Repair log file to found out what is causing the boot problem.
If you open the log file, you’ll be shown details of all the tests performed by Startup Repair, with any errors discovered detailed. We can use this information to help diagnose and get to the root cause of the problem.
To open log file from the Windows Recovery Environment, click and open the Command Prompt. When the Command Prompt is open, type Notepad and press Enter key to open the Notepad application. The Startup Repair log file is located at:
C:\Windows\System32\Logfiles\Srt\SrtTrail.txt
You will need to navigate to the drive on which you have Windows installed (usually the C: drive) to see the SrtTrail.txt log file.
when u say reinstall device driver u mean click on gpu in device manager and delete?
Installing device driver involves you executing graphic card driver you have downloaded fro NVIDIA site.
Your computer problem is its rebooting/shutting when you try to uninstall or reinstall driver and becomes un-bootable.
yes as soon as i try to install the update my screen goes black during the install then restarts and i have to system restore
i alrdy know for a fact it will happen again but i will do so i can get to that file u were talking about
We know reboot happens we need to found out why its happening so running Startup Repair and posting the log file may help us resolve this reboot problem.
