Task Manager>End System and Compressed Memory Task
I'll start by saying i had an extremely slow startup today. I pulled up the browser, the Task Manager, and Settings/Windows Update.
Windows update did not, at that time, show the Qualcom Driver waiting to be downloaded, but instead it checked for updates, which may have
contributed to the long startup.
Anyway, after I got freed up a bit, I ran the troubleshooter and restarted. This time, when i pulled up Windows Update, it shows the pending Qualcom download again it doesn't respond when clicking the download button, nor does it provide a button for "Check for Updates".
Of note: I downloaded the Qualcom drivers from Dell.....weeks ago. And also, I have my Advanced System Settings/Hardware/Installation Settings set to NOT automatically download the mfg's custom apps and icons..... so Windows Update shouldn't be downloading drivers automatically, either.
So then I ran the troubleshooter a couple of more tims, as per your instructions, and there is no change
Windows Update does not automatically download drivers. It offers to be installed as an option.I'll start by saying i had an extremely slow startup today. I pulled up the browser, the Task Manager, and Settings/Windows Update.
Delusion,
Just letting you know that we are discussing your issue. However, most of the experts are a slight busy this period of time.
I'll suggest to you to uninstall the Qualcomm update and try to install it again from the Windows Update.
To do this:
Select the Start button, then select Settings > Update & Security > Windows Update > View update history > Uninstall updates.
Right click the Qualcomm update, and then select Uninstall.
Restart the computer, and check for updates.
If the Qualcomm update is offered, download and install it.
Let me know what happened/happens.
