Great!
Run DX DiagnosticThe only thing that shows up in Latencymon now and very rarely spikes is dxgkrnl.sys which is to do with DirectX. I have reinstalled DirectX but this issue still persists. It's nowhere near as bad as the other issue though.
1: kd> !drvobj hdaudbus
Driver object (ffffe08f230518b0) is for:
\Driver\HDAudBus
Driver Extension List: (id , addr)
(fffff80360102ae0 ffffe08f2f506fa0)
Device Object list:
ffffe08f2f8ccc00 ffffe08f2c1b3de0 ffffe08f225129f0 ffffe08f1b8e7de0
1: kd> !devnode ffffe08f23ed2720
DevNode 0xffffe08f23ed2720 for PDO 0xffffe08f225129f0
Parent 0xffffe08f169b0ae0 Sibling 0000000000 Child 0000000000
InstancePath is "HDAUDIO\FUNC_01&VEN_10DE&DEV_00A3&SUBSYS_1043889C&REV_1001\5&2b92fd5a&4&0001"
ServiceName is "HdAudAddService"
State = DeviceNodeRemoved (0x314)
Previous State = DeviceNodeStartCompletion (0x308)
StateHistory[07] = DeviceNodeStartCompletion (0x308)
StateHistory[06] = DeviceNodeAwaitingQueuedRemoval (0x311)
StateHistory[05] = DeviceNodeStartCompletion (0x308)
StateHistory[04] = DeviceNodeStartPending (0x307)
StateHistory[03] = DeviceNodeResourcesAssigned (0x306)
StateHistory[02] = DeviceNodeDriversAdded (0x305)
StateHistory[01] = DeviceNodeInitialized (0x304)
StateHistory[00] = DeviceNodeUninitialized (0x301)
StateHistory[19] = Unknown State (0x0)
StateHistory[18] = Unknown State (0x0)
StateHistory[17] = Unknown State (0x0)
StateHistory[16] = Unknown State (0x0)
StateHistory[15] = Unknown State (0x0)
StateHistory[14] = Unknown State (0x0)
StateHistory[13] = Unknown State (0x0)
StateHistory[12] = Unknown State (0x0)
StateHistory[11] = Unknown State (0x0)
StateHistory[10] = Unknown State (0x0)
StateHistory[09] = Unknown State (0x0)
StateHistory[08] = Unknown State (0x0)
Flags (0x2c002130) DNF_ENUMERATED, DNF_IDS_QUERIED,
DNF_NO_RESOURCE_REQUIRED, DNF_HAS_PROBLEM,
DNF_NO_LOWER_DEVICE_FILTERS, DNF_NO_LOWER_CLASS_FILTERS,
DNF_NO_UPPER_DEVICE_FILTERS
Problem = CM_PROB_FAILED_START
Problem Status = 0xc0000001
Failure Status 0000000000
The Wi-Fi is still disabled on my PC as I use Ethernet anyway. Quite a few devices in Device Manager say they had a problem starting and the Wi-Fi adapter is one of them. I'm not sure why though as it has the latest driver which released on the 9th May 2023. Even my Ethernet says it had a problem starting in the Events tab but it has been working fine so I'm not sure if it's a Windows 11 issue.That's excellent news and thanks for linking that thread! It's interesting that the registry amendment worked though, according to your MSINFO32 file, there was no IRQ sharing between devices apart from two system timers?
I wonder if the same solution would apply to your wireless adapter? Is that still disabled?
pnputil /enum-devices /problem
reg query "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum\HDAUDIO" /s >> %userprofile%\Desktop\HDAudio.txt
Unfortunately, I have the motherboard but not the CPU as I sold my 9900k 2 weeks ago and my current CPU is AMD not Intel so I can’t use the motherboard.Unfortunately, the registry value which I was hoping would be retained hasn't been. I have been suspecting that the root issue is motherboard related, do you have a spare motherboard which you could test with?
Event[214]
Log Name: System
Source: Microsoft-Windows-Kernel-PnP
Date: 2023-06-07T03:04:39.1160000Z
Event ID: 225
Task: N/A
Level: [b]Warning[/b]
Opcode: Info
Keyword: N/A
User: S-1-5-18
User Name: NT AUTHORITY\SYSTEM
Computer: DESKTOP-NHTEQB7
Description:
The application \Device\HarddiskVolume3\Program Files (x86)\[b]Razer[/b]\[b]Synapse3[/b]\Service\Razer Synapse Service.exe with process id 7892 stopped the removal or ejection for the device USB\[b]VID_1532&PID_0226&MI_02[/b]\9&77b2305&0&0002.
Process command line: "C:\Program Files (x86)\Razer\Synapse3\Service\Razer Synapse Service.exe"
List of affected devices:
RZCONTROL\[b]VID_1532&PID_0226&MI_00[/b]\b&1014b77a&0
0xC0000490 - STATUS_PNP_NO_COMPAT_DRIVERS
PnP could not find a compatible driver for the device. This failure is often referred to as a DNF (driver not found) problem.
Examine the hardware IDs and compatible IDs of the device in question and compare to the hardware ID(s) that the INF specifies under the Models sections. Also make sure that the TargetOSVersion part of the Models section name applies to the architecture and OS version you are running on.
Code 28 (CM_PROB_FAILED_INSTALL)
Indicates that the installation failed and there is no driver selected for this device, although the kernel did not report a problem (and there is no DNF_XXX match for this the problem). This problem can be the result of an on-board system device (ISA timer, ISA RTC, RAM Memory, and so forth) that does not yet have an INF file.
I have attached the file that you requested along with another image of an error that I keep getting randomly. I have tried researching about this error but the only thing that seems to come up is a Microsoft thread. The person who had this error explained that they changed their 7800X3D but it didn't fix it so they decided to change the motherboard, which got rid of this error. I can't find any information on why this error even happens but it's clearly something CPU related.
I also am still receiving System Interrupts in task manager that go up to 5%. I think that whatever is causing my problems is also causing the abnormally high temps. I have found Reddit forums with people using the exact same AIO cooler as me and the same CPU but their temperatures are in the 30-40 degree range when idle whereas mine sits at 52 degrees Celsius at idle. My CPU seems to go up to the 90's in games that aren't even CPU intensive such as PUBG. Perhaps something in the system is faulty but it's going to be a pain to find out what since almost everything in my system is new. There's people running the 7800X3D with stock coolers with lower temps than mine... The reason I bought this chip is because it's meant to be easy to cool due to its low wattage requirements.
Event[4468]
Log Name: System
Source: Service Control Manager
Date: 2023-06-06T17:59:45.3630000Z
Event ID: 7045
Task: N/A
Level: Information
Opcode: N/A
Keyword: Classic,
User: S-1-5-18
Description:
A service was installed in the system.
Service Name: AMD 3D V-Cache Performance Optimizer Service
Service File Name: %SystemRoot%\System32\DriverStore\FileRepository\amd3dvcache.inf_amd64_0b3c99dc64473f00\amd3dvcacheSvc.exe
Service Type: user mode service
Service Start Type: auto start
Service Account: LocalSystem
What is the Windows Driver Store? How do I update that?Service name: amd3dvcacheSvc
Display name: AMD 3D V-Cache Performance Optimizer Service
Read More:Code:Event[4468] Log Name: System Source: Service Control Manager Date: 2023-06-06T17:59:45.3630000Z Event ID: 7045 Task: N/A Level: Information Opcode: N/A Keyword: Classic, User: S-1-5-18 User Name: NT AUTHORITY\SYSTEM Computer: DESKTOP-NHTEQB7 Description: A service was installed in the system. Service Name: AMD 3D V-Cache Performance Optimizer Service Service File Name: %SystemRoot%\System32\DriverStore\FileRepository\amd3dvcache.inf_amd64_0b3c99dc64473f00\amd3dvcacheSvc.exe Service Type: user mode service Service Start Type: auto start Service Account: LocalSystem
- AMD Chipset Drivers 5.05.16.529 released 23 May 2023: https://www.amd.com/en/support/chipsets/amd-socket-am5/x670e
- AMD Adrenalin Edition, Adrenalin 23.5.2 (WHQL Recommended) released 1 June 2023: https://www.amd.com/en/support/apu/amd-ryzen-processors/amd-ryzen-7-processors/amd-ryzen-7-7800x3d
Driver Version 22.40.57.05 for Windows® 10 and Windows® 11 (Windows Driver Store Version 31.0.14057.5006).
Your current version: --> ?? 22.40.40.230307 ?? <-- --- from msinfo32 and your MB support: 31.0.14040.3
C:\Windows\System32\DriverStore folder. If it needs updating, it's done during Windows Update.What is the Windows Driver Store? How do I update that?
Shouldn’t it have updated when I downloaded all of the latest Windows updates?C:\Windows\System32\DriverStore folder. If it needs updating, it's done during Windows Update.
Only if needed.Shouldn’t it have updated when I downloaded all of the latest Windows updates?
