Morning DR M ,
Below are the results.
# Run at 8/6/2023 7:39:27 AM
# KpRm (Kernel-panik) version 2.14.0
# Website
https://kernel-panik.me/tool/kprm/
# Run by clang from C:\Users\clang\Saved Games\Downloads
# Computer Name: DESKTOP-N4NCUCI
# OS: Windows 10 X64 (19045) (10.0.19045.3208)
# Number of passes: 1
- Checked options -
~ Registry Backup
~ Delete Tools
~ Restore System Settings
~ UAC Restore
~ Delete Restore Points
~ Create Restore Point
~ Delete Quarantines
- Create Registry Backup -
~ [OK] Hive C:\WINDOWS\System32\config\SOFTWARE backed up
~ [OK] Hive C:\Users\clang\NTUSER.dat backed up
[OK] Registry Backup: C:\KPRM\backup\2023-08-06-07-39-27
- Delete Tools -
## AdwCleaner
[OK] C:\AdwCleaner deleted
## ESET Online Scanner
[OK] C:\Users\clang\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\ESET Online Scanner.lnk deleted
[OK] C:\Users\clang\AppData\Local\ESET\ESETOnlineScanner deleted
## FRST
[OK] C:\Users\clang\Desktop\Addition.txt deleted
[OK] C:\Users\clang\Desktop\Fixlog.txt deleted
[OK] C:\Users\clang\Desktop\FRST.txt deleted
[OK] C:\Users\clang\Desktop\FRST64 (1).exe deleted
[OK] C:\FRST deleted
## Kaspersky Virus Removal Tool
[OK] C:\Users\clang\Desktop\KVRT.exe deleted
- Restore System Settings -
[OK] Reset WinSock
[OK] FLUSHDNS
[OK] Hide Hidden file.
[OK] Show Extensions for known file types
[OK] Hide protected operating system files
- Restore UAC -
[OK] Set EnableLUA with default (1) value
[OK] Set ConsentPromptBehaviorAdmin with default (5) value
[OK] Set ConsentPromptBehaviorUser with default (3) value
[OK] Set EnableInstallerDetection with default (0) value
[OK] Set EnableSecureUIAPaths with default (1) value
[OK] Set EnableUIADesktopToggle with default (0) value
[OK] Set EnableVirtualization with default (1) value
[OK] Set FilterAdministratorToken with default (0) value
[OK] Set PromptOnSecureDesktop with default (1) value
[OK] Set ValidateAdminCodeSignatures with default (0) value
- Clear Restore Points -
~ [OK] RP named Scheduled Checkpoint created at 07/20/2023 02:43:31 deleted
~ [OK] RP named Windows Modules Installer created at 07/26/2023 18:41:04 deleted
~ [OK] RP named Installed HP Support Solutions Framework created at 07/31/2023 14:34:30 deleted
[OK] All system restore points have been successfully deleted
- Create Restore Point -
[OK] System Restore Point created
- Display System Restore Point -
RP named KpRm created at 08/06/2023 12:40:33
-- KPRM finished in 113.19s --
