Highest measured interrupt to process latency is at 10405.20
Is the problem still present?
Download MSI_util_v3
Run it as an administrator.
Take a screenshot and post it here.
It seems you can quite safely change the msi mode checkbox for the HD audio controller from unticked to ticked.
I have ticked it as you told me to
could you tell me what this is supposed to do or how it is supposed to help?
BTW i still get high dpc latency just not that bad anymore it is mostly due to these drivers:
do you have any knowlage about fixing thse two drivers or reducing their dpc latency?
here are the diagnostics:
CONCLUSION
LatencyMon has been analyzing your system for 0:15:32 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: ITAMAR
OS version: Windows 10, 10.0, version 2009, build: 22621 (x64)
Hardware: Z690 GAMING X, Gigabyte Technology Co., Ltd.
CPU: GenuineIntel 12th Gen Intel(R) Core(TM) i7-12700KF
Logical processors: 20
Processor groups: 1
RAM: 16223 MB total
CPU SPEED
Reported CPU speed: 3610 MHz
Highest measured interrupt to process latency (µs): 701.80
Average measured interrupt to process latency (µs): 6.399648
Highest measured interrupt to DPC latency (µs): 700.0
Average measured interrupt to DPC latency (µs): 3.375782
REPORTED ISRs
Highest ISR routine execution time (µs): 120.899169
Highest reported total ISR routine time (%): 0.033427
Total time spent in ISRs (%) 0.033596
ISR count (execution time <250 µs): 387267
REPORTED DPCs
Highest DPC routine execution time (µs): 567.001108
Driver with highest DPC routine execution time: ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Highest reported total DPC routine time (%): 0.026092
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 535.98 , NVIDIA Corporation
Total time spent in DPCs (%) 0.049892
DPC count (execution time <250 µs): 988740
DPC count (execution time 500-10000 µs): 15
DPC count (execution time 1000-2000 µs): 0
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: backgroundtaskhost.exe
Total number of hard pagefaults 1104
Hard pagefault count of hardest hit process: 974
Number of processes hit: 7
PER CPU DATA
CPU 0 Interrupt cycle time (s): 8.952767
CPU 0 ISR highest execution time (µs): 0.0
CPU 0 ISR total execution time (s): 0.0
CPU 0 ISR count: 0
CPU 0 DPC highest execution time (µs): 567.001108
CPU 0 DPC total execution time (s): 0.227652
CPU 0 DPC count: 43747
CPU 1 Interrupt cycle time (s): 27.904354
CPU 1 ISR highest execution time (µs): 120.899169
CPU 1 ISR total execution time (s): 6.262028
CPU 1 ISR count: 383810
CPU 1 DPC highest execution time (µs): 311.347368
CPU 1 DPC total execution time (s): 8.705737
CPU 1 DPC count: 908565
CPU 2 Interrupt cycle time (s): 1.452560
CPU 2 ISR highest execution time (µs): 18.088089
CPU 2 ISR total execution time (s): 0.000595
CPU 2 ISR count: 316
CPU 2 DPC highest execution time (µs): 94.586704
CPU 2 DPC total execution time (s): 0.006317
CPU 2 DPC count: 936
CPU 3 Interrupt cycle time (s): 1.282992
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 88.268698
CPU 3 DPC total execution time (s): 0.000713
CPU 3 DPC count: 128
CPU 4 Interrupt cycle time (s): 3.001976
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 124.040443
CPU 4 DPC total execution time (s): 0.115562
CPU 4 DPC count: 12046
CPU 5 Interrupt cycle time (s): 2.044380
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 563.32410
CPU 5 DPC total execution time (s): 0.054966
CPU 5 DPC count: 5371
CPU 6 Interrupt cycle time (s): 3.039340
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 96.064820
CPU 6 DPC total execution time (s): 0.120779
CPU 6 DPC count: 10065
CPU 7 Interrupt cycle time (s): 2.066690
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 117.499169
CPU 7 DPC total execution time (s): 0.047580
CPU 7 DPC count: 4346
CPU 8 Interrupt cycle time (s): 1.080502
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 37.178393
CPU 8 DPC total execution time (s): 0.000502
CPU 8 DPC count: 201
CPU 9 Interrupt cycle time (s): 1.130672
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 18.908587
CPU 9 DPC total execution time (s): 0.000265
CPU 9 DPC count: 73
CPU 10 Interrupt cycle time (s): 1.257713
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 102.085319
CPU 10 DPC total execution time (s): 0.001010
CPU 10 DPC count: 139
CPU 11 Interrupt cycle time (s): 1.034574
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 56.224377
CPU 11 DPC total execution time (s): 0.000364
CPU 11 DPC count: 75
CPU 12 Interrupt cycle time (s): 1.36120
CPU 12 ISR highest execution time (µs): 0.0
CPU 12 ISR total execution time (s): 0.0
CPU 12 ISR count: 0
CPU 12 DPC highest execution time (µs): 79.840443
CPU 12 DPC total execution time (s): 0.000740
CPU 12 DPC count: 120
CPU 13 Interrupt cycle time (s): 0.989823
CPU 13 ISR highest execution time (µs): 0.0
CPU 13 ISR total execution time (s): 0.0
CPU 13 ISR count: 0
CPU 13 DPC highest execution time (µs): 37.224377
CPU 13 DPC total execution time (s): 0.000484
CPU 13 DPC count: 78
CPU 14 Interrupt cycle time (s): 1.594764
CPU 14 ISR count: 0
CPU 14 DPC highest execution time (µs): 38.444321
CPU 14 DPC total execution time (s): 0.001076
CPU 14 DPC count: 237
CPU 15 Interrupt cycle time (s): 1.020442
CPU 15 ISR highest execution time (µs): 0.0
CPU 15 ISR total execution time (s): 0.0
CPU 15 ISR count: 0
CPU 15 DPC highest execution time (µs): 15.974515
CPU 15 DPC total execution time (s): 0.000077
CPU 15 DPC count: 26
CPU 16 Interrupt cycle time (s): 2.028179
CPU 16 ISR highest execution time (µs): 0.0
CPU 16 ISR total execution time (s): 0.0
CPU 16 ISR count: 0
CPU 16 DPC highest execution time (µs): 72.948476
CPU 16 DPC total execution time (s): 0.002597
CPU 16 DPC count: 328
CPU 17 Interrupt cycle time (s): 2.352028
CPU 17 ISR highest execution time (µs): 7.188920
CPU 17 ISR total execution time (s): 0.001632
CPU 17 ISR count: 3141
CPU 17 DPC highest execution time (µs): 69.178393
CPU 17 DPC total execution time (s): 0.005541
CPU 17 DPC count: 775
CPU 18 Interrupt cycle time (s): 2.194141
CPU 18 ISR highest execution time (µs): 0.0
CPU 18 ISR total execution time (s): 0.0
CPU 18 ISR count: 0
CPU 18 DPC highest execution time (µs): 53.859834
CPU 18 DPC total execution time (s): 0.004589
CPU 18 DPC count: 822
CPU 19 Interrupt cycle time (s): 2.238993
CPU 19 ISR highest execution time (µs): 0.0
CPU 19 ISR total execution time (s): 0.0
CPU 19 ISR count: 0
CPU 19 DPC highest execution time (µs): 108.434349
CPU 19 DPC total execution time (s): 0.006208
CPU 19 DPC count: 677
thank you for all of the help up until now!
there is one or two stutters every now and then but it is so much better then before
, i will keep this thread unresolved to update if needed if you dont mind.
thank you for all of the help xilolee!
