- Nov 22, 2017
- 2,458
Hi Jpatt1555
Apologies for the delay, Hopefully we can get the corruption sorted and then can also have a look at some potential things to try regarding the BSOD and crashes you are still experiencing. Here's the next fix.
- Download SFCFix.exe (by niemiro) and save this to your Desktop.
- Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it.
- Save any open documents and close all open windows.
- On your Desktop, you should see two files: SFCFix.exe and SFCFix.zip.
- Drag the file SFCFix.zip onto the file SFCFix.exe and release it.
- SFCFix will now process the script.
- Upon completion, a file should be created on your Desktop: SFCFix.txt.
- Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put tags around the log to break up the text.
