I am having a problem with my win7(64bit), Using windows update I am unable to update to a security patch for IE9, when I try I get error code 80070057. If I try to install the ie10 or 11 updates I get error code 9C59.
Initially to try fix this I attempted to uninstall ie9, first through the updates list (unsuccessful) and then through cmd prompt as administrator (also unsuccessful). In an attempt to fix this problem I then found MicrosoftFixIt50778, which also would not install. So I then installed MicrosoftFixIt50181, Which worked and then allowed me to install 50778. But sadly this did not help and I still have ie9 installed.
My next hope was that when I removed Mcafee it left a few bits of "junk" in my registry, So I installed CCleaner and went to work, Cleaned out everything that looked like it didnt need to be there. Still no luck so I moved on to tracking down mcafee from some info I found online and went to work. Again no good, Finally I found the mcafee removal tool and tried to clean it completely. Still No luck
Other attempts were clean system boots, and attempting to install in safemode, same issues as described above
Hope this is not all to much in the first post, I am fairly certain this is all ive attempted to fix the issue
I am unable to attach my cbs.zip as it is 7.42mb and the max allowed size is 7.15mb
