Generic info.
A hot laptop is often caused by dust clogging the heatsink and vents.
Using a can of compressed air to blow out the laptop vents and around the fan PLUS sitting the lappy on an extra good Cooling Master does the trick of lowering temps considerably I have have found.
For new inexperienced Forum members you may care to refer to the {oldish} links below.
http://www.informationweek.com/news/60300177
http://electronics.howstuffworks.com/how-to-tech/how-to-keep-laptop-cool.htm
That's what I get paid the big-bucks to do!!! (I average about $2/hr when doing computer work)
Y'know, I really don't have a clue! :banghead:Is that good or bad Carrona?
Yep, but I don't get paid enough to open the case (when it's covered by a warranty) :0)
I just send it out to the service center - and hope that they'll replace the video card based on my description.
For Dell laptops I use a program called "I8Kfangui" http://www.diefer.de/i8kfan/ you can set the temp to the fans come on at a predetermined setting helps keep my Inspiron and XPS lappys running cool :smile9:
